    4. [Frage]Sayit - Received file is too short
      pix last edited by
      lasse die DWD Unwetter Warnungen per Sayit ansagen.
      Der Text "Es gibt eine Amtliche WARNUNG vor DAUERREGEN der Stufe 2. Zeitweise schauerartig verstärkter Regen, dabei kommen bis Mittwochabend 30 bis 40 Liter je Quadratmeter zusammen." gibt im Log diesen Fehler aus und der Adapter startet neu:
      2015-10-06 13:55:33.501  - info: sayit.0 saying: Es gibt eine Amtliche WARNUNG vor DAUERREGEN der Stufe 2\. Zeitweise schauerartig verstärkter Regen, dabei kommen bis Mittwochabend 30 bis 40 Liter je Quadratmeter zusammen.
      2015-10-06 13:55:33.697  - warn: sayit.0 Received file is too short:
      2015-10-06 13:55:33.698  - warn: sayit.0 Cannot read length of file /Users/pix/Documents/iobroker/node_modules/iobroker.sayit/say.mp3
      2015-10-06 13:55:33.698  - warn: sayit.0 Received file is too short:
          at sayFinished (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:203:45)
          at sayItBrowser (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:473:5)
          at cacheFile (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:397:5)
          at /Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:415:21
          at /Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:277:39
          at getLength (/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:164:27)
          at /Users/pix/Documents/iobroker/node_modules/iobroker.sayit/main.js:276:21
      2015-10-06 13:55:34.023  - error: host.MacMini-Ethernet.fritz.box instance system.adapter.sayit.0 terminated with code 6 (uncaught exception)
      Der kürzere Text "Es gibt eine Amtliche WARNUNG vor DAUERREGEN der Stufe 2." funktioniert
      2015-10-06 13:56:06.119  - info: sayit.0 starting. Version 0.3.11 in /Users/pix/Documents/iobroker/node_modules/iobroker.sayit
      2015-10-06 13:56:06.124  - info: sayit.0 Upload announce mp3 files
      2015-10-06 13:56:18.814  - info: sayit.0 saying: /Users/pix/Documents/iobroker/node_modules/iobroker.sayit/gong.mp3
      2015-10-06 13:56:19.816  - info: sayit.0 saying: Es gibt eine Amtliche WARNUNG vor DAUERREGEN der Stufe 2.
      2015-10-06 13:56:20.092  - info: sayit.0 Copied file '/Users/pix/Documents/iobroker/node_modules/iobroker.sayit/say.mp3' to '/Users/pix/Documents/iobroker/cache/1f7f0ba3d0c7df2ab4113e6426ab5048.mp3'
      Die Fehler "is too short" mein vielleicht "is too long", oder? Wie lang darf denn ein Ansagetext sein?
      Pix
        Ne.. Es ist wirklich "too short".
        Vermute passiert folgendes: Zu viel Text wird gar nicht konvertiert und Engine gibt so was wie "Text is too long" zurück. Das speichert sayIt adapter trotzdem als mp3 Datei. Um zu erkennen, ob es Fehl-Antwort war, analysiert SayIt die Größe von mp3 Datei und falls die Gröse unter 1kb ist, dann gibt die Fehlermeldung "Received file is too short".
          pix last edited by
          Danke für die Antwort.
          Wo kann ich was über die Engine lesen? Hast du einen Link?
          Gesendet von meinem iPhone mit Tapatalk
            skorpil last edited by
            Gleiches Problem hier:
            http://forum.iobroker.de/viewtopic.php? … =40#p14645
            Was tun?
            • X
              xADDRx last edited by
              Hat hier jemand das Problem gelöst? Ich bekomme leider immer noch die Fehlermeldung:
              sayit.0 2017-10-07 01:49:00.773 error Cannot get file: received file is too short
              Beni
                tempestas last edited by
                Klar ist das gelöst.
                Nicht google als Sprachengine nehmen sondern fie cloud oder direkt Amazon Polly.
                • X
                  Hallo tempestas,
                  danke für die Antwort!
                  Hat mir weitergeholfen.
