    4. Log Fehler
    Log Fehler
      willy10 last edited by
      Hallo
      Mir ist vorhin mal aufgefallen das ich im LOG Fehler drin habe wo ich nichts mit anfangen kann. Eigendlich funktionieren meine Gerätschaften so weit.
      Mich berunruhigt das nur was da im Log so an Meldungen erscheinen. Vieleicht ist hier einer so nett und könnte mich mal aufklären. Auch wie ich das weg bekomme.
      gruss Willy
      host.pi 2018-04-17 18:32:41.546 error instance system.adapter.web.0 terminated with code 0 (OK)
      host.pi 2018-04-17 18:32:41.545 error Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      host.pi 2018-04-17 18:32:41.545 error Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.pi 2018-04-17 18:32:41.545 error Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      host.pi 2018-04-17 18:32:41.545 error Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      host.pi 2018-04-17 18:32:41.545 error Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.pi 2018-04-17 18:32:41.544 error Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      host.pi 2018-04-17 18:32:41.544 error Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      host.pi 2018-04-17 18:32:41.543 error Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.web/main.js:140:31)
      host.pi 2018-04-17 18:32:41.543 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.web/main.js:171:25
      host.pi 2018-04-17 18:32:41.543 error Caught by controller[0]: at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:758:21)
      host.pi 2018-04-17 18:32:41.539 error Caught by controller[0]: TypeError: IOSocket is not a constructor
      web.0 2018-04-17 18:32:41.286 info starting. Version 2.1.9 in /opt/iobroker/node_modules/iobroker.web, node: v6.13.1
      host.pi 2018-04-17 18:32:38.792 info instance system.adapter.web.0 started with pid 6823
      host.pi 2018-04-17 18:32:08.770 info Restart adapter system.adapter.web.0 because enabled
      host.pi 2018-04-17 18:32:08.770 error instance system.adapter.web.0 terminated with code 0 (OK)
      host.pi 2018-04-17 18:32:08.770 error Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      host.pi 2018-04-17 18:32:08.769 error Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.pi 2018-04-17 18:32:08.769 error Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      host.pi 2018-04-17 18:32:08.769 error Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      host.pi 2018-04-17 18:32:08.769 error Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.pi 2018-04-17 18:32:08.768 error Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      host.pi 2018-04-17 18:32:08.768 error Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      host.pi 2018-04-17 18:32:08.767 error Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.web/main.js:140:31)
      host.pi 2018-04-17 18:32:08.766 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.web/main.js:171:25
      host.pi 2018-04-17 18:32:08.766 error Caught by controller[0]: at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:758:21)
      host.pi 2018-04-17 18:32:08.764 error Caught by controller[0]: TypeError: IOSocket is not a constructor
      Mod-Edit by eric2905, Code_ und Spoiler–Tags eingefügt
      • wendy2702
        wendy2702 last edited by
        kannst du das logfile bitte in Code und Spoiler Tags packen.
        Ist besser wenn man Mobil mit liest.
        Danke!
        Welche Versionen:
        ADMIN
        JS-Controller
        NODE
        NPM
        WEB
        Sicher das der Web Adapter konstant "grün" bleibt?
          ADMIN 3.3.9
          JS-Controller 3.6.4
          NODE 1.5.1
          NPM (was das ist weiss ich nicht)
          WEB 2.1.9 das steht: verbunden mit Host …falsch
          Lebenszeichen ...falsch
          PS: Ob Grün kann ich nicht sehen wegen meiner Farbenblindheit...(((
          Ach, VIS lässt sich nicht starten, wollte ich noch sagen
          gruss willy
          • wendy2702
            Hi Willy,
            wie und wo hast du iobroker installiert?
            Hast du den WEB Adapter konfiguriert und in VIS die Lizenz eingetragen?
            Was genau heißt: VIS lässt sich nicht starten? Was passiert wenn du hinter der Instanz auf das letzte Symbol klickst:
            Kannst du noch die JS-Controller Version posten, entweder im Tab "Hosts" oder in der konsole:
            iobroker -v
              in der konsole nach der eingabe von : iobroken -v steht da (1.2.3)
              bei VIS in den Instanzen ganz recht dann auf "webseite öffnen" kommt dann : diese webseite ist nicht erreichbar!
              Beim Webadapter habe ich nichts eingetragen und der Code im VIS Adapter ist auch drinne..
              • wendy2702
                Ist deine Node Version wirklich 1.5.1 ? :shock:
                Kannst du mal
                node -v
                npm -v
                abfragen?
                Aber die VIS Instanz hast du gestartet? Das heißt du siehst vorne die beiden "Striche" im ersten Feld.
                • AlCalzone
                  @wendy2702:
                  Ist deine Node Version wirklich 1.5.1 ? :shock: `
                  Würde mich wundern, die Version gabs nie… Er meint vermutlich den NodeRED-Adapter.
                    nodered adapter hat 1.5.1
                    "Aber die VIS Instanz hast du gestartet? Das heißt du siehst vorne die beiden "Striche" im ersten Feld."
                    vis gestartet gestoppt und wieder gestartet….bei der internetseite die dann aufgemacht wird passiert nix mehr und striche sehe ich keine
                    achso..
                    Eingabe node -v kommt v.6.14.1
                    Eingabe npm -v kommt v.3.10.10
                    • wendy2702
                      kannst du mal einen screenshot von deinen Instanzen Posten.
                        von welchen bitte ?
                          Die sind alle installiert
                          • wendy2702
                            Wo ist denn die VIS und WEB Instanz?
                              Ist ganz unten..auf dem bild aber nicht zu sehen.
                              Ist aber beides drauf… hier nochmal
                              • wendy2702
                                Ich wollte ja den Status sehen.
                                Mach mal auf der Konsole:
                                iobroker list instances
                                Ausgabe bitte in Spoiler und Code Tags Posten.
                                  pi@pi:~ $ iobroker list instances
                                  system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  system.adapter.botvac.0 : botvac - enabled
                                  system.adapter.broadlink2.0 : broadlink2 - enabled
                                  system.adapter.cloud.0 : cloud - enabled
                                  system.adapter.discovery.0 : discovery - enabled
                                  system.adapter.enigma2.0 : enigma2 - enabled
                                  system.adapter.fritzdect.0 : fritzdect - enabled
                                  system.adapter.fronius.0 : fronius - disabled
                                  system.adapter.harmony.0 : harmony - enabled
                                  system.adapter.history.0 : history - enabled
                                  system.adapter.javascript.0 : javascript - enabled
                                  system.adapter.node-red.0 : node-red - enabled, port: 1880
                                  system.adapter.ping.0 : ping - enabled
                                  system.adapter.scenes.0 : scenes - enabled
                                  system.adapter.sonoff.0 : sonoff - disabled, port: 1881, bind: 0.0.0.0
                                  system.adapter.sonoff.1 : sonoff - disabled, port: 1883, bind: 0.0.0.0
                                  system.adapter.sonoff.2 : sonoff - disabled, port: 1885, bind: 0.0.0.0
                                  system.adapter.sony-bravia.0 : sony-bravia - disabled
                                  system.adapter.terminal.0 : terminal - enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                  system.adapter.tr-064.0 : tr-064 - enabled
                                  system.adapter.vis-bars.0 : vis-bars - enabled
                                  system.adapter.vis-hqwidgets.0 : vis-hqwidgets - enabled
                                  system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd - enabled
                                  system.adapter.vis-justgage.0 : vis-justgage - enabled
                                  system.adapter.vis-keyboard.0 : vis-keyboard - enabled
                                  system.adapter.vis-map.0 : vis-map - enabled
                                  system.adapter.vis-metro.0 : vis-metro - enabled
                                  system.adapter.vis-rgraph.0 : vis-rgraph - enabled
                                  system.adapter.vis-timeandweather.0 : vis-timeandweather - enabled
                                  system.adapter.vis-weather.0 : vis-weather - enabled
                                  system.adapter.vis.0 : vis - enabled
                                  system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  pi@pi:~ $
                                  Hier die instanzen
                                  Mod-Edit by eric2905, Dann füge ich mal die Code- und Spoiler-Tags ein….
                                    @willy10:
                                    system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin `
                                    enabled ist er ja (siehe grünes "Pause" Zeichen)
                                    aber warum ist die Ampel rot?
                                      das weiss ich nicht.
                                      Verbunden mit Horst u. Lebenszeichen bei Web.0 …beides auf falsch angezeigt
                                        und so sieht das aus:
                                        • wendy2702
                                          @wendy2702:
                                          Hi Willy,
                                          wie und wo hast du iobroker installiert? `
                                          Zitiere mich mal selber. Bitte beantworten.
                                          Blöde Frage: hast du iobroker oder das System (was auch immer) mal restartet?
                                            ja habe ich ach vom strom weggenommen, und immer wenn was neu war habe ich das dann installiert. Mir ist das im Log erst jetzt aufgefallen mit den Fehlermeldungen. VIS benutze ich sonst nicht. Habe vorhin mal auf meinen ersatz raspy ein alte Backub aufgespielt vom 04.03.23018 mit dem alten iobroken. Der geht.
                                            81.0k
                                            2234
