    4. Fehlermeldungen vom Script für Alexa
      tomdeboom last edited by
      habe seit ein paar Tage folgende Fehlermeldung im zusammenhang mit dem Alexa Script:
      ! host.iobroker 2018-04-18 20:17:30.600 info instance system.adapter.javascript.0 started with pid 21393
      ! host.iobroker 2018-04-18 20:17:00.544 info Restart adapter system.adapter.javascript.0 because enabled
      ! host.iobroker 2018-04-18 20:17:00.543 error instance system.adapter.javascript.0 terminated with code 0 (OK)
      ! host.iobroker 2018-04-18 20:17:00.542 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
      ! host.iobroker 2018-04-18 20:17:00.542 error Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:80:11)
      ! host.iobroker 2018-04-18 20:17:00.542 error Caught by controller[0]: at endReadableNT (_stream_readable.js:974:12)
      ! host.iobroker 2018-04-18 20:17:00.542 error Caught by controller[0]: at IncomingMessage.emit (events.js:185:7)
      ! host.iobroker 2018-04-18 20:17:00.542 error Caught by controller[0]: at emitNone (events.js:91:20)
      ! host.iobroker 2018-04-18 20:17:00.541 error Caught by controller[0]: at IncomingMessage. (script.js.common.AlexaControl:1019:81)
      ! host.iobroker 2018-04-18 20:17:00.541 error Caught by controller[0]: at script.js.common.AlexaControl:552:38
      ! host.iobroker 2018-04-18 20:17:00.541 error Caught by controller[0]: at Object.parse (native)
      ! host.iobroker 2018-04-18 20:17:00.540 error Caught by controller[0]: SyntaxError: Unexpected end of JSON input
      ! javascript.0 2018-04-18 20:17:00.310 info script.js.common.Alexa.AlexaLogOn: Start LogOn Process
      ! host.iobroker 2018-04-18 20:13:24.063 info instance system.adapter.javascript.0 started with pid 20640
      ! host.iobroker 2018-04-18 20:12:54.011 info Restart adapter system.adapter.javascript.0 because enabled
      ! host.iobroker 2018-04-18 20:12:54.010 error instance system.adapter.javascript.0 terminated with code 0 (OK)
      ! Caught 2018-04-18 20:12:54.010 error by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
      ! Caught 2018-04-18 20:12:54.009 error by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:80:11)
      ! Caught 2018-04-18 20:12:54.009 error by controller[0]: at endReadableNT (_stream_readable.js:974:12)
      ! Caught 2018-04-18 20:12:54.008 error by controller[0]: at IncomingMessage.emit (events.js:185:7)
      ! Caught 2018-04-18 20:12:54.008 error by controller[0]: at emitNone (events.js:91:20)
      ! Caught 2018-04-18 20:12:54.007 error by controller[0]: at IncomingMessage. (script.js.common.AlexaControl:1019:81)
      ! Caught 2018-04-18 20:12:54.007 error by controller[0]: at script.js.common.AlexaControl:552:38
      ! Caught 2018-04-18 20:12:54.006 error by controller[0]: at Object.parse (native)
      ! Caught 2018-04-18 20:12:54.001 error by controller[0]: SyntaxError: Unexpected end of JSON input
      ! javascript.0 2018-04-18 20:12:53.941 info terminating
      ! javascript.0 2018-04-18 20:12:53.932 info script.js.common.Google_Maps.Fahrzeit_Nikki_Work: Anzahl Wegepunkte: 10
      ! javascript.0 2018-04-18 20:12:53.918 error at process._tickCallback (internal/process/next_tick.js:104:9)
      ! javascript.0 2018-04-18 20:12:53.918 error at _combinedTickCallback (internal/process/next_tick.js:80:11)
      ! javascript.0 2018-04-18 20:12:53.918 error at endReadableNT (_stream_readable.js:974:12)
      ! javascript.0 2018-04-18 20:12:53.918 error at IncomingMessage.emit (events.js:185:7)
      ! javascript.0 2018-04-18 20:12:53.918 error at emitNone (events.js:91:20)
      ! javascript.0 2018-04-18 20:12:53.918 error at IncomingMessage. (script.js.common.AlexaControl:1019:81)
      ! javascript.0 2018-04-18 20:12:53.918 error at script.js.common.AlexaControl:552:38
      ! javascript.0 2018-04-18 20:12:53.918 error at Object.parse (native)
      ! javascript.0 2018-04-18 20:12:53.918 error SyntaxError: Unexpected end of JSON input
      ! javascript.0 2018-04-18 20:12:53.917 error uncaught exception: Unexpected end of JSON input
      ! javascript.0 2018-04-18 20:12:53.859 info script.js.common.Alexa.AlexaLogOn: Referer Location: "https://www.amazon.de/ap/signin?showRmr … .net%2Faut
      ! javascript.0 2018-04-18 20:12:53.569 info script.js.common.Alexa.AlexaLogOn: Start LogOn Process
      Hat das irgendwas mit der Aussage von Bluefox zu tun?
      @Bluefox:
      @Master77:
      Hallo zusammen.
      Geht mir genau so. Nur das bei mir die Harmony über IoBroker und Alexa nicht mehr funktioniert.
      Ich gebe den Befehl an Alexa, sie bestätigt auch aber es geht anscheinend kein Befehl raus. Auch wenn ich über die Alexa App den Befehl an IoBroker raus geben geht nichts.
      Es wird angezeigt das auf IoBroker gewartet wird und dann wird der Befehl ebenfalls bestätigt aber ohne ein Ergebnis. Also es tut sich nichts.
      Manuell über die Harmony Fernbedienung geht alles. Auch die Harmony App auf dem Handy funktioniert.
      Bis vor kurzem ging alles perfekt. Ohne eine Änderung meinerseits ging es von hier auf jetzt nicht mehr.
      Bluefox meinte das es anscheinend Probleme mit IoBroker pro und der Alexa Anbindung gibt.
      Weiß allerdings nicht ob das Problem noch besteht.
      Gruß Markus
      Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk `
      Bei Pro besteht das Problem weiterhin, dass Amazon Tokens nicht passen.
      Aber es darf keine Bestätigung in dem Fall kommen. `
      Ich habe die cloud pro.
      Und am dem Script habe ich nichts verändert.
      Danke und Gruß,
      Tom
        da stimmt mit den Json String was nicht..
        welchen Script meinst du ??
          Das hier –>
          AlexaControl:
          ! // AlexaControl
          ! // Version: v0.1.6
          ! // Author: Hauke
          ! // Dank an ruhr70 dessen Skript als Vorlage diente
          ! // http://forum.iobroker.net/viewtopic.php?f=37&t=6035
          ! // und Stefan.Franke, dessen Skript den Login per Cookie ermöglicht
          ! // http://forum.iobroker.net/viewtopic.php … gOn#p98493
          ! // Changelog:
          ! // v.0.1.6 Fehler behoben: Cannot use 'in' operator to search for 'provider' in undefined
          ! // v.0.1.5 Dummy-Objekte, falls Alexa {"message":null} antwortet, weil das Device derzeit nicht aktiv ist
          ! // v.0.1.4 Spielzeit und Titellänge werden nun im 2-Sekunden-Takt berechnet
          ! // v.0.1.3 WiFi ESSID / MAC werden ausgelesen
          ! // v.0.1.2 Playlists
          ! // v.0.1.1 History
          ! // v.0.1.0 erste brauchbare Version
          AlexaLogOn:
          ! // AlexaLogOn
          ! // Dieses Script ermöglicht es das Cookie für den Amazon-Account mit der Angabe
          ! // von User und Passwort (und falls konfiguriert, 2FA code) erzeugen zu lassen.
          ! // Das Cookie wird dann in einen Datenpunkt geschrieben, wo es für andere Skripe
          ! // zugriffbar ist.
          ! // Skript arbeitet unabhängig vom Cloud Adapter.
          ! // Version: v0.7
          ! // Feedback: http://forum.iobroker.net/viewtopic.php?f=37&t=9237
          ! // Changelog:
          ! // v0.7: Sonderzeichenunterstützung für user/pass
          ! // v0.6: Automatische Anpassung der Instanznummer
          ! // v0.5: Datenpunkt für Cookie Status
          ! // v0.4: Cron schedule
          ! // v0.3: 2 Factor Authentication
          ! // v0.2: CSRF wird berechnet
          ! // v0.1: initialer Release
          Danke und Gruß,
          Tom
            Hi arteck,
            ich glaube ich setze das ganze mal als GELÖST…
            Habe das Skill neu Installiert und das Script mal einen Tag ausgelassen und siehe da seit gestern läuft es wieder einwandfrei.
            Oder soll ich das Thema noch 1-2 Tage offen lassen?
            Gruß,
            Tom
