    4. IoBroker Simple Web Adapter und Visualisierung läuft nicht
      Fonzo last edited by
      Ich habe mal versucht ioBroker auf einem Raspberry PI 2 zu installieren. IoBroker läuft auch allerdings startet die Visulaisierung nicht. Woran kann das denn liegen? Der simple Web Adapter läuft auch nicht.
      raspberrypi 2015-10-11 14:48:10 info host.raspberrypi Restart adapter system.adapter.web.0 because enabled
      raspberrypi 2015-10-11 14:48:10 error host.raspberrypi instance system.adapter.web.0 terminated with code 6 (uncaught exception)
      web.0 2015-10-11 14:48:10 info web.0 http server listening on port 8082
      web.0 2015-10-11 14:48:10 error Error: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' at Function.Module._resolveFilename (module.js:336:15) at Function.Modu
      web.0 2015-10-11 14:48:10 error uncaught exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js'
      web.0 2015-10-11 14:48:10 info web.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.web
      raspberrypi 2015-10-11 14:48:07 info host.raspberrypi instance system.adapter.web.0 started with pid 18657
      raspberrypi 2015-10-11 14:47:46 info host.raspberrypi Restart adapter system.adapter.web.0 because enabled
      raspberrypi 2015-10-11 14:47:46 error host.raspberrypi instance system.adapter.web.0 terminated with code 6 (uncaught exception)
      web.0 2015-10-11 14:47:45 info web.0 http server listening on port 8082
      web.0 2015-10-11 14:47:45 error Error: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js' at Function.Module._resolveFilename (module.js:336:15) at Function.Modu
      web.0 2015-10-11 14:47:45 error uncaught exception: Cannot find module '/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/iobrokersocket.js'
      web.0 2015-10-11 14:47:45 info web.0 starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.web
        Hast du das Image von der Website genommen?
        Kann sein, dass da ein Bug drin ist.
          Ne kein Image genommen. Jessie installiert, dann Node.js und dann ioBroker über npm
            Auch hier:
            welches node?
            Habe damit auch Probleme gehabt bei der Erstellung der Images und daher bisher auf Jessie verzichtet.
            Gibt es Fehlermeldungen im log?
              @Homoran:
              Auch hier:
              welches node? `
              4.1.2
