    4. Verbindung zur (Free-) Cloud nicht möglich
      Cavaradossi last edited by
      Hallo Forum,
      ich nutze ioBroker seit ca. 4 Wochen auf dem Pi, um PCs mit dem Echo fernzusteuern. Heute morgen funktioniert das leider nicht mehr, weil vermutlich die Cloudverbindung streikt. Im Log finde ich eine ganze Reihe dieser Einträge ->
      cloud.0	2018-05-12 07:38:31.380	info	Connection changed: io client disconnect
      cloud.0	2018-05-12 07:38:31.379	error	Unknown api-key
      cloud.0	2018-05-12 07:38:31.261	info	Trying to connect as system.user.admin from undefined
      cloud.0	2018-05-12 07:37:37.661	info	Request enums
      cloud.0	2018-05-12 07:37:33.212	info	Request devices
      cloud.0	2018-05-12 07:37:33.207	info	Request devices
      cloud.0	2018-05-12 07:37:31.187	info	Connection changed: io client disconnect
      cloud.0	2018-05-12 07:37:31.179	info	Adapter redirected temporally to "https://iobroker.net:10560" in one minute. Reason: command from server
      cloud.0	2018-05-12 07:37:31.067	info	Trying to connect as system.user.admin from undefined
      cloud.0	2018-05-12 07:37:30.772	info	Connecting with https://iobroker.net:10555 with "xxxx@googlemail.com_c36290a0-461e-11e8-8d9b-f52bcd34a72"
      cloud.0	2018-05-12 07:37:30.618	info	starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.14.1
      cloud.0	2018-05-12 07:35:17.532	info	terminating
      cloud.0	2018-05-12 07:35:12.538	info	Connection changed: io client disconnect
      cloud.0	2018-05-12 07:35:12.535	error	Unknown api-key
      cloud.0	2018-05-12 07:35:12.384	info	Trying to connect as system.user.admin from undefined
      cloud.0	2018-05-12 07:34:12.525	info	Connection changed: io client disconnect
      cloud.0	2018-05-12 07:34:12.523	error	Unknown api-key
      cloud.0	2018-05-12 07:34:12.377	info	Trying to connect as system.user.admin from undefined
      cloud.0	2018-05-12 07:33:12.514	info	Connection changed: io client disconnect
      cloud.0	2018-05-12 07:33:12.512	error	Unknown api-key
      cloud.0	2018-05-12 07:33:12.363	info	Trying to connect as system.user.admin from undefined
      cloud.0	2018-05-12 07:32:12.499	info	Connection changed: io client disconnect
      cloud.0	2018-05-12 07:32:12.498	error	Unknown api-key
      cloud.0	2018-05-12 07:32:12.363	info	Trying to connect as system.user.admin from undefined
      cloud.0	2018-05-12 07:31:12.523	info	Connection changed: io client disconnect
      cloud.0	2018-05-12 07:31:12.520	error	Unknown api-key
      cloud.0	2018-05-12 07:31:12.343	info	Trying to connect as system.user.admin from undefined
      cloud.0	2018-05-12 07:30:12.477	info	Connection changed: io client disconnect
      cloud.0	2018-05-12 07:30:12.475	error	Unknown api-key
      Auf https://iobroker.net/ erhalte ich die Fehlermeldung "IOBROKER IST NOCH NICHT VERBUNDEN.
      DRÜCKEN SIE HIER, UM DIE VERBINDUNG HERZUSTELLEN."
      Ist der api-key zeitlich begrenzt oder liegt ein anderer Fehler vor. Ich hoffe, ihr könnt helfen?
      Danke und Gruß
      Cavaradossi
      • eric2905
        eric2905 last edited by
        Moin,
        @Cavaradossi:
        Die Zeile im Log hast Du gesehen?
        Prüfe mal den Key im Adapter.
        Gruß,
        Eric
        Von unterwegs getippert
          Mojn Eric,
          Danke für deine Antwort.
          Der api-key ist in der Adapterkonfiguration eingetragen mit der Instanz 'web [web.0]'. Deswegen meine Frage, ob der key zeitlich begrenz ist, denn auch eine Verbindung auf https://iobroker.net/ scheitert.
          • eric2905
            Kann das Verhalten nachstellen.
            Starte den Adapter bitte mal neu, warte ein wenig und schau dann mal.
            Gruß,
            Eric
              Keine Änderung ->
              Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
              cloud.0	2018-05-12 08:16:05.812	info	Connection changed: io client disconnect
              cloud.0	2018-05-12 08:16:05.808	error	Unknown api-key
              cloud.0	2018-05-12 08:16:05.656	info	Trying to connect as system.user.admin from undefined
              cloud.0	2018-05-12 08:15:05.609	info	Connection changed: io client disconnect
              cloud.0	2018-05-12 08:15:05.604	info	Adapter redirected temporally to 'https://iobroker.net:10560' in one minute. Reason: command from server
              cloud.0	2018-05-12 08:15:05.460	info	Trying to connect as system.user.admin from undefined
              cloud.0	2018-05-12 08:15:05.193	info	Connecting with https://iobroker.net:10555 with 'xxxx@googlemail.com_c36290a0-461e-11e8-8d9b-f52bcd34a72'
              cloud.0	2018-05-12 08:15:05.063	info	starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.14.1
              host.raspberrypi	2018-05-12 08:15:02.982	info	instance system.adapter.cloud.0 started with pid 880
              Was mich ein wenig wundert, sind diese Zeilen ->
              Liegt möglicherweise ein temporärers Problem beim Server vor?
                Kampfratte last edited by
                Ich habe das selbe Problem, Cavaradossi. Und damit Eric nicht alles doppelt schreiben muss, werde ich nun auch hier weiter sein. Ich habe mit Eric im Facebook geschrieben wegen diesem Problem.
                • eric2905
                  Ich brauche mal einen Tester :
                  Ich habe mir auf der Webseite der Free-Cloud einen neuen API-Key erzeugt und den in den Adapter eingetragen. Seitdem läuft er bei mir wieder.
                  Kann das mal bitte gegengetestet werden?
                  Gruß,
                  Eric
                    Hallo Eric,
                    Danke für den Hinweis. Mit einem neuen api-key funktionioert es jetzt wieder.
                    Cavaradossi
                      @eric2905:
                      Gruß,
                      Eric
                      Von unterwegs getippert `
                      Hallo Eric, habe dies auch getan. Und nun funktioniert es auch bei mir wieder. Vielen Dank für deine Mühe.
                        LJSven last edited by
                        neuen Key generiert, funktioniert wieder
                        1028
