    4. HILFE: iobroker läuft nicht mehr
      Berndi last edited by
      Hallo Gemeinde,
      nach einem Update des admin-Adapters hat das Drama begonnen! 😉
      sudo iobroker start
      bringt:
      module.js:549
          throw err;
          at Function.Module._resolveFilename (module.js:547:15)
          at Function.Module._load (module.js:474:25)
          at Function.Module.runMain (module.js:693:10)
          at startup (bootstrap_node.js:191:16)
          at bootstrap_node.js:612:3
      und
      sudo npm i iobroker.js-controller@1.0.3
      bringt dann:
      npm WARN deprecated tar.gz@1.0.7: ⚠️  WARNING ⚠️ tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
      > iobroker.js-controller@1.0.3 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      fs.js:1061
        return binding.unlink(pathModule._makeLong(path));
      Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
          at Object.fs.unlinkSync (fs.js:1061:18)
          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:126:24)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:590:27
          at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:622:15)
          at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2903:5)
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
          at Module._compile (module.js:652:30)
          at Object.Module._extensions..js (module.js:663:10)
          at Module.load (module.js:565:32)
          at tryModuleLoad (module.js:505:12)
      npm WARN npm@2.15.12 had bundled packages that do not match the required version(s). They have been replaced with non-bundled versions.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@1.0.3 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@1.0.3 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2018-06-17T13_48_47_212Z-debug.log</anonymous>
      Bitte helft mir, ich komme nicht mehr weiter! 😞
        Karte hin?
        Gruß Rainer
          Hallo Rainer,
          ich hoffe nicht, die ist erst ca. 4 Wochen alt… :?
          • U
            Ulti last edited by
            Habe exakt dasselbe Problem. Kann keiner helfen??? 😞
            mfg
            • Stabilostick
              Stabilostick last edited by
              Evtl. bring die Reinstallation des js-controllers etwas?
              sudo iobroker stop
              sudo npm install -g npm@4
              sudo npm install iobroker.js-controller --production
              sudo iobroker start
              Edit: npm eingefügt
                Morrio last edited by
                ich schließe mich den Problemen an. Habe genau die selben Fehlermeldungen.
                Habe mich längere Zeit nicht um meine Installation gekümmert und wollte jetzt wieder einsteigen. Bei den Updates etc ist dann das Problem aufgetreten.
                @Stabilostick:
                sudo iobroker stop
                sudo iobroker start
                Hier kommt bei mir die Fehlermeldung wie im Anhang gezeigt.
                  daniello last edited by
                  Wollte mich anschließen .. aber was ich als Log beifügen wollte hat irgendwie dazu geführt, dass ich iobroker wieder starten konnte .. vielleicht hilfts.
                  nodejs: v8.11.1
                  npm: 6.2.0
                  sudo iobroker start
                  pi@raspi:~ $ sudo iobroker start
                  module.js:549
                      throw err;
                      at startup (bootstrap_node.js:188:16)
                      at bootstrap_node.js:609:3
                  pi@raspi:~ $
                  npm install iobroker .js-controller –production
                  > iobroker.js-controller@1.4.2 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstall_check.js
                  NPM version: 6.2.0
                  npm version >= 5: disabling package-lock
                  > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
                  > node-gyp rebuild
                  make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
                    CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                    SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                    COPY Release/unix_dgram.node
                  make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                  > iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-controller
                  + iobroker.js-controller@1.4.2
                  added 341 packages from 239 contributors and audited 1773 packages in 94.343s
                  found 11 vulnerabilities (8 low, 3 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                  • Stabilostick
                    Habe oben noch
                    eingefügt.
                    npm 5.6.0 sollte man gar nicht verwenden. Und mit npm>5.7.0 habe ich wegen automatisch gelöschter Pakete auf Raspberries schlechte Erfahrungen gemacht.
                      ist 6.2.0 auch böse? Ach so .. sehe grad .. das "Größerzeichen".
                      Kann ich mit Deinem Befehl ein Downgrade machen?
                      Und wird NPM dann nicht verändert, wenn ich in per Shell ein
                      sudo apt-get update && sudo apt-get upgrade -y
                      absetzte?
                        paul53 last edited by
                        @daniello:
                        Kann ich mit Deinem Befehl ein Downgrade machen? `
                        Ja.
                        @daniello:
                        absetzte? `
                        Ja, wobei es passieren kann, dass hinterher kein NPM mehr existiert.
                          stimmt .. das hatte ich schon .. kein NPM .. musste erstmal drauf kommen 😞
                          Danke!
                            Hab ich mal gemacht das
                            /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                            + npm@4.6.1
                            added 297 packages from 135 contributors and updated 2 packages in 26.683s
                            erhalte aber noch immer
                            npm -v 6.2.0
                            • Stabilostick
                              Dann hast du noch ein zweites npm mal ohne -g installiert. Wenn du keine Lust hast, den Fehler zu suchen oder was zu löschen, mach im ioBroker-Ordner noch mal den Befehl ohne -g
                                Mit Lust hat das nichts zu tun .. eher mit Ahnungslosigkeit 🙂
                                Hat nichts geändert:
                                pi@raspi:/opt/iobroker $ sudo npm install npm@4
                                + npm@4.6.1
                                added 299 packages from 591 contributors and audited 4433 packages in 50.961s
                                found 80 vulnerabilities (22 low, 44 moderate, 14 high)
                                pi@raspi:/opt/iobroker $ npm -v
                                6.2.0
                                • Stabilostick
                                  Ups, da war ich zu voreilig. Aber keine Sorge, nichts kaputt.
                                  • Stabilostick
                                    Tipp mal ein````
                                    which npm
                                      Hatte schon geschaut .. gibt nur einen Eintrag:
                                      /usr/local/bin/npm
                                      • Stabilostick
                                        Der hat vorhin aber nach /usr/bin/npm installiert…
                                          Die Version 6.2.0 ist wahrscheinlich die in /usr/local/bin (im Suchpfad vorn). Da npm und npx nur (relative) Links sind, solltest Du sie in absolute Links auf die Version 4.6.1 ändern: Austausch der .. vorne gegen /usr. Das musste ich auch machen.
                                          root@rpihm:~# ls -l /usr/local/bin/np*
                                          lrwxrwxrwx 1 root staff 40 Jul 19 20:29 /usr/local/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                                          lrwxrwxrwx 1 root staff 40 Jul 19 20:29 /usr/local/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
                                          EDIT: Sehr einfach mit WinSCP "Verknüpfung bearbeiten"
                                            hmm npx wird dan rot .. glaube da passt was nicht.
                                            Mir ist auch nicht ganz klar was ich nach dem ändern auf Absolut machen soll .. nochmal das Downgrade auf npm 4 versuchen?
                                            81.1k
                                            3063
