    4. Globales Problem mit 3 Adaptern
    • Plasmachef
      Plasmachef last edited by
      Hallo Zusammen,
      seit ein paar Stunden habe ich ohne Vorwarnung Probleme mit 3 Adaptern:
      1. Fritzdect 0.1.1
      host.raspberrypi	2018-06-17 15:42:18.590	info	Restart adapter system.adapter.fritzdect.0 because enabled
      host.raspberrypi	2018-06-17 15:42:18.590	error	instance system.adapter.fritzdect.0 terminated with code 1 ()
      host.raspberrypi	2018-06-17 15:42:18.590	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
      host.raspberrypi	2018-06-17 15:42:18.590	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
      host.raspberrypi	2018-06-17 15:42:18.589	error	Caught by controller[0]: at Module.load (module.js:494:32)
      host.raspberrypi	2018-06-17 15:42:18.589	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      host.raspberrypi	2018-06-17 15:42:18.589	error	Caught by controller[0]: at Module._compile (module.js:577:32)
      host.raspberrypi	2018-06-17 15:42:18.589	error	Caught by controller[0]: at Object. (/opt/iobroker/node_modules/bluebird/js/release/bluebird.js:9:36)
      host.raspberrypi	2018-06-17 15:42:18.589	error	Caught by controller[0]: at module.exports (/opt/iobroker/node_modules/bluebird/js/release/promise.js:739:1)
      host.raspberrypi	2018-06-17 15:42:18.589	error	Caught by controller[0]: at require (internal/module.js:20:19)
      host.raspberrypi	2018-06-17 15:42:18.588	error	Caught by controller[0]: at Module.require (module.js:504:17)
      host.raspberrypi	2018-06-17 15:42:18.588	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
      host.raspberrypi	2018-06-17 15:42:18.588	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
      host.raspberrypi	2018-06-17 15:42:18.588	error	Caught by controller[0]: at Module.load (module.js:494:32)
      host.raspberrypi	2018-06-17 15:42:18.588	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      host.raspberrypi	2018-06-17 15:42:18.587	error	Caught by controller[0]: at Module._compile (module.js:549:28)
      host.raspberrypi	2018-06-17 15:42:18.587	error	Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
      host.raspberrypi	2018-06-17 15:42:18.587	error	Caught by controller[0]: at createScript (vm.js:56:10)
      host.raspberrypi	2018-06-17 15:42:18.587	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
      host.raspberrypi	2018-06-17 15:42:18.587	error	Caught by controller[0]: ^
      host.raspberrypi	2018-06-17 15:42:18.586	error	Caught by controller[0]: � if (tqpeof fn != "function"- {
      host.raspberrypi	2018-06-17 15:42:18.585	error	Caught by controller[0]: /opt/iobroker/node_modules/bluebird/js/release/using.js:130
      host.raspberrypi	2018-06-17 15:42:17.993	info	instance system.adapter.fritzdect.0 started with pid 2144
      2. innogy-smarthome 0.2.0
      host.raspberrypi	2018-06-17 15:44:32.190	info	Restart adapter system.adapter.innogy-smarthome.0 because enabled
      host.raspberrypi	2018-06-17 15:44:32.190	error	instance system.adapter.innogy-smarthome.0 terminated with code 0 (OK)
      host.raspberrypi	2018-06-17 15:44:32.190	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
      host.raspberrypi	2018-06-17 15:44:32.190	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
      host.raspberrypi	2018-06-17 15:44:32.190	error	Caught by controller[0]: at Module.load (module.js:494:32)
      host.raspberrypi	2018-06-17 15:44:32.189	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      host.raspberrypi	2018-06-17 15:44:32.189	error	Caught by controller[0]: at Module._compile (module.js:577:32)
      host.raspberrypi	2018-06-17 15:44:32.189	error	Caught by controller[0]: at Object. (/opt/iobroker/node_modules/bluebird/js/release/bluebird.js:9:36)
      host.raspberrypi	2018-06-17 15:44:32.189	error	Caught by controller[0]: at module.exports (/opt/iobroker/node_modules/bluebird/js/release/promise.js:739:1)
      host.raspberrypi	2018-06-17 15:44:32.189	error	Caught by controller[0]: at require (internal/module.js:20:19)
      host.raspberrypi	2018-06-17 15:44:32.189	error	Caught by controller[0]: at Module.require (module.js:504:17)
      host.raspberrypi	2018-06-17 15:44:32.188	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
      host.raspberrypi	2018-06-17 15:44:32.188	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
      host.raspberrypi	2018-06-17 15:44:32.188	error	Caught by controller[0]: at Module.load (module.js:494:32)
      host.raspberrypi	2018-06-17 15:44:32.188	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      host.raspberrypi	2018-06-17 15:44:32.188	error	Caught by controller[0]: at Module._compile (module.js:549:28)
      host.raspberrypi	2018-06-17 15:44:32.188	error	Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
      host.raspberrypi	2018-06-17 15:44:32.187	error	Caught by controller[0]: at createScript (vm.js:56:10)
      host.raspberrypi	2018-06-17 15:44:32.187	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
      host.raspberrypi	2018-06-17 15:44:32.187	error	Caught by controller[0]: ^
      host.raspberrypi	2018-06-17 15:44:32.187	error	Caught by controller[0]: � if (tqpeof fn != "function"- {
      host.raspberrypi	2018-06-17 15:44:32.186	error	Caught by controller[0]: /opt/iobroker/node_modules/bluebird/js/release/using.js:130
      innogy-smarthome.0	2018-06-17 15:44:31.937	info	starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v6.13.1
      host.raspberrypi	2018-06-17 15:44:30.174	info	instance system.adapter.innogy-smarthome.0 started with pid 2285
      3. telegram 1.2.0
      host.raspberrypi	2018-06-17 15:53:59.042	error	instance system.adapter.telegram.0 terminated with code 0 (OK)
      Caught	2018-06-17 15:53:59.042	error	by controller[0]: at Function.Module._load (module.js:445:3)
      Caught	2018-06-17 15:53:59.041	error	by controller[0]: at tryModuleLoad (module.js:453:12)
      Caught	2018-06-17 15:53:59.041	error	by controller[0]: at Module.load (module.js:494:32)
      Caught	2018-06-17 15:53:59.041	error	by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      Caught	2018-06-17 15:53:59.041	error	by controller[0]: at Module._compile (module.js:577:32)
      Caught	2018-06-17 15:53:59.041	error	by controller[0]: at Object. (/opt/iobroker/node_modules/bluebird/js/release/bluebird.js:9:36)
      Caught	2018-06-17 15:53:59.041	error	by controller[0]: at module.exports (/opt/iobroker/node_modules/bluebird/js/release/promise.js:739:1)
      Caught	2018-06-17 15:53:59.040	error	by controller[0]: at require (internal/module.js:20:19)
      Caught	2018-06-17 15:53:59.040	error	by controller[0]: at Module.require (module.js:504:17)
      Caught	2018-06-17 15:53:59.040	error	by controller[0]: at Function.Module._load (module.js:445:3)
      Caught	2018-06-17 15:53:59.040	error	by controller[0]: at tryModuleLoad (module.js:453:12)
      Caught	2018-06-17 15:53:59.040	error	by controller[0]: at Module.load (module.js:494:32)
      Caught	2018-06-17 15:53:59.040	error	by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      Caught	2018-06-17 15:53:59.039	error	by controller[0]: at Module._compile (module.js:549:28)
      Caught	2018-06-17 15:53:59.039	error	by controller[0]: at Object.runInThisContext (vm.js:97:10)
      Caught	2018-06-17 15:53:59.039	error	by controller[0]: at createScript (vm.js:56:10)
      Caught	2018-06-17 15:53:59.039	error	by controller[0]: SyntaxError: Invalid or unexpected token
      Caught	2018-06-17 15:53:59.038	error	by controller[0]: ^
      Caught	2018-06-17 15:53:59.038	error	by controller[0]: � if (tqpeof fn != "function"- {
      Caught	2018-06-17 15:53:59.037	error	by controller[0]: /opt/iobroker/node_modules/bluebird/js/release/using.js:130
      telegram.0	2018-06-17 15:53:59.003	info	terminating
      telegram.0	2018-06-17 15:53:58.926	debug	Schedule restart: 4 5 * * *
      telegram.0	2018-06-17 15:53:58.755	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v6.13.1
      telegram.0	2018-06-17 15:53:58.690	debug	statesDB connected
      telegram.0	2018-06-17 15:53:58.632	debug	objectDB connected
      telegram.0	2018-06-17 15:53:58.387	error	at Function.Module._load (module.js:445:3)
      telegram.0	2018-06-17 15:53:58.387	error	at tryModuleLoad (module.js:453:12)
      telegram.0	2018-06-17 15:53:58.387	error	at Module.load (module.js:494:32)
      telegram.0	2018-06-17 15:53:58.387	error	at Object.Module._extensions..js (module.js:586:10)
      telegram.0	2018-06-17 15:53:58.387	error	at Module._compile (module.js:577:32)
      telegram.0	2018-06-17 15:53:58.387	error	at Object. (/opt/iobroker/node_modules/bluebird/js/release/bluebird.js:9:36)
      telegram.0	2018-06-17 15:53:58.387	error	at module.exports (/opt/iobroker/node_modules/bluebird/js/release/promise.js:739:1)
      telegram.0	2018-06-17 15:53:58.387	error	at require (internal/module.js:20:19)
      telegram.0	2018-06-17 15:53:58.387	error	at Module.require (module.js:504:17)
      telegram.0	2018-06-17 15:53:58.387	error	at Module._compile (module.js:549:28)
      telegram.0	2018-06-17 15:53:58.387	error	at Object.runInThisContext (vm.js:97:10)
      telegram.0	2018-06-17 15:53:58.387	error	at createScript (vm.js:56:10)
      telegram.0	2018-06-17 15:53:58.387	error	SyntaxError: Invalid or unexpected token
      telegram.0	2018-06-17 15:53:58.387	error	^
      telegram.0	2018-06-17 15:53:58.387	error	� if (tqpeof fn != "function"- {
      telegram.0	2018-06-17 15:53:58.387	error	/opt/iobroker/node_modules/bluebird/js/release/using.js:130
      telegram.0	2018-06-17 15:53:58.372	error	uncaught exception: Invalid or unexpected token
      host.raspberrypi	2018-06-17 15:53:56.768	info	instance system.adapter.telegram.0 started with pid 3029
      host.raspberrypi	2018-06-17 15:53:56.696	info	object change system.adapter.telegram.0
      (alle Logs sind auf "Debug" erzeugt worden)
      Ich habe an der Konfiguration und Installation seit einigen Wochen schon nichts mehr gemacht … und jetzt auf einmal das!
      Könnte mir vorstellen, dass es alles die selbe Ursache hat, kenne mich aber zu wenig aus.
      Wer kann mir da bitte helfen?
      Wenn ich Infos noch nachlegen soll, dann bitte ansagen.
      Danke im Voraus
      Grüße Plasma
      • Jey Cee
        Seit Wochen keine Änderung, auch kein Update?
        Raspberry Pi als host und nur eine SD Karte als Speichermedium?
        Dann könnte die SD Karte defekt sein.
        Gesendet von meinem m8 mit Tapatalk
        • apollon77
          apollon77 last edited by
          Wäre auch mein Tip, da scheint es ein File erwischt zu haben das jetzt "plötzlich" einen Fehler hat.
          Wenn DU also nichts gemacht hast dann "Bit gekippt" … SD karte prüfen/ersetzen
          • Plasmachef
            Herzlichen Dank für den Tipp!
            Er war Gold wert!
            Die Karte hat tatsächlich einen Treffer.
            Ich habe eine Kopie davon gezogen, auf eine andere Karte gebracht und jetzt läuft das System wieder einwandfrei.
            … jedoch bleibt ein ungutes Gefühl, dass das System oder der ioBroker noch einen "versteckten" Fehler hat, den ich mit der Kopie rübergezogen habe.
            Gibt es die Möglichkeit alle Systemdateien vom PI und die des ioBrokers neu schreiben zu lassen?
            Nochmals danke sehr für eure Hilfe! 🙂
              tomfort last edited by
              Schau mal auf Youtube nach.
              81.0k
