    4. {Gelöst} Harmony Adapter uncaught exception: bind EADDRINUSE 0.0.0.0:5224[/cod
    • Dutchman
      Hi leuts,
      Habe soeben den Harmony adapter auf meinem dicker host installiert, leider meckert er und möchte nicht starten jemand eine idee was man damit anfangen könnte ?
      Auf meiner regulären VM-Ware läuft alles :
      host.iObroker	2018-06-21 10:40:00.902	info	Restart adapter system.adapter.harmony.0 because enabled
      host.iObroker	2018-06-21 10:40:00.902	error	instance system.adapter.harmony.0 terminated with code 0 (OK)
      Caught	2018-06-21 10:40:00.902	error	by controller[0]: port: 5224 }
      Caught	2018-06-21 10:40:00.902	error	by controller[0]: address: '0.0.0.0',
      Caught	2018-06-21 10:40:00.901	error	by controller[0]: syscall: 'bind',
      Caught	2018-06-21 10:40:00.901	error	by controller[0]: errno: 'EADDRINUSE',
      Caught	2018-06-21 10:40:00.901	error	by controller[0]: code: 'EADDRINUSE',
      Caught	2018-06-21 10:40:00.901	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
      Caught	2018-06-21 10:40:00.901	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:83:11)
      Caught	2018-06-21 10:40:00.901	error	by controller[0]: at _handle.lookup (dgram.js:219:18)
      Caught	2018-06-21 10:40:00.901	error	by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
      Caught	2018-06-21 10:40:00.901	error	by controller[0]: at Object.exports._errnoException (util.js:1020:11)
      Caught	2018-06-21 10:40:00.900	error	by controller[0]: { Error: bind EADDRINUSE 0.0.0.0:5224
      harmony.0	2018-06-21 10:40:00.887	info	terminating
      harmony.0	2018-06-21 10:40:00.887	error	at process._tickCallback (internal/process/next_tick.js:104:9)
      harmony.0	2018-06-21 10:40:00.887	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
      harmony.0	2018-06-21 10:40:00.887	error	at _handle.lookup (dgram.js:219:18)
      harmony.0	2018-06-21 10:40:00.887	error	at exports._exceptionWithHostPort (util.js:1043:20)
      harmony.0	2018-06-21 10:40:00.887	error	at Object.exports._errnoException (util.js:1020:11)
      harmony.0	2018-06-21 10:40:00.887	error	Error: bind EADDRINUSE 0.0.0.0:5224
      harmony.0	2018-06-21 10:40:00.887	error	uncaught exception: bind EADDRINUSE 0.0.0.0:5224
      • apollon77
        apollon77 last edited by
        Die Meldung heisst das ein anderer prozess auf Port 5224 auf dem Rechner schon läuft … Finde raus was es ist
        • Dutchman
          @apollon77:
          Die Meldung heisst das ein anderer prozess auf Port 5224 auf dem Rechner schon läuft … Finde raus was es ist `
          grr keiner meiner dicker container belegt diesen port aber auf dem NAS ist er im gebrauch … mal schauen ob es irgendein NAS service ist :
          xx@xxr:~$ netstat -a | grep 522
          udp        0      0 0.0.0.0:5224            0.0.0.0:*
          • Dutchman
            gefunden : Plesk license abfragen …. grmbl, danke
            Edit : grmbl hatte nichts mit plesk zu tun sondern Homebridge.
            Hatte dort das harmony Plugin installiert logisch das der Port belegt war
            81.0k
