    4. [Gelöst] Probleme in Java Script nach Update History Adapter auf Ver. 1.84
      aftershowman last edited by
      bei mir haben "Send to" im Java Script nicht mehr funktioniert.
      Mit der Version 1.74 vom History Adapter hat noch alles funktiniert.
      Bin dann zurück auf 1.74 und alles ging wieder
      Hier die log Messages:
      history.0	2018-07-02 18:44:10.282	error	message messagebox.system.adapter.history.0 [object Object] Cannot read property 'id' of undefined
      history.0	2018-07-02 18:44:10.244	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      history.0	2018-07-02 18:44:10.244	error	at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
      history.0	2018-07-02 18:44:10.244	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:233:12)
      history.0	2018-07-02 18:44:10.244	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:275:10)
      history.0	2018-07-02 18:44:10.244	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
      history.0	2018-07-02 18:44:10.244	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
      history.0	2018-07-02 18:44:10.244	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3398:41)
      history.0	2018-07-02 18:44:10.244	error	at Object.message (/opt/iobroker/node_modules/iobroker.history/history.js:146:9)
      history.0	2018-07-02 18:44:10.244	error	at processMessage (/opt/iobroker/node_modules/iobroker.history/history.js:225:9)
      history.0	2018-07-02 18:44:10.244	error	at storeState (/opt/iobroker/node_modules/iobroker.history/history.js:994:82)
      history.0	2018-07-02 18:44:10.244	error	TypeError: Cannot read property 'id' of undefined</anonymous></anonymous>
      Hier der Code, der die Fehler verursacht:
      Was mach ich falsch?
      sendTo ("history.0", "storeState", {id: ObjEinspeisung5min, state: {
      "val": mytempVar,
      "ack": 1,
      "ts": new Date(JahrAkt + "." + MonatAkt + "." + TagAkt + " " + StundeAkt + ":" + MinuteAkt + ":00").getTime(),
      "q": 0
      Grüße, Frank
      Edit by Dutchman : Naestes mal in code tags bitte !
      • apollon77
        apollon77 last edited by
        Schaue ich mir zeitnah an. Legst du es bitte als GitHub issue noch an?! Danke
        Gesendet vom Handy …
        • apollon77
          Bitte 1.8.5 vo Github testen. Fehler sollte weg sein.Bitte um Rückmeldung. Danke
          Ingo
            HAllo,
            Danke für die schnelle Bearbeitung.
            Leider hab ich keien Ahnung wie ich eine Version von GitHub installieren soll.
            Ich mache die updates auschliesslich über den dan IOBroker Admin.
            Bräuchte also ne Anleitung, oder muß warten bis die Version über den IOBroker Admin angeboten wird.
            Sorry.
            Tolles Tool, möchte ich an dieser Stelle einmal loswerden.
            Grüße, Frank
              issue auf GitHub angelegt
              • Stabilostick
                Stabilostick last edited by
                Von Github installieren geht z.B. so:
                Ist dann die Neueste, also gerade eben 1.8.5.
                • apollon77
                  Update vom GitHub installieren: Admin - Adapter - oben auf das Icon "Custom-Install" (Github Symbol) klicken, dort aus der Liste history wählen. Installieren. Dann History-Instanz neu starten.
                  Ab morgen ists im Latest-Repository
                  Edit: Danke Stabilostick, ein Bild sagt mehr als tausend Worte 🙂
                    habe das Update auf Version History 1.85.
                    "Send to" funktioniert wieder.
                    Super Danke.
                    !!!! Super Support.
                    Grüße, Frank
                    • apollon77
                      Danke. Setzt du den Thread Titel im ersten Post bitte noch auf „gelöst“?!
                      81.0k
