    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Web
    Web
    • aurodionov
      aurodionov last edited by
      Продолжаю бороться с нескладушками. При установке виз падает в ошибку, оказалось не ставится web
      root@SmartHome:/opt/iobroker# iobroker install web
      ! /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:77
      if (arr.rows[id].value.common.enabled) {
      TypeError: Cannot read property 'enabled' of undefined
      at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:77:54)
      at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
      at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
      at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
      at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
      at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
      root@SmartHome:/opt/iobroker#</anonymous></anonymous></anonymous>
      root@SmartHome:/opt/iobroker# iobroker add web
      • E
        electric last edited by
        Текущая версия 1.4.6.
        Не устанавливается ни через админку ни через консоль.
        В лог сыплет ошибки:
        ! npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json npm ERR! registry error parsing json !
        В админке один раз и выходит из установки с ошибкой.
        update: починили))
          dimonchik88 last edited by
          Если в Лог такая ошибка:
          host.raspberrypi instance system.adapter.web.0 terminated with code 1 ()
          то удаляем через командную строку:
          ****cd /opt/iobroker
          ./iobroker del web****
          и после этого устанавливаем заново через графику или
          ./iobroker add web
