    4. Gyp ERR! build error
    • caravandriver
      caravandriver last edited by Negalein
      Ich habe auf einem docker Container iobroker installiert. Ich erhalte aber bei vielen Modulen diese gyp ERR. Woran liegt das?
      make: Leaving directory '/opt/iobroker/node_modules/utf-8-validate/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack at emitTwo (events.js:126:13)
      gyp ERR! stack at ChildProcess.emit (events.js:214:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
      gyp ERR! System Linux 3.10.102
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
      gyp ERR! node -v v8.11.3
      gyp ERR! node-gyp -v v3.7.0
      gyp ERR! not ok
      npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
      iobroker.mobile@0.4.11
      added 1 package from 1 contributor and audited 3065 packages in 98.916s
      found 27 vulnerabilities (19 low, 8 high)
      run `npm audit fix` to fix them, or `npm audit` for details
      DONE iobroker.mobile
      npm WARN deprecated bcrypt@1.0.3: bcrypt < v2.0.0 is susceptible to bcrypt wrap-around bug. Upgrade to bcrypt
      = v2.0.0 for improved sup
      port for newer bcrypt hashes
      npm WARN deprecated i18next-client@1.10.3: you can use npm instal
      • apollon77
        apollon77 last edited by
        Das Log mus snoch länger sein. Bitte vollständig posten. Da fehlt das relevante
        Am Ende ist das eine Abhängigkeit vom js.controller denke ich die aber optional ist
        Damit zwei optionen: Rausfinden was zu fixen ist (meist fehlt irgendein Linux paket oder Header-Files) oder ignorieren und damit leben 🙂
        • smartboart
          smartboart last edited by
          Hast du herausgefunden was das Problem war?
          • BBTown
            BBTown @smartboart last edited by
            @smartboart in einem anderen Thread gab es einen Hinweis, dass die GYP Error Meldungen womöglich etwas mit einer "Python Installation" zu tun haben könnten??!!
            • smartboart
              Danke für den Hinweis..
              apt-get install python-dev ergab bei mir nur das schon alles aktuell ist....
              gyp err
