    4. States ohne Object
    States ohne Object
      paul53 last edited by
      Es gibt offenbar States in der States DB (states.json), zu denen kein Objekt gehört. Das sollte meiner Meinung nach nicht sein. Folgendes Skript liefert Warnungs-Logs: Object "…" does not exist
      const allDp = $('[id=*]');
      allDp.each(function(id, i) {
          if(!getObject(id)) log(id);
      bei folgenden States (Datenpunkte sind es nicht, da die Objekt-Eigenschaften fehlen):
      ! 10:06:00.442 [info] javascript.0 script.js.common.Tests: hm-rpc.0.CENTRAL.PONG 10:06:00.442 [info] javascript.0 script.js.common.Tests: system.adapter.admin.0.inputCount 10:06:00.442 [info] javascript.0 script.js.common.Tests: system.adapter.admin.0.outputCount 10:06:00.442 [info] javascript.0 script.js.common.Tests: system.adapter.email.0.inputCount 10:06:00.442 [info] javascript.0 script.js.common.Tests: system.adapter.email.0.outputCount 10:06:00.443 [info] javascript.0 script.js.common.Tests: system.adapter.history.0.inputCount 10:06:00.443 [info] javascript.0 script.js.common.Tests: system.adapter.history.0.outputCount 10:06:00.443 [info] javascript.0 script.js.common.Tests: system.adapter.hm-rpc.0.inputCount 10:06:00.444 [info] javascript.0 script.js.common.Tests: system.adapter.hm-rpc.0.outputCount 10:06:00.444 [info] javascript.0 script.js.common.Tests: system.adapter.javascript.0.inputCount 10:06:00.444 [info] javascript.0 script.js.common.Tests: system.adapter.javascript.0.outputCount 10:06:00.444 [info] javascript.0 script.js.common.Tests: system.adapter.vis.0.alive 10:06:00.444 [info] javascript.0 script.js.common.Tests: system.adapter.vis.0.connected 10:06:00.445 [info] javascript.0 script.js.common.Tests: system.adapter.vis.0.inputCount 10:06:00.445 [info] javascript.0 script.js.common.Tests: system.adapter.vis.0.memHeapTotal 10:06:00.445 [info] javascript.0 script.js.common.Tests: system.adapter.vis.0.memHeapUsed 10:06:00.445 [info] javascript.0 script.js.common.Tests: system.adapter.vis.0.memRss 10:06:00.446 [info] javascript.0 script.js.common.Tests: system.adapter.vis.0.outputCount 10:06:00.446 [info] javascript.0 script.js.common.Tests: system.adapter.vis.0.uptime 10:06:00.446 [info] javascript.0 script.js.common.Tests: web.0.connected !
      • apollon77
        apollon77 last edited by
        korrekt. Das ist auch letztens als wir Daten zu den neuen verbotenen zeichen gesammelt haben aufgefallen.
        Die ganzen Objekte unter system.adapter.X sollten per https://github.com/ioBroker/ioBroker.js … issues/229 gefixt werden.
        Den Rest muss man bei den Adatern checken wo die herkommen und ggf dort Issues anlegen das die Objekte dort korrekt angelegt werden.
        Zusätzlich gibt es https://github.com/ioBroker/ioBroker.js ... issues/230 für die saubere zukünftige lösung.
        Wurde schon teilweise diskutiert, habe gerade mal die Issues dazu angelegt 🙂
