    4. [Gelöst]Neu Instalation: Aber admin Restart All 10-20 Sec
      doc hardi last edited by
      Hallo ich habe heute erst den iobroker Neu installiert auf ein neun MicroSD karte,
      Verwende habe ich folgende image vom 14.04.2018 für den Raspberry Pi 3 B,
      Nun aber Geht aber nux das admincenter start alle 10 - 30 sec neu, ich musste den iobroker neu aufsetzen weil er auf der alten sd nicht mehr start wollte nach den lest Updates
      Hier die Log:
      ! 2018-07-26 14:37:49.497 - [32minfo[39m: iobroker _restart
      ! 2018-07-26 14:37:50.143 - [32minfo[39m: iobroker Starting node restart.js
      ! 2018-07-26 14:37:50.175 - [32minfo[39m: iobroker exit 0
      ! 2018-07-26 14:37:50.533 - [32minfo[39m: host.ioBroker received SIGTERM
      ! 2018-07-26 14:37:51.928 - [32minfo[39m: admin.0 States connected to redis: 127.0.0.1:6379
      ! 2018-07-26 14:37:52.046 - [32minfo[39m: admin.0 starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.admin, node: v8.11.1
      ! 2018-07-26 14:37:52.072 - [32minfo[39m: admin.0 requesting all states
      ! 2018-07-26 14:37:52.075 - [32minfo[39m: admin.0 requesting all objects
      ! 2018-07-26 14:37:52.077 - [32minfo[39m: admin.0 Request actual repository…
      ! 2018-07-26 14:37:52.466 - [32minfo[39m: admin.0 received all states
      ! 2018-07-26 14:37:53.791 - [32minfo[39m: admin.0 received all objects
      ! 2018-07-26 14:37:53.945 - [32minfo[39m: admin.0 http server listening on port 8081
      ! 2018-07-26 14:37:53.946 - [32minfo[39m: admin.0 Use link "http://localhost:8081" to configure.
      ! 2018-07-26 14:37:53.993 - [32minfo[39m: host.ioBroker Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      ! 2018-07-26 14:37:55.191 - [32minfo[39m: admin.0 Repository received successfully.
      ! 2018-07-26 14:37:55.541 - [32minfo[39m: host.ioBroker received SIGTERM
      ! 2018-07-26 14:37:59.629 - [32minfo[39m: host.ioBroker force terminating
      ! 2018-07-26 14:37:59.630 - [32minfo[39m: Adapter admin still running
      ! 2018-07-26 14:38:07.072 - [32minfo[39m: host.ioBroker iobroker.js-controller version 1.4.0 js-controller starting
      ! 2018-07-26 14:38:07.080 - [32minfo[39m: host.ioBroker Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      ! 2018-07-26 14:38:07.080 - [32minfo[39m: host.ioBroker hostname: ioBroker, node: v8.11.1
      ! 2018-07-26 14:38:07.085 - [32minfo[39m: host.ioBroker ip addresses: 192.168.178.20 fe80::4071:a465:1858:3b27
      ! 2018-07-26 14:38:07.379 - [32minfo[39m: host.ioBroker inMem-objects listening on port 9001
      ! 2018-07-26 14:38:07.399 - [32minfo[39m: host.ioBroker InMemoryDB connected
      ! 2018-07-26 14:38:07.417 - [32minfo[39m: host.ioBroker 13 instances found
      ! 2018-07-26 14:38:07.435 - [32minfo[39m: host.ioBroker starting 8 instances
      ! 2018-07-26 14:38:07.483 - [32minfo[39m: host.ioBroker instance system.adapter.admin.0 started with pid 3683
      ! 2018-07-26 14:38:07.501 - [32minfo[39m: host.ioBroker States connected to redis: 127.0.0.1:6379
      ! 2018-07-26 14:38:07.509 - [31merror[39m: uncaught exception: Cannot convert undefined or null to object
      ! 2018-07-26 14:38:07.512 - [31merror[39m: TypeError: Cannot convert undefined or null to object
      ! at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:863:9)
      ! at runCallback (timers.js:798:20)
      ! at tryOnImmediate (timers.js:752:5)
      ! at processImmediate [as _immediateCallback] (timers.js:729:5)
      ! 2018-07-26 14:38:07.520 - [32minfo[39m: iobroker _restart
      ! 2018-07-26 14:38:08.171 - [32minfo[39m: iobroker Starting node restart.js
      ! 2018-07-26 14:38:08.204 - [32minfo[39m: iobroker exit 0
      ! 2018-07-26 14:38:08.572 - [32minfo[39m: host.ioBroker received SIGTERM
      ! 2018-07-26 14:38:10.008 - [32minfo[39m: host.ioBroker instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      ! 2018-07-26 14:38:10.009 - [32minfo[39m: host.ioBroker All instances are stopped.
      ! 2018-07-26 14:38:10.275 - [32minfo[39m: host.ioBroker terminated
      ! 2018-07-26 14:38:15.102 - [32minfo[39m: host.ioBroker iobroker.js-controller version 1.4.0 js-controller starting
      ! 2018-07-26 14:38:15.109 - [32minfo[39m: host.ioBroker Copyright © 2014-2018 bluefox, 2014 hobbyquaker
      ! 2018-07-26 14:38:15.110 - [32minfo[39m: host.ioBroker hostname: ioBroker, node: v8.11.1
      ! 2018-07-26 14:38:15.115 - [32minfo[39m: host.ioBroker ip addresses: 192.168.178.20 fe80::4071:a465:1858:3b27
      ! 2018-07-26 14:38:15.408 - [32minfo[39m: host.ioBroker inMem-objects listening on port 9001
      ! 2018-07-26 14:38:15.428 - [32minfo[39m: host.ioBroker InMemoryDB connected
      ! 2018-07-26 14:38:15.446 - [32minfo[39m: host.ioBroker 13 instances found
      ! 2018-07-26 14:38:15.465 - [32minfo[39m: host.ioBroker starting 8 instances
      ! 2018-07-26 14:38:15.512 - [32minfo[39m: host.ioBroker instance system.adapter.admin.0 started with pid 3764
      ! 2018-07-26 14:38:15.530 - [32minfo[39m: host.ioBroker States connected to redis: 127.0.0.1:6379
      ! 2018-07-26 14:38:15.538 - [31merror[39m: uncaught exception: Cannot convert undefined or null to object
      ! 2018-07-26 14:38:15.542 - [31merror[39m: TypeError: Cannot convert undefined or null to object
      ! 2018-07-26 14:38:15.550 - [32minfo[39m: iobroker _restart [/spoiler]
      Ich Wurde mich freuen wen jemand weis wie ich den iobroker weider zum laufen bekomme
      mfg doc hardi
      • Stabilostick
        Stabilostick last edited by
        Hmm, in der Version 1.4.0 der Datei /opt/iobroker/node_modules/iobroker.js-controller/controller.js habe ich in Zeile 863 eine Leerzeile.
        Was steht da bei Dir an der Stelle? So etwas wie
                if (oldObj && oldObj.native.hardware && oldObj.native.hardware.networkInterfaces) {
                    newObj.native.hardware.networkInterfaces = oldObj.native.hardware.networkInterfaces;
        --> das ist bei mir die Zeile 863 -> Leerzeile hier
                if (oldObj) {
                    delete oldObj.cmd;
                    delete oldObj.from;
                    delete oldObj.ts;
                    delete oldObj.acl;
        Hattest Du gleich nach der Neuinstallation ein Backup der alten Installation eingespielt?
        • wendy2702
          wendy2702 last edited by
          Das "read me" hast du befolgt –> http://www.iobroker.net/docu/?page_id=8038&lang=de ???
            Hallo danke für deine hilfe
            nach dem ich
            sudo iobroker stop
            sudo npm install iobroker.js-controller --production
            sudo iobroker start
            Gemacht habe geht es weider anscheide Ware bei der Image ein Fehler in der iobroker.js-controller vorhanden
            danke für alles
