    4. ERLEDIGT Adapter-Problem. Bitte um Hilfe
      as15 last edited by
      mein Slave Raspberry läuft nicht rund. Angeschlossen ist ein Bluetooth Stick und ein Zigbee Stick.
      Der Ble-Adapter startet regelmäßig neu, da dieser abstürtzt.
      Der Zigbee-Adapter startet gar nicht erst.
      Kann mir jemand helfen:
      Log Zigbee:````
      host.WohnzimmerBalkon 2018-08-05 12:48:00.724 error instance system.adapter.zigbee.0 terminated with code 1 ()
      Caught 2018-08-05 12:48:00.722 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/cc-znp/node_modules/serialport/lib/bindings/auto-detect.js:16:22)
      Caught 2018-08-05 12:48:00.722 error by controller[0]: at require (internal/module.js:20:19)
      Caught 2018-08-05 12:48:00.721 error by controller[0]: at Module.require (module.js:504:17)
      Caught 2018-08-05 12:48:00.720 error by controller[0]: at Function.Module._load (module.js:445:3)
      Caught 2018-08-05 12:48:00.719 error by controller[0]: at tryModuleLoad (module.js:453:12)
      Caught 2018-08-05 12:48:00.718 error by controller[0]: at Module.load (module.js:494:32)
      Caught 2018-08-05 12:48:00.718 error by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      Caught 2018-08-05 12:48:00.717 error by controller[0]: at Module._compile (module.js:577:32)
      Caught 2018-08-05 12:48:00.716 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/cc-znp/node_modules/serialport/lib/bindings/linux.js:2:36)
      Caught 2018-08-05 12:48:00.715 error by controller[0]: at bindings (/opt/iobroker/node_modules/cc-znp/node_modules/bindings/bindings.js:93:9)
      Caught 2018-08-05 12:48:00.715 error by controller[0]: → /opt/iobroker/node_modules/cc-znp/node_modules/serialport/compiled/6.14.3/linux/arm/serialport.node
      Caught 2018-08-05 12:48:00.714 error by controller[0]: → /opt/iobroker/node_modules/cc-znp/node_modules/serialport/build/default/serialport.node
      Caught 2018-08-05 12:48:00.714 error by controller[0]: → /opt/iobroker/node_modules/cc-znp/node_modules/serialport/Release/serialport.node
      Caught 2018-08-05 12:48:00.713 error by controller[0]: → /opt/iobroker/node_modules/cc-znp/node_modules/serialport/out/Release/serialport.node
      Caught 2018-08-05 12:48:00.712 error by controller[0]: → /opt/iobroker/node_modules/cc-znp/node_modules/serialport/Debug/serialport.node
      Caught 2018-08-05 12:48:00.712 error by controller[0]: → /opt/iobroker/node_modules/cc-znp/node_modules/serialport/out/Debug/serialport.node
      Caught 2018-08-05 12:48:00.711 error by controller[0]: → /opt/iobroker/node_modules/cc-znp/node_modules/serialport/build/Release/serialport.node
      Caught 2018-08-05 12:48:00.711 error by controller[0]: → /opt/iobroker/node_modules/cc-znp/node_modules/serialport/build/Debug/serialport.node
      Caught 2018-08-05 12:48:00.710 error by controller[0]: → /opt/iobroker/node_modules/cc-znp/node_modules/serialport/build/serialport.node
      Caught 2018-08-05 12:48:00.709 error by controller[0]: Error: Could not locate the bindings file. Tried:
      Caught 2018-08-05 12:48:00.708 error by controller[0]: ^
      Caught 2018-08-05 12:48:00.708 error by controller[0]: throw err
      Caught 2018-08-05 12:48:00.706 error by controller[0]: /opt/iobroker/node_modules/cc-znp/node_modules/bindings/bindings.js:96</anonymous></anonymous>
      Log BLE:````
      ble.0	2018-08-05 12:49:06.788	info	starting scan for services ["fe95"]
      ble.0	2018-08-05 12:49:06.746	info	monitored services: fe95
      ble.0	2018-08-05 12:49:06.746	info	enabled plugins: mi-flora, _default
      ble.0	2018-08-05 12:49:06.744	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
      ble.0	2018-08-05 12:49:06.736	info	starting. Version 0.5.2 in /opt/iobroker/node_modules/iobroker.ble, node: v6.14.3
      host.WohnzimmerBalkon	2018-08-05 12:49:04.056	info	instance system.adapter.zigbee.0 started with pid 2069
      host.WohnzimmerBalkon	2018-08-05 12:49:01.150	info	instance system.adapter.ble.0 started with pid 1982
      host.WohnzimmerBalkon	2018-08-05 12:49:00.129	info	Restart adapter system.adapter.ble.0 because enabled
      host.WohnzimmerBalkon	2018-08-05 12:49:00.128	error	instance system.adapter.ble.0 terminated with code 156 ()
      Vielen Dank euch!
      PS:
      node -v v6.14.3
      nodejs -v v6.14.3
      npm -v 3.10.10
      EDIT: Update auf node 8 und npm 4 hats gebracht…
      • AlCalzone
        @as15:
        Du hast es wohl geschafft, den BLE-Adapter mit einem automatischen Neustart (Code 156) zu versehen, den er auch brav durchführt.
        viewtopic.php?t=7349
          as15 last edited by
          Genau das war der "zweite" Fehler…
          Top Danke euch!
