    4. Node: Adapter lassen sich nicht mehr updaten
      pix last edited by
      die heutigen Versuche, die neuen Versionen von Text to Speech, MQTT und VIS hq-Widgets Style zu installieren schlugen fehl. 😢
      2015-11-15 12:12:00.907 - info: iobroker upgrade sayit
      2015-11-15 12:12:01.598 - info: iobroker npm install iobroker.sayit --production --prefix "/Users/pix/Documents/iobroker" (System call)
      2015-11-15 12:12:14.958 - info: iobroker npm
      2015-11-15 12:12:14.959 - info: iobroker ERR! Darwin 15.0.0
      2015-11-15 12:12:14.960 - info: iobroker npm ERR!
      2015-11-15 12:12:14.960 - info: iobroker argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.sayit" "--production" "--prefix" "/Users/pix/Documents/iobroker"
      2015-11-15 12:12:14.961 - info: iobroker npm ERR! node v5.0.0npm
      2015-11-15 12:12:14.961 - info: iobroker ERR! npm v3.3.6
      2015-11-15 12:12:14.963 - info: iobroker npm
      2015-11-15 12:12:14.964 - info: iobroker ERR! Cannot read property 'localeCompare' of undefinednpm ERR!
      npm ERR!
      2015-11-15 12:12:14.964 - info: iobroker If you need help, you may report this error at:npm ERR! <https: github.com/npm/issues="">
      ! 2015-11-15 12:12:14.985 - info: iobroker
      2015-11-15 12:12:14.986 - info: iobroker npm ERR! Please include the following file with any support request:
      2015-11-15 12:12:14.986 - info: iobroker npm ERR! /Users/pix/Documents/npm-debug.log
      2015-11-15 12:12:15.004 - error: iobroker host.MacMini-Ethernet.fritz.box Cannot install iobroker.sayit: 1
      2015-11-15 12:12:15.012 - info: iobroker exit 25</https:>
      2015-11-15 12:10:41.298 - info: iobroker upgrade mqtt
      2015-11-15 12:10:41.901 - info: iobroker npm install iobroker.mqtt --production --prefix "/Users/pix/Documents/iobroker" (System call)
      2015-11-15 12:10:57.939 - info: iobroker npm
      2015-11-15 12:10:57.940 - info: iobroker ERR!
      2015-11-15 12:10:57.940 - info: iobroker Darwin 15.0.0
      2015-11-15 12:10:57.941 - info: iobroker npm ERR! argv
      2015-11-15 12:10:57.942 - info: iobroker "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.mqtt" "--production" "--prefix" "/Users/pix/Documents/iobroker"
      2015-11-15 12:10:57.942 - info: iobroker npm ERR!
      2015-11-15 12:10:57.943 - info: iobroker node v5.0.0npm ERR! npm v3.3.6
      ! 2015-11-15 12:10:57.946 - info: iobroker
      2015-11-15 12:10:57.946 - info: iobroker npm ERR! Cannot read property 'localeCompare' of undefined
      2015-11-15 12:10:57.947 - info: iobroker npm ERR! npm ERR! If you need help, you may report this error at:
      ! 2015-11-15 12:10:57.985 - info: iobroker
      2015-11-15 12:10:57.986 - info: iobroker npm ERR! Please include the following file with any support request:
      2015-11-15 12:10:57.986 - info: iobroker npm ERR! /Users/pix/Documents/npm-debug.log
      2015-11-15 12:10:58.014 - error: iobroker host.MacMini-Ethernet.fritz.box Cannot install iobroker.mqtt: 1
      2015-11-15 12:10:58.025 - info: iobroker exit 25</https:>
      2015-11-15 12:07:50.053  - info: iobroker upgrade vis-hqwidgets
      2015-11-15 12:07:51.093  - info: iobroker npm install iobroker.vis-hqwidgets --production --prefix "/Users/pix/Documents/iobroker" (System call)
      2015-11-15 12:08:25.644  - info: iobroker npm
      2015-11-15 12:08:25.644  - info: iobroker  ERR! Darwin 15.0.0
      2015-11-15 12:08:25.645  - info: iobroker npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.vis-hqwidgets" "--production" "--prefix" "/Users/pix/Documents/iobroker"
      2015-11-15 12:08:25.650  - info: iobroker  ERR!     <https: github.com/npm/issues="">2015-11-15 12:08:25.698  - info: iobroker
      2015-11-15 12:08:25.698  - info: iobroker npm ERR! Please include the following file with any support request:npm ERR!
      2015-11-15 12:08:25.698  - info: iobroker      /Users/pix/Documents/npm-debug.log
      2015-11-15 12:08:25.718  - error: iobroker host.MacMini-Ethernet.fritz.box Cannot install iobroker.vis-hqwidgets: 1
      2015-11-15 12:08:25.732  - info: iobroker exit 25
      2015-11-15 12:08:25.646  - info: iobroker npm ERR! node v5.0.0npm ERR! npm  v3.3.6
      2015-11-15 12:08:25.648  - info: iobroker npm ERR!
      2015-11-15 12:08:25.648  - info: iobroker  Cannot read property 'localeCompare' of undefinednpm ERR!
      npm</https:>
      Ich vermute, es liegt an einem Update von Node auf 5.0\. Ich hatte hier darüber gelesen:
      [http://forum.iobroker.net/viewtopic.php … 702#p14510](http://forum.iobroker.net/viewtopic.php?f=8&amp;t=1702#p14510)
      Kann jemand helfen?
      Pix
      Edit: Sehe gerade, dass ich in das falsche Forum gerutscht bin. Bitte in "Fehler" verschieben, danke!
      • sissiwup
        sissiwup last edited by
        bei mir liegt es meist am io.js-controller.
        Installier den einfach nochmal drüber, dann klappts auch mit den anderen.
        Hatte auch arge Probleme nach Update auf 0.7.15.
          pix last edited by
          Hallo sissiwup,
          danke für den Hinweis. Habe iobroker gestoppt und mit
          npm install iobroker.js-controller
          ````versucht, den Controller drüber zuinstallieren - ohne Erfolg.
          ./iobroker Upgrade
          Nach````
          pgrep -f '^io.*' | xargs kill -KILL
          ````lief zumindest der Ladebalken für den Controller auf npm. Leider bricht auch das wieder ab.
          npm ERR! Darwin 15.0.0
          npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller"
          npm ERR! npm v3.3.6
          npm ERR!
          npm ERR! /Users/pix/Documents/iobroker/npm-debug.log</https:>
          Jetzt weiss ich auch nicht mehr weiter. :roll:
          Pix
            pix last edited by
            Hier mal das ganze npm-debug.log:
            261_npm-debug.log
              Pman last edited by
              Ich wollte mir schon anschließen, da ich massig Fehler bei "iobroker update" hatte, lag aber nur daran dass der Pi ohne Internet war :lol:
              Habe ein Jessie System mit node5 und neustem js-controller, keine Probleme. Also nur an node5 kann es nicht liegen.
                pix last edited by
                Ich werd verrückt:
                Jetzt startet das System nicht mehr.
                Hab alle io-Prozesse beendet und ./iobroker start IOBROKER neugestartet
                Jetzt werden nur der js-controller, admin.0 und manchmal der DWD gestartet, dann wieder beendet und wieder gestartet.
                Marker - 15.11.2015, 20:28:25
                2015-11-15 20:28:31.875 - info: host.MacMini-Ethernet.fritz.box ioBroker.js-controller version 0.7.15 js-controller starting
                2015-11-15 20:28:31.879 - info: host.MacMini-Ethernet.fritz.box Copyright (c) 2014-2015 bluefox, hobbyquaker
                2015-11-15 20:28:31.879 - info: host.MacMini-Ethernet.fritz.box hostname: MacMini-Ethernet.fritz.box
                2015-11-15 20:28:31.880 - info: host.MacMini-Ethernet.fritz.box ip addresses: fe80::ca2a:14ff:fe58:bcd 192.168.178.38 fe80::ac0d:2eeb:3442:5285 fd26:78a9:c46b:bf48:ac0d:2eeb:3442:5285
                2015-11-15 20:28:33.307 - info: inMem-states listening on port 9000
                2015-11-15 20:28:33.580 - info: inMem-objects listening on port 9001
                2015-11-15 20:28:33.584 - info: host.MacMini-Ethernet.fritz.box InMemoryDB connected
                2015-11-15 20:28:33.612 - info: host.MacMini-Ethernet.fritz.box 41 instances found
                2015-11-15 20:28:33.613 - info: host.MacMini-Ethernet.fritz.box starting 31 instances
                2015-11-15 20:28:34.423 - info: admin.0 starting. Version 0.6.6 in /Users/pix/Documents/iobroker/node_modules/iobroker.admin
                2015-11-15 20:28:34.449 - info: admin.0 requesting all states
                2015-11-15 20:28:34.450 - info: admin.0 requesting all objects
                2015-11-15 20:28:34.450 - info: admin.0 Request actual repository...
                2015-11-15 20:28:34.452 - info: admin.0 http server listening on port 8081
                2015-11-15 20:28:34.452 - info: admin.0 Use link "http://localhost:8081" to configure.
                2015-11-15 20:28:35.550 - info: admin.0 received all states
                2015-11-15 20:28:36.596 - info: admin.0 received all objects
                2015-11-15 20:28:36.686 - info: host.MacMini-Ethernet.fritz.box Update repository "online" under "https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json"
                2015-11-15 20:28:37.681 - info: host.MacMini-Ethernet.fritz.box instance scheduled system.adapter.dwd.0 3 * * * *
                2015-11-15 20:28:37.686 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.dwd.0 started with pid 2832
                2015-11-15 20:28:38.565 - info: dwd.0 starting. Version 1.0.0 in /Users/pix/Documents/iobroker/node_modules/iobroker.dwd
                2015-11-15 20:28:39.177 - info: dwd.0 getFile Z_CAP_C_EDZW_20151113235538_PVW_WWMS51_MXXX.xml
                2015-11-15 20:28:40.272 - info: dwd.0 getFile Z_CAP_C_EDZW_20151114232050_PVW_WWMS51_MXXX.xml
                2015-11-15 20:28:40.596 - warn: host.MacMini-Ethernet.fritz.box warning: Following packages cannot be read: example
                2015-11-15 20:28:40.611 - info: admin.0 Repository received successfully.
                2015-11-15 20:28:40.661 - error: uncaught exception: ENOENT: no such file or directory, scandir '/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/../node_modules'
                2015-11-15 20:28:40.667 - info: admin.0 terminating http server on port 8081
                2015-11-15 20:28:40.664 - error: Error: ENOENT: no such file or directory, scandir '/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/../node_modules'
                at Error (native)
                at Object.fs.readdirSync (fs.js:856:18)
                at Object.getInstalledInfo (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/tools.js:214:15)
                at /Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/controller.js:621:40
                at ObjectsInMemServer._applyView (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2204:23)
                at ObjectsInMemServer.getObjectView (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2226:22)
                at ObjectsInMemServer. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2218:33)
                at checkObjectRights (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:491:16)
                at ObjectsInMemServer.getObjectView (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2214:13)
                at processMessage (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/controller.js:620:25)
                2015-11-15 20:28:40.665 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0
                2015-11-15 20:28:40.666 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0 killing pid 2831
                2015-11-15 20:28:40.666 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0
                2015-11-15 20:28:40.667 - info: host.MacMini-Ethernet.fritz.box stopInstance canceled schedule system.adapter.dwd.0
                2015-11-15 20:28:40.667 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0
                2015-11-15 20:28:40.667 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0 not running
                2015-11-15 20:28:40.667 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0
                2015-11-15 20:28:40.667 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0 not running
                2015-11-15 20:28:40.667 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0
                2015-11-15 20:28:40.668 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0 not running
                2015-11-15 20:28:40.668 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0
                2015-11-15 20:28:40.668 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0 not running
                2015-11-15 20:28:40.668 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1
                2015-11-15 20:28:40.668 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1 not running
                2015-11-15 20:28:40.668 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0
                2015-11-15 20:28:40.668 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0 not scheduled
                2015-11-15 20:28:40.668 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0
                2015-11-15 20:28:40.668 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0 not running
                2015-11-15 20:28:40.668 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1
                2015-11-15 20:28:40.668 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1 not running
                2015-11-15 20:28:40.668 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2
                2015-11-15 20:28:40.669 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2 not running
                2015-11-15 20:28:40.669 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0
                2015-11-15 20:28:40.669 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0 not running
                2015-11-15 20:28:40.669 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0
                2015-11-15 20:28:40.669 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0 not running
                2015-11-15 20:28:40.669 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0
                2015-11-15 20:28:40.669 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0 not running
                2015-11-15 20:28:40.669 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0
                2015-11-15 20:28:40.669 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0 not running
                2015-11-15 20:28:40.669 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0
                2015-11-15 20:28:40.669 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0 not running
                2015-11-15 20:28:40.669 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0
                2015-11-15 20:28:40.669 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0 not running
                2015-11-15 20:28:40.670 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0
                2015-11-15 20:28:40.670 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0 not running
                2015-11-15 20:28:40.670 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0
                2015-11-15 20:28:40.670 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0 not scheduled
                2015-11-15 20:28:40.670 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-bars.0
                2015-11-15 20:28:40.670 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-colorpicker.0
                2015-11-15 20:28:40.670 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-hqwidgets.0
                2015-11-15 20:28:40.671 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-metro.0
                2015-11-15 20:28:40.671 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis.0
                2015-11-15 20:28:40.671 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.mobile.0
                2015-11-15 20:28:40.671 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0
                2015-11-15 20:28:40.671 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0 not running
                2015-11-15 20:28:40.671 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0
                2015-11-15 20:28:40.671 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0 not running
                2015-11-15 20:28:40.671 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0
                2015-11-15 20:28:40.671 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0 not running
                2015-11-15 20:28:40.671 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-rgraph.0
                2015-11-15 20:28:40.671 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-timeandweather.0
                2015-11-15 20:28:40.671 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-fancyswitch.0
                2015-11-15 20:28:40.671 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-jqui-mfd.0
                2015-11-15 20:28:40.672 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0
                2015-11-15 20:28:40.672 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0 not running
                2015-11-15 20:28:40.672 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0
                2015-11-15 20:28:40.672 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0 not running
                2015-11-15 20:28:40.672 - info: iobroker _restart
                2015-11-15 20:28:40.893 - info: admin.0 terminating
                2015-11-15 20:28:40.920 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.admin.0 terminated with code 0 (OK)
                2015-11-15 20:28:41.089 - info: iobroker Starting node restart.js
                2015-11-15 20:28:41.096 - info: iobroker exit 0
                2015-11-15 20:28:41.366 - info: dwd.0 getFile Z_CAP_C_EDZW_20151115050306_PVW_WWMS52_MXXX.xml
                2015-11-15 20:28:41.434 - info: host.MacMini-Ethernet.fritz.box received SIGTERM
                2015-11-15 20:28:41.434 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0
                2015-11-15 20:28:41.434 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0 not running
                2015-11-15 20:28:41.434 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0
                2015-11-15 20:28:41.434 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0 not scheduled
                2015-11-15 20:28:41.435 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0
                2015-11-15 20:28:41.435 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0 not running
                2015-11-15 20:28:41.435 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0
                2015-11-15 20:28:41.435 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0 not running
                2015-11-15 20:28:41.435 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0
                2015-11-15 20:28:41.435 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0 not running
                2015-11-15 20:28:41.435 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0
                2015-11-15 20:28:41.435 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0 not running
                2015-11-15 20:28:41.435 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1
                2015-11-15 20:28:41.435 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1 not running
                2015-11-15 20:28:41.435 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0
                2015-11-15 20:28:41.435 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0 not scheduled
                2015-11-15 20:28:41.435 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0
                2015-11-15 20:28:41.436 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0 not running
                2015-11-15 20:28:41.436 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1
                2015-11-15 20:28:41.436 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1 not running
                2015-11-15 20:28:41.436 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2
                2015-11-15 20:28:41.436 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2 not running
                2015-11-15 20:28:41.436 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0
                2015-11-15 20:28:41.436 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0 not running
                2015-11-15 20:28:41.436 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0
                2015-11-15 20:28:41.436 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0 not running
                2015-11-15 20:28:41.436 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0
                2015-11-15 20:28:41.436 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0 not running
                2015-11-15 20:28:41.436 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0
                2015-11-15 20:28:41.436 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0 not running
                2015-11-15 20:28:41.437 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0
                2015-11-15 20:28:41.437 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0 not running
                2015-11-15 20:28:41.437 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0
                2015-11-15 20:28:41.437 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0 not running
                2015-11-15 20:28:41.437 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0
                2015-11-15 20:28:41.437 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0 not running
                2015-11-15 20:28:41.437 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0
                2015-11-15 20:28:41.437 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0 not scheduled
                2015-11-15 20:28:41.437 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-bars.0
                2015-11-15 20:28:41.437 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-colorpicker.0
                2015-11-15 20:28:41.437 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-hqwidgets.0
                2015-11-15 20:28:41.437 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-metro.0
                2015-11-15 20:28:41.437 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis.0
                2015-11-15 20:28:41.438 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.mobile.0
                2015-11-15 20:28:41.438 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0
                2015-11-15 20:28:41.438 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0 not running
                2015-11-15 20:28:41.438 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0
                2015-11-15 20:28:41.438 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0 not running
                2015-11-15 20:28:41.438 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0
                2015-11-15 20:28:41.438 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0 not running
                2015-11-15 20:28:41.438 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-rgraph.0
                2015-11-15 20:28:41.438 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-timeandweather.0
                2015-11-15 20:28:41.438 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-fancyswitch.0
                2015-11-15 20:28:41.439 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-jqui-mfd.0
                2015-11-15 20:28:41.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0
                2015-11-15 20:28:41.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0 not running
                2015-11-15 20:28:41.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0
                2015-11-15 20:28:41.441 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0 not running
                2015-11-15 20:28:42.439 - info: host.MacMini-Ethernet.fritz.box received SIGTERM
                2015-11-15 20:28:42.439 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0
                2015-11-15 20:28:42.439 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0 not running
                2015-11-15 20:28:42.439 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0
                2015-11-15 20:28:42.439 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0 not scheduled
                2015-11-15 20:28:42.439 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0
                2015-11-15 20:28:42.439 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0 not running
                2015-11-15 20:28:42.439 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0
                2015-11-15 20:28:42.439 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0 not running
                2015-11-15 20:28:42.439 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0
                2015-11-15 20:28:42.439 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0 not running
                2015-11-15 20:28:42.439 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0 not scheduled
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0
                2015-11-15 20:28:42.440 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0 not running
                2015-11-15 20:28:42.440 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0
                2015-11-15 20:28:42.441 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0 not running
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0
                2015-11-15 20:28:42.441 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0 not scheduled
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-bars.0
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-colorpicker.0
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-hqwidgets.0
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-metro.0
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis.0
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.mobile.0
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0
                2015-11-15 20:28:42.441 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0 not running
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0
                2015-11-15 20:28:42.441 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0 not running
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0
                2015-11-15 20:28:42.441 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0 not running
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-rgraph.0
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-timeandweather.0
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-fancyswitch.0
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-jqui-mfd.0
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0
                2015-11-15 20:28:42.441 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0 not running
                2015-11-15 20:28:42.441 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0
                2015-11-15 20:28:42.441 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0 not running
                2015-11-15 20:28:42.457 - info: dwd.0 getFile Z_CAP_C_EDZW_20151115180000_PVW_WWMS51_MXXX.xml
                2015-11-15 20:28:43.444 - info: host.MacMini-Ethernet.fritz.box received SIGTERM
                2015-11-15 20:28:43.444 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0
                2015-11-15 20:28:43.445 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0 not running
                2015-11-15 20:28:43.445 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0
                2015-11-15 20:28:43.445 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0 not scheduled
                2015-11-15 20:28:43.445 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0
                2015-11-15 20:28:43.445 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0 not running
                2015-11-15 20:28:43.445 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0
                2015-11-15 20:28:43.445 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0 not running
                2015-11-15 20:28:43.445 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0
                2015-11-15 20:28:43.445 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0 not running
                2015-11-15 20:28:43.445 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0
                2015-11-15 20:28:43.445 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0 not running
                2015-11-15 20:28:43.445 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1
                2015-11-15 20:28:43.446 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1 not running
                2015-11-15 20:28:43.446 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0
                2015-11-15 20:28:43.446 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0 not scheduled
                2015-11-15 20:28:43.446 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0
                2015-11-15 20:28:43.446 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0 not running
                2015-11-15 20:28:43.446 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1
                2015-11-15 20:28:43.446 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1 not running
                2015-11-15 20:28:43.446 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2
                2015-11-15 20:28:43.446 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2 not running
                2015-11-15 20:28:43.446 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0
                2015-11-15 20:28:43.446 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0 not running
                2015-11-15 20:28:43.446 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0
                2015-11-15 20:28:43.446 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0 not running
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0
                2015-11-15 20:28:43.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0 not running
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0
                2015-11-15 20:28:43.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0 not running
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0
                2015-11-15 20:28:43.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0 not running
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0
                2015-11-15 20:28:43.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0 not running
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0
                2015-11-15 20:28:43.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0 not running
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0
                2015-11-15 20:28:43.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0 not scheduled
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-bars.0
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-colorpicker.0
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-hqwidgets.0
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-metro.0
                2015-11-15 20:28:43.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis.0
                2015-11-15 20:28:43.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.mobile.0
                2015-11-15 20:28:43.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0
                2015-11-15 20:28:43.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0 not running
                2015-11-15 20:28:43.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0
                2015-11-15 20:28:43.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0 not running
                2015-11-15 20:28:43.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0
                2015-11-15 20:28:43.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0 not running
                2015-11-15 20:28:43.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-rgraph.0
                2015-11-15 20:28:43.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-timeandweather.0
                2015-11-15 20:28:43.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-fancyswitch.0
                2015-11-15 20:28:43.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-jqui-mfd.0
                2015-11-15 20:28:43.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0
                2015-11-15 20:28:43.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0 not running
                2015-11-15 20:28:43.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0
                2015-11-15 20:28:43.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0 not running
                2015-11-15 20:28:43.590 - info: dwd.0 setting states
                2015-11-15 20:28:44.446 - info: host.MacMini-Ethernet.fritz.box received SIGTERM
                2015-11-15 20:28:44.446 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0
                2015-11-15 20:28:44.446 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0 not running
                2015-11-15 20:28:44.446 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0
                2015-11-15 20:28:44.446 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0 not scheduled
                2015-11-15 20:28:44.446 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0
                2015-11-15 20:28:44.446 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0 not running
                2015-11-15 20:28:44.446 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0
                2015-11-15 20:28:44.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0 not running
                2015-11-15 20:28:44.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0
                2015-11-15 20:28:44.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0 not running
                2015-11-15 20:28:44.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0
                2015-11-15 20:28:44.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0 not running
                2015-11-15 20:28:44.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1
                2015-11-15 20:28:44.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1 not running
                2015-11-15 20:28:44.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0
                2015-11-15 20:28:44.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0 not scheduled
                2015-11-15 20:28:44.447 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0
                2015-11-15 20:28:44.447 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0 not running
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1
                2015-11-15 20:28:44.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1 not running
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2
                2015-11-15 20:28:44.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2 not running
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0
                2015-11-15 20:28:44.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0 not running
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0
                2015-11-15 20:28:44.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0 not running
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0
                2015-11-15 20:28:44.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0 not running
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0
                2015-11-15 20:28:44.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0 not running
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0
                2015-11-15 20:28:44.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0 not running
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0
                2015-11-15 20:28:44.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0 not running
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0
                2015-11-15 20:28:44.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0 not running
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0
                2015-11-15 20:28:44.448 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0 not scheduled
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-bars.0
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-colorpicker.0
                2015-11-15 20:28:44.448 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-hqwidgets.0
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-metro.0
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis.0
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.mobile.0
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0
                2015-11-15 20:28:44.449 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0 not running
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0
                2015-11-15 20:28:44.449 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0 not running
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0
                2015-11-15 20:28:44.449 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0 not running
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-rgraph.0
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-timeandweather.0
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-fancyswitch.0
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-jqui-mfd.0
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0
                2015-11-15 20:28:44.449 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0 not running
                2015-11-15 20:28:44.449 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0
                2015-11-15 20:28:44.449 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0 not running
                2015-11-15 20:28:45.450 - info: host.MacMini-Ethernet.fritz.box received SIGTERM
                2015-11-15 20:28:45.450 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0
                2015-11-15 20:28:45.450 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0 not running
                2015-11-15 20:28:45.450 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0
                2015-11-15 20:28:45.450 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0 not scheduled
                2015-11-15 20:28:45.450 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0
                2015-11-15 20:28:45.450 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0 not running
                2015-11-15 20:28:45.450 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0
                2015-11-15 20:28:45.450 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0 not running
                2015-11-15 20:28:45.450 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0
                2015-11-15 20:28:45.450 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0 not running
                2015-11-15 20:28:45.450 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0
                2015-11-15 20:28:45.450 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0 not running
                2015-11-15 20:28:45.450 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1
                2015-11-15 20:28:45.450 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0 not scheduled
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0 not running
                2015-11-15 20:28:45.451 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0
                2015-11-15 20:28:45.451 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0 not scheduled
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-bars.0
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-colorpicker.0
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-hqwidgets.0
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-metro.0
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis.0
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.mobile.0
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0
                2015-11-15 20:28:45.452 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0 not running
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0
                2015-11-15 20:28:45.452 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0 not running
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0
                2015-11-15 20:28:45.452 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0 not running
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-rgraph.0
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-timeandweather.0
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-fancyswitch.0
                2015-11-15 20:28:45.452 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-jqui-mfd.0
                2015-11-15 20:28:45.453 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0
                2015-11-15 20:28:45.454 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0 not running
                2015-11-15 20:28:45.454 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0
                2015-11-15 20:28:45.454 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0 not running
                2015-11-15 20:28:46.454 - info: host.MacMini-Ethernet.fritz.box received SIGTERM
                2015-11-15 20:28:46.454 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0
                2015-11-15 20:28:46.454 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0 not running
                2015-11-15 20:28:46.454 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0
                2015-11-15 20:28:46.454 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0 not scheduled
                2015-11-15 20:28:46.454 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0
                2015-11-15 20:28:46.455 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0 not running
                2015-11-15 20:28:46.455 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0
                2015-11-15 20:28:46.455 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0 not running
                2015-11-15 20:28:46.455 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0
                2015-11-15 20:28:46.455 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0 not running
                2015-11-15 20:28:46.455 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0
                2015-11-15 20:28:46.455 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0 not running
                2015-11-15 20:28:46.455 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1
                2015-11-15 20:28:46.455 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1 not running
                2015-11-15 20:28:46.455 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0
                2015-11-15 20:28:46.455 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0 not scheduled
                2015-11-15 20:28:46.455 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0
                2015-11-15 20:28:46.455 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.0 not running
                2015-11-15 20:28:46.456 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1
                2015-11-15 20:28:46.457 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.1 not running
                2015-11-15 20:28:46.457 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2
                2015-11-15 20:28:46.457 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.javascript.2 not running
                2015-11-15 20:28:46.457 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0
                2015-11-15 20:28:46.457 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.node-red.0 not running
                2015-11-15 20:28:46.457 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0
                2015-11-15 20:28:46.457 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushover.0 not running
                2015-11-15 20:28:46.457 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0
                2015-11-15 20:28:46.457 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sayit.0 not running
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0
                2015-11-15 20:28:46.458 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.scenes.0 not running
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0
                2015-11-15 20:28:46.458 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sonos.0 not running
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0
                2015-11-15 20:28:46.458 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.terminal.0 not running
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0
                2015-11-15 20:28:46.458 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.web.0 not running
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0
                2015-11-15 20:28:46.458 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.yr.0 not scheduled
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-bars.0
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-colorpicker.0
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-hqwidgets.0
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-metro.0
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis.0
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.mobile.0
                2015-11-15 20:28:46.458 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0
                2015-11-15 20:28:46.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.sequence.0 not running
                2015-11-15 20:28:46.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0
                2015-11-15 20:28:46.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.occ.0 not running
                2015-11-15 20:28:46.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0
                2015-11-15 20:28:46.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vcard.0 not running
                2015-11-15 20:28:46.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-rgraph.0
                2015-11-15 20:28:46.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-timeandweather.0
                2015-11-15 20:28:46.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-fancyswitch.0
                2015-11-15 20:28:46.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.vis-jqui-mfd.0
                2015-11-15 20:28:46.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0
                2015-11-15 20:28:46.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hmm.0 not running
                2015-11-15 20:28:46.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0
                2015-11-15 20:28:46.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.pushbullet.0 not running
                2015-11-15 20:28:47.459 - info: host.MacMini-Ethernet.fritz.box received SIGTERM
                2015-11-15 20:28:47.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0
                2015-11-15 20:28:47.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.admin.0 not running
                2015-11-15 20:28:47.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0
                2015-11-15 20:28:47.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.dwd.0 not scheduled
                2015-11-15 20:28:47.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0
                2015-11-15 20:28:47.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.fritzbox.0 not running
                2015-11-15 20:28:47.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0
                2015-11-15 20:28:47.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.history.0 not running
                2015-11-15 20:28:47.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0
                2015-11-15 20:28:47.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rega.0 not running
                2015-11-15 20:28:47.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0
                2015-11-15 20:28:47.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.0 not running
                2015-11-15 20:28:47.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1
                2015-11-15 20:28:47.459 - warn: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.hm-rpc.1 not running
                2015-11-15 20:28:47.459 - info: host.MacMini-Ethernet.fritz.box stopInstance system.adapter.ical.0</anonymous>
                Hat das schon jemand gehabt?
                  pix last edited by
                  Ok, das Einspielen eines TimeMachine Backups von heute Morgen hat zumindest geholfen, das System wieder zu starten. Das kann aber nicht der übliche Weg sein, schließlich gibt es das nur auf OS X.
                  Das Update der o.g. Adapter funktioniert dennoch nicht.
                  Pix
                  • sissiwup
                    Installier mal dein npm auf Version 3.3.4, die 3.3.5 und 3.3.6 sollen da buggy sein.
