    4. Probleme mit hm-rpc 0.3.1
    • ruhigundrelaxed
      ruhigundrelaxed last edited by
      Hi Ho,
      hab nach dem letzten Update auf hm-rpc 0.3.1 uncaught exceptions…
      Direkt nach dem update:
      zuhause	2015-02-13 13:19:08	info	host.zuhause Restart adapter system.adapter.hm-rpc.0 because enabled
      zuhause	2015-02-13 13:19:08	error	host.zuhause instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
      hm-rpc.0	2015-02-13 13:19:08	error	Error: Cannot find module 'xmlbuilder' at Function.Module._resolveFilename (module.js:338:15) at Function.Module._load (module.js:280:25) at Module.require (module.js:364:17) at requir
      hm-rpc.0	2015-02-13 13:19:08	error	uncaught exception: Cannot find module 'xmlbuilder'
      ich habe dann mal probiert mit npm xmlbuilder nachzuinstallieren.. (npm install xmlbuilder)
      danach hatte ich die Fehlermeldung:
      zuhause	2015-02-13 13:19:39	error	host.zuhause instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
      hm-rpc.0	2015-02-13 13:19:39	error	Error: Cannot find module 'sax' at Function.Module._resolveFilename (module.js:338:15) at Function.Module._load (module.js:280:25) at Module.require (module.js:364:17) at require (modu
      hm-rpc.0	2015-02-13 13:19:39	error	uncaught exception: Cannot find module 'sax'
      hm-rpc.0	2015-02-13 13:19:39	info	hm-rpc.0 starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.hm-rpc
      zuhause	2015-02-13 13:19:38	info	host.zuhause instance system.adapter.hm-rpc.0 started with pid 18722
      ich hab dann mal probiert mit npm sax nachzuinstallieren… (npm install sax)
      nun kommt folgender Fehler im log:
      zuhause	2015-02-13 13:20:41	info	host.zuhause Restart adapter system.adapter.hm-rpc.0 because enabled
      zuhause	2015-02-13 13:20:41	error	host.zuhause instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
      hm-rpc.0	2015-02-13 13:20:41	error	Error: Root element needs a name at new XMLBuilder (/opt/iobroker/node_modules/xmlbuilder/lib/XMLBuilder.js:17:15) at Object.module.exports.create (/opt/iobroker/node_modules/xmlbuilder/lib/in
      hm-rpc.0	2015-02-13 13:20:41	error	uncaught exception: Root element needs a name
      kann das jemand reproduzieren, oder ist meine Installation vermurxt.
      Martin
        @ruhigundrelaxed:
        Hi Ho,
        Martin `
        Es ist tatsächlich ein Fehler. Nimm 0.3.2. Leigt seit 30 Sekunden auf npm.
        • ruhigundrelaxed
          Wow. Super schnelle Reaktion. 0.3.2 funktioniert. Vielen Dank
          1.2k
          80.8k
