Create Adapter Instanz: Timer.listOnTimeout
ich versuche gerade auf meinem Raspberry Pi (ein alter RPI Version 1) ioBroker zu installieren. Die Instanzierung der meisten Adapter hat ohne Probleme funktioniert. Bei manchen Adaptern wie z.B. vis-keyboard erhalte ich jedoch einen Timeout.
$ ./iobroker add vis-keyboard ERROR: ERROR: events.js:72 ERROR: throw er; // Unhandled 'error' event ^ ERROR: Error: listen EADDRINUSE at errnoException (net.js:901:11) at Server._listen2 (net.js:1039:14) at listen (net.js:1061:10) at Server.listen (net.js:1127:5) at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2494:24) at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:144:9 at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:151:7) at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2160:27) at Timer.listOnTimeout [as ontimeout] (timers.js:110:15) ERROR: process exited with code 8
iobroker 2015-11-17 19:03:56 info exit 8 iobroker 2015-11-17 19:03:56 error at Timer.listOnTimeout [as ontimeout] (timers.js:110:15) iobroker 2015-11-17 19:03:56 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2160:27) iobroker 2015-11-17 19:03:56 error at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:151:7) iobroker 2015-11-17 19:03:56 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:144:9 iobroker 2015-11-17 19:03:56 error at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2494:24) iobroker 2015-11-17 19:03:56 error at Server.listen (net.js:1127:5) iobroker 2015-11-17 19:03:56 error at listen (net.js:1061:10) iobroker 2015-11-17 19:03:56 error at Server._listen2 (net.js:1039:14) iobroker 2015-11-17 19:03:56 error Error: listen EADDRINUSE at errnoException (net.js:901:11) iobroker 2015-11-17 19:03:55 error throw er; // Unhandled 'error' event ^ iobroker 2015-11-17 19:03:55 error events.js:72 iobroker 2015-11-17 19:03:55 error iobroker 2015-11-17 19:03:40 info add vis-keyboard
kennt jemand diesen Fehler?
Kann dieser Timeout an meiner alten hardware liegen?
Tobias
Tobias `
hast du schon mal diesen Antwort gelesen? -
Vielen Dank!
Konnte diesen Post leider nicht über die Suchfunktion finden
Tobias
