    4. [gelöst] Scenes Adapter: Cannot assign to read only property
    • Jey Cee
      Jedesmal wenn ich an einer Szene was ändere wird der Adapter neu gestartet. Dann tauchen jedesmal die selben Fehler im Log auf.
      scenes.0	2015-11-22 12:08:03	info	scenes.0 starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.scenes
      ioBroker	2015-11-22 12:08:00	info	host.ioBroker instance system.adapter.scenes.0 started with pid 4067
      host-ioBroker	2015-11-22 12:07:30	info	Restart adapter system.adapter.scenes.0 because enabled
      host-ioBroker	2015-11-22 12:07:30	error	instance system.adapter.scenes.0 terminated with code 6 (uncaught exception)
      TypeError:	2015-11-22 12:07:29	error	at Timer.listOnTimeout (timers.js:92:15)
      TypeError:	2015-11-22 12:07:29	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:366:30)
      TypeError:	2015-11-22 12:07:29	error	at Adapter.emit (events.js:172:7)
      TypeError:	2015-11-22 12:07:29	error	at emitTwo (events.js:87:13)
      TypeError:	2015-11-22 12:07:29	error	at Adapter. (/opt/iobroker/node_modules/iobroker.scenes/main.js:99:13)
      TypeError:	2015-11-22 12:07:29	error	at restartAdapter (/opt/iobroker/node_modules/iobroker.scenes/main.js:113:13)
      TypeError:	2015-11-22 12:07:29	error	at exports.clearTimeout (timers.js:224:42)
      TypeError:	2015-11-22 12:07:29	error	Cannot assign to read only property '_onTimeout' of scene.0.PS3
      uncaught	2015-11-22 12:07:29	error	exception: Cannot assign to read only property '_onTimeout' of scene.0.PS3
      scenes-0	2015-11-22 12:07:29	info	restartAdapter
        @Jey Cee:
        Probier mal
        ### 0.2.2 (2015-11-22)
        * (bluefox) fix error with restart adapter
        • Jey Cee
          Danke Bluefox für den schnellen Fix die Fehler sind weg. Der Adapter startet aber immer noch neu, ich geh davon aus das muss so sein.
