    4. Yahka lässt sich nicht installieren
      tomily last edited by
      Hi guys,
      habe meinen ioBroker vom Raspberry auf eine virtuelle Linux Maschine (Debian GNU/Linux 9 x64) umgezogen.
      Leider kann ich dort den Homekit bzw. Yahka Adapter nicht mehr installieren.
      Hat jemand eine Idee? Erhalte folgende Fehlermeldung.
      Kompletter Auszug des Installationsfensters:
      $ ./iobroker add yahka  --host ioBroker
      NPM version: 6.4.1
      npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
      gyp
      ERR!
      build error
      gyp
       ERR! stack Error: not found: makegyp ERR! stack
           at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)gyp ERR! stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
      gyp ERR! stack
           at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
      gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
      gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
      gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:152:21)
      gyp ERR! System Linux 4.9.0-7-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/curve25519-n
      gyp ERR! node -v v8.12.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      npm
      ERR!
       code ELIFECYCLEnpm ERR! errno 1
      npm
       ERR! curve25519-n@1.4.0 install: `node-gyp rebuild`npm ERR! Exit status 1
      npm ERR!
       npm ERR! Failed at the curve25519-n@1.4.0 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-11-09T12_33_37_926Z-debug.log
      host.ioBroker install adapter yahka
      NPM version: 6.4.1npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
      gyp
      ERR!
      build error
      gyp
      stack     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)gyp ERR!
       stack     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
      gyp ERR!
       stack     at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16gyp ERR! stack     at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
      gyp ERR! not ok
      npm
      ERR!
      code
      npm
      ERR!
       ERR! Exit status 1npm ERR!
      npm ERR!
       Failed at the curve25519-n@1.4.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm
      ERR!
       A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-11-09T12_33_48_573Z-debug.log
      gyp
      ERR!
      build error
      gyp
      ERR! stack
       Error: not found: makegyp ERR! stack     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
      gyp ERR! stack     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)gyp ERR!
      gyp ERR! not ok
      npm
      ERR!
      code
       ELIFECYCLEnpm
      ERR! errno 1npm
       ERR! npm ERR! Failed at the curve25519-n@1.4.0 install script.
      npm ERR!
      npm
      ERR!
      npm
      ERR!     /root/.npm/_logs/2018-11-09T12_33_58_665Z-debug.log
      ERROR: host.ioBroker Cannot install yahka
      ERROR: process exited with code 13
      • apollon77
        apollon77 last edited by
        lass mich mal für dich googeln ..
        https://www.google.com/search?q=Error%3 … 3A+makegyp
        Der erste Link sieht mal ziemlich vielversprechend aus
          Danke! Dieser Foreneintrag ist mir trotz intensivem suchen durch die Lappen gegangen.
          Konnte den Adapter dann tatsächlich installieren. Allerdings lässt er sich nicht starten.
          Kann die kommenden Log-Einträge nicht richtig interpretieren. Vll kannst Du was damit anfangen?
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:96
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: throw err
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: ^
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: Error: Could not locate the bindings file. Tried:
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/build/ed25519.node
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/build/Debug/ed25519.node
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/build/Release/ed25519.node
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/out/Debug/ed25519.node
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/Debug/ed25519.node
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/out/Release/ed25519.node
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/Release/ed25519.node
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/build/default/ed25519.node
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: → /opt/iobroker/node_modules/ed25519-hap/compiled/8.12.0/linux/x64/ed25519.node
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:93:9)
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/ed25519-hap/index.js:1:99)
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: at Module._compile (module.js:653:30)
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
          2018-11-11 12:02:39.933 - error: Caught by controller[0]: at Module.load (module.js:566:32)
          2018-11-11 12:02:39.934 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
          2018-11-11 12:02:39.934 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
          2018-11-11 12:02:39.934 - error: Caught by controller[0]: at Module.require (module.js:597:17)
          2018-11-11 12:02:39.934 - error: Caught by controller[0]: at require (internal/module.js:11:18)
          2018-11-11 12:02:39.934 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/hap-nodejs/lib/HAPServer.js:8:15)
          2018-11-11 12:02:39.934 - error: host.ioBroker-test instance system.adapter.yahka.0 terminated with code 1 ()
          • apollon77
            Nicht korrekt installiert. Zeig bitte mal das install log.
            Gesendet vom Handy …
              im Dateianhang das Log aus dem Verzeichnis /opt/iobroker/log.
              Ich hoffe du hast das gemeint?
              In der ioBroker-Gui bekome ich nur die Einträge, die ich vorhin gesendet habe.
              Oder gibt es ein separates Install-Log?
              9175_iobroker.2018-11-11.log
                Moin,
                also ich konnte den Adapter nun ans laufen bringen. Aber leider weiß ich nicht, was letztendlich das Problem gelöst hat.
                Nach der Installation der zwei fehlenden Pakete habe ich den Adapter insgesamt 3x über die Gui installiert. Beim dritten mal hat es funktioniert.
                Werde heute Abend mal ein paar Geräte einfügen und testen, ob die Bridge auch gefunden wird.
                Sorry, dass ich keine vernünftige Rückmeldung gebenkann. Trotzdem 1000 Dank !
                81.1k
