    4. Yahka Error nach Update auf js-controller 1.5.2
      michacolonia last edited by
      Ich habe folgende Fehlermeldungen nach dem Update auf js-controller 1.5.2
      Hat noch jemand dieses Problem?
      yahka.0	2018-09-15 13:39:14.912	error	exception by stop: Cannot call write after a stream was destroyed
      yahka.0	2018-09-15 13:39:14.910	info	cleaned everything up...
      yahka.0	2018-09-15 13:39:14.909	error	at Characteristic.TargetPosition. <anonymous>(/opt/iobroker/node_modules/iobroker.yahka/yahka.homekit-bridge.js:150:27)
      yahka.0	2018-09-15 13:39:14.909	error	at TIoBrokerInOutFunction_State.fromIOBroker (/opt/iobroker/node_modules/iobroker.yahka/yahka.function-factory.js:66:22)
      yahka.0	2018-09-15 13:39:14.909	error	at Adapter.getForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4299:33)
      yahka.0	2018-09-15 13:39:14.909	error	at StatesInMemClient.getState (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:151:16)
      yahka.0	2018-09-15 13:39:14.909	error	at Socket.emit (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:150:5)
      yahka.0	2018-09-15 13:39:14.909	error	at enabled (/opt/iobroker/node_modules/socket.io-client/node_modules/debug/debug.js:120:11)
      yahka.0	2018-09-15 13:39:14.909	error	at Function.log (/opt/iobroker/node_modules/socket.io-client/node_modules/debug/node.js:110:17)
      yahka.0	2018-09-15 13:39:14.909	error	at Socket.Writable.write (_stream_writable.js:294:11)
      yahka.0	2018-09-15 13:39:14.909	error	at writeOrBuffer (_stream_writable.js:394:5)
      yahka.0	2018-09-15 13:39:14.909	error	at doWrite (_stream_writable.js:406:19)
      yahka.0	2018-09-15 13:39:14.909	error	Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      yahka.0	2018-09-15 13:39:14.909	error	uncaught exception: Cannot call write after a stream was destroyed
      yahka.0	2018-09-15 13:38:41.945	error	exception by stop: Cannot call write after a stream was destroyed
      yahka.0	2018-09-15 13:38:41.944	info	cleaned everything up...</anonymous>
      • sigi234
        viewtopic.php?f=36&t=16798
          … und das bedeutet, dass ich auf ein Update des Yahka Entwickler warten muss, oder?
            Super! läuft wieder :!: 8-)
