    4. Wert von Homematic Gerät bei Funktion abrufen
      HKF8770 last edited by
      Habe ein Problem,
      möchte bei einer Berechnung "edit function node" einen Wert einer Homematic Componente miot einbeziehen.
      Habe es versuch wie bei einem Java Skrift mit "var zv = getState("javascript.0.Strom.Zählerstand.Vorjahr"/javascript.0.Strom.Zählerstand.Vorjahr/).val;" doch das geht nicht.
      Wie ist der Befehlt oder geht das gar nicht??
      [{"id":"e46e912d.1b917","type":"inject","name":"","topic":" ","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"x":187,"y":484,"z":"fc6c7385.03939","wires":[["dd040bba.22fbf8","937366d3.6c8c98"]]},{"id":"6cdb284d.9324d8","type":"debug","name":"","active":true,"console":"false","complete":"false","x":570,"y":460,"z":"fc6c7385.03939","wires":[]},{"id":"937366d3.6c8c98","type":"function","name":"Tage + 1","func":"msg = {};\nvar Tage = require(\"hm-rega.0.10499\"/*Tage_Strom*/).val;\nvar Tageneu = Tage + 1; \nmsg.payload = Tageneu;\nreturn msg;","outputs":1,"noerr":0,"x":382,"y":491,"z":"fc6c7385.03939","wires":[["6cdb284d.9324d8"]]},{"id":"dd040bba.22fbf8","type":"debug","name":"","active":true,"console":"false","complete":"false","x":378,"y":417,"z":"fc6c7385.03939","wires":[]}]
