    4. Javascript install error
      Soukai last edited by
      Hallo!
      ich hab probleme javascript zu installieren und bekomme folgende meldung und weiß nicht weiter:
      root@raspberrypi:/opt/iobroker# npm install iobroker.javascript
      (node:2361) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpd                       ir() instead.
      npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coff                       eescript" (no hyphen)
      npm ERR! Error: Method Not Allowed
      npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
      npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.j                       s:167:7)
      npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this *entire* log,
      npm ERR! including the npm and node versions, at:
      npm ERR!     <http: github.com/npm/issues="">npm ERR! System Linux 4.14.72-v7+
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript"
      npm ERR! cwd /opt/iobroker
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR!     /opt/iobroker/npm-debug.log
      npm ERR! not ok code 0</http:>
      Was tun?
      Vielen Dank!
      Chris
      • Dutchman
        Warum per npm ? Was passiert bei:
        iobroker add javascript
          Per iobroker gehts auch nicht. Durch deinen Befehl leider auch nicht…
          root@raspberrypi:~# iobroker add javascript
          (node:1476) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
          NPM version: 1.4.21
          npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
          (node:1490) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
          npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
          npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
          npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript" "--production" "--save" "--prefix" "/opt/iobroker"
          npm ERR! cwd /root
          npm ERR! code E405
          npm ERR!
          npm ERR!     /root/npm-debug.log
          host.raspberrypi create instance javascript
          host.raspberrypi error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'</http:>
          • Dutchman
            Npm Version 1.4????
            Was sagt
            node -v
            npm -v
              root@raspberrypi:~# node -v
              v8.11.1
              root@raspberrypi:~# npm -v
              1.4.21
              (node:1777) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
              root@raspberrypi:~#
                paul53 last edited by
                NPM v1.4.21 ist schon sehr alt. Update besser auf Version 4.
                npm install -g npm@4
                npm -v
                • Dutchman
                  Und weil npm zu alt ist geht die Installation auch nicht
                    hat nun geklappt, nach paar errors. er sagt mir nun es gibt ein update. Ist es empfehlenswert auf 6.x upzudaten?
