    4. MQTT Adapter geht seit heute nicht mehr
      homecineplexx last edited by
      hallo
      wollte heute bissl was arbeiten (coden), und da merk ich, mein MQTT Adapter bleibt auf gelb und wird nicht mehr grün.
      Logs sagen leider nicht viel aus:
      2018-10-17 18:41:53.669  - ESC[34mdebugESC[39m: mqtt.0 onStateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1539794513660,"q":0,"from":"system.adapter.mqtt.0","lc":1539793802461}
      2018-10-17 18:42:12.359  - ESC[32minfoESC[39m: host.raspberrypi object change system.adapter.mqtt.0
      2018-10-17 18:42:12.360  - ESC[32minfoESC[39m: host.raspberrypi stopInstance system.adapter.mqtt.0
      2018-10-17 18:42:12.360  - ESC[32minfoESC[39m: host.raspberrypi stopInstance system.adapter.mqtt.0 killing pid 3114
      2018-10-17 18:42:12.941  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 156 ()
      2018-10-17 18:42:14.890  - ESC[32minfoESC[39m: host.raspberrypi instance system.adapter.mqtt.0 started with pid 3131
      2018-10-17 18:42:15.847  - ESC[34mdebugESC[39m: mqtt.0 objectDB connected
      2018-10-17 18:42:15.909  - ESC[34mdebugESC[39m: mqtt.0 statesDB connected
      2018-10-17 18:42:16.026  - ESC[32minfoESC[39m: mqtt.0 starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.mqtt, node: v10.10.0
      2018-10-17 18:42:16.684  - ESC[32minfoESC[39m: mqtt.0 Starting MQTT ' authenticated  server on port 1886
      2018-10-17 18:42:16.685  - ESC[32minfoESC[39m: mqtt.0 Starting MQTT -WebSocket' authenticated  server on port 1887
      2018-10-17 18:42:16.696  - ESC[34mdebugESC[39m: mqtt.0 stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1539794536688,"q":0,"from":"system.adapter.mqtt.0","lc":1539793802461}
      2018-10-17 18:42:16.697  - ESC[34mdebugESC[39m: mqtt.0 onStateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1539794536688,"q":0,"from":"system.adapter.mqtt.0","lc":1539793802461}
      81.1k
