    4. [gelöst] JSON Wert extrahieren
      Stuti last edited by
      leider hatte ich in FB keinen Erfolg, deswegen die Frage noch einmal hier:
      Ich versuche Min, Max und Mittelwerte aus der SQL Datenbank zu bekommen.
          sendTo('sql.0', 'query', 'select avg(val) from ioBroker.ts_number where id = 21 and ts/1000 >= Unix_TIMESTAMP(CURDATE())', function (avgval) {
          if (avgval.error) {
              console.error(avgval.error);
          } else {
              // show result
               log('Rows: ' + JSON.stringify(avgval.result));
               var test = JSON.stringify(avgval.result).avg(val);
               log(test);
      Ergibt:
      16:29:43.270	info	javascript.0 script.js.Datenbankabfragen.Tagesmittelwert: Rows: [{"avg(val)":-2.0713963963963966}]
      16:29:43.270	error	javascript.0 ReferenceError: val is not defined at Object.cb (script.js.Datenbankabfragen.Tagesmittelwert:7:55) at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3386:71) at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30) at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20) at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12) at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8) at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)</anonymous></anonymous></anonymous>
      Also prinzipiell funktionert die Rückgabe ja, aber ich schaffe es nicht den Wert raus zu bekommen.
      log(avgval.result[1].avg(val)) gibt auch immer die Meldung, das "val" nicht definiert ist.
      Kann mir jemand helfen?
        pix last edited by
        Vielleicht liege ich völlig falsch, aber was soll im stringify der letzte ".avg(val)"? Das kannst du eigentlich nicht einfach anhängen.
        Also versuch mal so:
            if (avgval.error) {
            } else {
                // show result
                 var test = JSON.stringify(avgval.result[0].avg(val));
                 log(test);
        Vielleicht sind auch die runden Klammern im Namen ein Problem, dann probier mal
        var test = JSON.stringify(avgval.result[0].["avg(val)"]);
        Pix
          ich hatte mich irgendwann gewundert warum es in eckigen Klammern zurückgegeben wurde, also: [{"avg(val)":-2.0713963963963966}]
          Demnach ist das dann wohl ein Array…
          Es funktioniert: avgval.result[0]["avg(val)"]
          bzw am Ende: setState('Datenbank.TagesTempMittel', (avgval.result[0]["avg(val)"]).toFixed(2));
          Ob man JSON.stringify davor schreibt oder es lässt macht soweit ich gesehen hab keinen Unterschied.
          Danke für die Hilfe. Ich markier das hier als gelöst.
          79.9k
