    4. Npm update
    Npm update
      mimquadrat last edited by
      hi jungs,
      ich glaub ich war mal wieder zu mutig. Wollte den node-red Adapter installieren, da war ein Fehler mit irgendwas NPM ist nicht das richtige…..
      Daraufhin habe ich das hier gemacht:
      sudo npm install npm -g
      von hier:
      https://docs.npmjs.com/getting-started/installing-node
      das hier ist im Log:
      ` > $ ./iobroker add zwave
      npm install iobroker.zwave –production --prefix "/opt/iobroker" (System call)
      npm
      WARN lifecycle openzwave-shared@1.1.6~preinstall: cannot run in wd %s %s (wd=%s) openzwave-shared@1.1.6 node lib/install-ozw.js /opt/iobroker/node_modules/.staging/openzwave-shared-8e400646
      gyp: Call to 'PKG_CONFIG_PATH= pkg-config --variable=libdir libopenzwave' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp
      ERR!
      configure error
      gyp
      ERR!
      stack
      Error: gyp failed with exit code: 1
      gyp
      ERR! stack
      at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:305:16)gyp
      ERR! stack
      at ChildProcess.emit (events.js:110:17)gyp
      ERR! stack
      at Process.ChildProcess._handle.onexit (child_process.js:1074:12)
      gyp ERR!
      System Linux 4.1.7-v7+gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
      gyp ERR! node -v v0.12.6
      gyp ERR! node-gyp -v v3.2.1
      gyp ERR! not ok
      npm
      WARN enoent ENOENT, open '/opt/iobroker/package.json'
      npm WARN mongodb-core@1.2.28 requires a peer of kerberos@~0.0 but none was installed.
      npm WARN iobroker No description
      npm WARN iobroker No repository field.
      npm WARN iobroker No README data
      npm WARN iobroker No license field.
      npm
      ERR! Linux 4.1.7-v7+npm ERR! argv "node" "/usr/local/bin/npm" "install" "iobroker.zwave" "--production" "--prefix" "/opt/iobroker"
      npm ERR! node v0.12.6
      npm ERR! npm v3.5.2npm ERR! code ELIFECYCLE
      npm
      ERR! openzwave-shared@1.1.6 install: node-gyp rebuildnpm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the openzwave-shared@1.1.6 install script 'node-gyp rebuild'.
      npm ERR! Make sure you have the latest version of node.js and npm installed.
      npm ERR! If you do, this is most likely a problem with the openzwave-shared package,
      npm ERR!
      not with npm itself.npm ERR! Tell the author that this fails on your system:
      npm ERR! node-gyp rebuild
      npm ERR! You can get information on how to open an issue for this project with:
      npm
      ERR!
      npm bugs openzwave-sharednpm ERR! Or if that isn't available, you can get their info via:
      npm ERR! npm owner ls openzwave-shared
      npm
      ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR! /npm-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.zwave: 1
      ERROR: process exited with code 25 `
      was soll ich machen!?
        @mimquadrat:
        hi jungs,
        von hier:
        npm
        gyp
        ERR!
        configure error
        gyp
        ERR!
        stack
        gyp
        ERR! stack
        ERR! stack
        ERR! stack
        gyp ERR!
        gyp ERR! not ok
        npm
        npm
        npm
        npm ERR!
        npm ERR!
        npm
        ERR!
        npm
        was soll ich machen!? `
        Was passiert?
        cd /opt/iobroker
        sudo npm install iobroker.zwave
        • V
          versteckt last edited by
          Wart mit zwave, morgen bzw. übermorgen gibt es eine neue Version inkl. Dokumentation.
          Gesendet von meinem iPhone mit Tapatalk
          9364_iobroker.2018-11-12.log
            ich hab stattdessen mit dem Wolf Adapter probiert:
            ` > root@raspberrypi:/opt/iobroker# sudo npm install iobroker.wolf
            /opt/iobroker
            ├── iobroker.icons-addictive-flavour-png@0.1.0
            └── iobroker.wolf@0.1.0
            npm WARN enoent ENOENT, open '/opt/iobroker/package.json'
            npm WARN iobroker No license field. `
            2858_iobroker.2018-11-14_-kopie__3.log
              @mimquadrat:
              /opt/iobroker
              Hat doch geklappt. Nur Warnungen
                leider ist der Adapter aber unter Instanzen nicht sichtbar
