    4. SQLlight3 Fehler in LOG
      hofi77 last edited by
      Hallo!
      Ich bekomme im LOG nachdem ich die History über SQL in den Geräten aktiviert habe folgende Fehler:
      sql.0	2015-12-20 13:43:54	error	sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.LEQ1247525.2.SET_TEMPERATURE';: Error: SQLITE_BUSY: database is locked
      sql.0	2015-12-20 13:43:54	error	sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(4, 1450615423000, 58, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
      sql-0	2015-12-20 13:43:12	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(24, 1450615381000, 20, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
      sql-0	2015-12-20 13:43:06	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(47, 1450615376000, 20, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
      sql-0	2015-12-20 13:43:01	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(29, 1450615371000, 120, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
      kann mir bitte jemand helfen?
      Danke Euch 🙂
      lg
      Manuel
      • eric2905
        eric2905 last edited by
        Hallo Manuel,
        schau mal hier : http://forum.iobroker.net/viewtopic.php?t=1776
        Gruß,
        Eric
