    4. SQL History 0.1.2 Fehler "ECONNREFUSED"
    • eric2905
      eric2905 last edited by
      Moin zusammen,
      habe heute früh das Update des "SQL History" Adapter auf die Version 0.1.2 durchgeführt …
      Log schmiss Fehlermeldungen (hab ich Esel nicht gesichert ... war was mit NPM ....) und nun habe ich einen Verbindungsfehler zur DB.
      sql.0	2015-12-23 05:03:42	error	sql.0 Error: connect ECONNREFUSED
      sql.0	2015-12-23 05:03:38	warn	sql.0 No connection to DB
      sql.0	2015-12-23 05:03:37	warn	sql.0 No connection to DB
      sql.0	2015-12-23 05:03:22	warn	sql.0 No connection to DB
      sql.0	2015-12-23 05:03:12	error	sql.0 Error: connect ECONNREFUSED
      sql.0	2015-12-23 05:03:07	warn	sql.0 No connection to DB
      sql.0	2015-12-23 05:02:55	warn	sql.0 No connection to DB
      sql.0	2015-12-23 05:02:51	warn	sql.0 No connection to DB
      sql.0	2015-12-23 05:02:45	warn	sql.0 No connection to DB
      sql.0	2015-12-23 05:02:42	error	sql.0 Error: connect ECONNREFUSED
      sql.0	2015-12-23 05:02:36	warn	sql.0 No connection to DB
      sql.0	2015-12-23 05:02:24	warn	sql.0 No connection to DB
      sql.0	2015-12-23 05:02:21	warn	sql.0 No connection to DB
      sql.0	2015-12-23 05:02:19	warn	sql.0 No connection to DB
      sql-0	2015-12-23 05:02:13	warn	No connection to DB
      sql-0	2015-12-23 05:02:12	error	Error: connect ECONNREFUSED
      sql-0	2015-12-23 05:02:06	warn	No connection to DB
      TypeError:	2015-12-23 05:02:02	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:212:12)
      TypeError:	2015-12-23 05:02:02	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:254:10)
      TypeError:	2015-12-23 05:02:02	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      TypeError:	2015-12-23 05:02:02	error	at Socket.StatesInMemClient.client.on.connectionTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      TypeError:	2015-12-23 05:02:02	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1930:34)
      TypeError:	2015-12-23 05:02:02	error	at Adapter.emit (events.js:95:17)
      TypeError:	2015-12-23 05:02:02	error	at Adapter._client (/opt/iobroker/node_modules/iobroker.sql/main.js:70:5)
      TypeError:	2015-12-23 05:02:02	error	at processMessage (/opt/iobroker/node_modules/iobroker.sql/main.js:379:9)
      TypeError:	2015-12-23 05:02:02	error	at getHistory (/opt/iobroker/node_modules/iobroker.sql/main.js:781:16)
      TypeError:	2015-12-23 05:02:02	error	at getId (/opt/iobroker/node_modules/iobroker.sql/main.js:589:16)
      TypeError:	2015-12-23 05:02:02	error	Cannot call method 'borrow' of null
      message	2015-12-23 05:02:02	error	messagebox.system.adapter.sql.0 [object Object] Cannot call method 'borrow' of null
      Jemand eine Ahnung / Idee?
      Danke und Gruß,
      Eric
      • eric2905
        Nachtrag:
        Habe die SQL-Instanz gelöscht (fehlerfrei) und dann versucht wieder eine neue Instanz zu installieren / aktivieren:
        $ ./iobroker add sql
        host.cubietruck create instance sql
        ERROR: host.cubietruck error: reading io-package.json Error: ENOENT, no such file or directory '/opt/iobroker/node_modules/iobroker.sql/io-package.json'
        ERROR: process exited with code 20
        Im Verzeichnis "/opt/iobroker/node_modules/iobroker.sql" ist wiederum ein Ordner "node_modules", aber kein File "io-package.json"
        Die Date ist im gesamten Pfad (find . -name io-package.json) nicht zu finden.
        Gruß,
        Eric
          @eric2905:
          Nachtrag:
          Gruß,
          Eric `
          cd /opt/iobroker
          iobroker stop sql
          npm install iobroker.sql
          iobroker upload sql
          iobroker start sql
          Welche Einstellungen hast du?
          2995_meross_log.txt
          • eric2905
            Im SQL-Adapter sind die Einstellungen wie vor dem Update drin:
            Host: localhost
            Port: 0
            User und Pwd: wie im mySQL definiert
            Den Rest probiere ich nachher, wenn ich zu Hause bin.
            Gruß,
            Eric
            • eric2905
              Hi Bluefox,
              hat nichts gebracht - immer noch der Fehler.
              Habe schon DB gedropped und user gelöscht und neu angelegt, usw.
              Erst nachdem ich mySQL komplett deinstalliert und neu installiert habe, funktioniert es wieder.
              Gruß,
              Eric
                @eric2905:
                Hi Bluefox,
                Erst nachdem ich mySQL komplett deinstalliert und neu installiert habe, funktioniert es wieder. `
                Komisch… :?
                  Habedere last edited by Negalein
                  Servus,
                  stehe eben auch vor dem Problem...
                  Habe schon eine neue Instanz installiert und die alten Einstellungen importiert - no way.
                  Auch der externe Zugriff vom Lappy auf die Datenbank funzt nicht.
                  Jemand noch eine Idee?
                  mfg
                  PS:
                  SQL 1.9.5
                  Node.js v8.16.0
                  NPM v6.4.1
                  PPS:
                  sql.0	2019-09-28 21:12:44.467	error	Error: connect ECONNREFUSED 127.0.0.1:3306
                  sql.0	2019-09-28 21:12:14.451	error	Error: connect ECONNREFUSED 127.0.0.1:3306
                  sql.0	2019-09-28 21:12:14.142	info	starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.sql, node: v8.16.0
                  sql.0	2019-09-28 21:12:14.065	info	States connected to redis: 127.0.0.1:6379
                  Hab dann in den Einstellungen bei Localhost mal Port 6379 versucht - "Connection Timeout"
                  PPPS:
                  Für alle die das Problem auch haben - bei mir hat wie folgt geholfen:
                  Neustarten von MySQL:
                  sudo service mysql restart
