    4. Syntax Error seit Onkyo 0.1.10
      Beatz last edited by
      seit dem Update auf die Version 0.1.10 des Onkyo Adapters bekomme ich folgende Fehlermeldungen im Log.
      ` > SyntaxError: 2015-12-28 15:22:58 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
      SyntaxError: 2015-12-28 15:22:58 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      SyntaxError: 2015-12-28 15:22:58 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      SyntaxError: 2015-12-28 15:22:58 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:212:12)
      SyntaxError: 2015-12-28 15:22:58 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:254:10)
      SyntaxError: 2015-12-28 15:22:58 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
      SyntaxError: 2015-12-28 15:22:58 error at Socket.StatesInMemClient.client.on.connectionTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      SyntaxError: 2015-12-28 15:22:58 error at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1942:80)
      SyntaxError: 2015-12-28 15:22:58 error at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.onkyo/onkyo.js:26:17)
      SyntaxError: 2015-12-28 15:22:58 error at new RegExp ()
      SyntaxError: 2015-12-28 15:22:58 error Invalid regular expression: /^[A-Z0-9/-+]+$/: Range out of order in character class
      message 2015-12-28 15:22:58 error onkyo.0.command [object Object] Invalid regular expression: /^[A-Z0-9/-+]+$/: Range out of order in character class
      onkyo-0 2015-12-28 15:22:58 info stateChange onkyo.0.command {"val":"master-volume=12","ack":false,"ts":1451312578,"q":0,"from":"system.adapter.javascript.0","lc":1451312578} `
      Kann das jemand bestätigen?
      Andreas
        Da ist ein Fehler drin. Werde demnächst fixen.
          Spitze 🙂
            Sollte jetzt gehen.
