    4. Fehlermeldungen Java Skript
      Realleachim last edited by
      Hallo!
      Ich habe mir Javaskript installiert, erhalte vom Adapter aber nur Fehlermeldungen. Woran kann das liegen?
      host.raspberrypi	2018-11-23 10:05:32.330	info	Restart adapter system.adapter.javascript.0 because enabled
      host.raspberrypi	2018-11-23 10:05:32.330	error	instance system.adapter.javascript.0 terminated with code 1 ()
      host.raspberrypi	2018-11-23 10:05:32.330	error	Caught by controller[0]: at tryModuleLoad (module.js:505:12)
      host.raspberrypi	2018-11-23 10:05:32.330	error	Caught by controller[0]: at Module.load (module.js:565:32)
      host.raspberrypi	2018-11-23 10:05:32.330	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
      host.raspberrypi	2018-11-23 10:05:32.330	error	Caught by controller[0]: at Module._compile (module.js:652:30)
      host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3427:3)
      host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:22:28
      host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at require (internal/module.js:11:18)
      host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at Module.require (module.js:596:17)
      host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at Function.Module._load (module.js:474:25)
      host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at Function.Module._resolveFilename (module.js:547:15)
      host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: Error: Cannot find module 'coffee-compiler'
      host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: ^
      host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: throw err;
      host.raspberrypi	2018-11-23 10:05:32.328	error	Caught by controller[0]: module.js:549
      host.raspberrypi	2018-11-23 10:05:30.175	info	instance system.adapter.javascript.0 started with pid 2476
      host.raspberrypi	2018-11-23 10:05:00.143	info	Restart adapter system.adapter.javascript.0 because enabled
      host.raspberrypi	2018-11-23 10:05:00.142	error	instance system.adapter.javascript.0 terminated with code 1 ()
      Caught	2018-11-23 10:05:00.142	error	by controller[0]: at tryModuleLoad (module.js:505:12)
      Caught	2018-11-23 10:05:00.142	error	by controller[0]: at Module.load (module.js:565:32)
      Caught	2018-11-23 10:05:00.142	error	by controller[0]: at Object.Module._extensions..js (module.js:663:10)
      Caught	2018-11-23 10:05:00.142	error	by controller[0]: at Module._compile (module.js:652:30)
      Caught	2018-11-23 10:05:00.142	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3427:3)
      Caught	2018-11-23 10:05:00.142	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:22:28
      Caught	2018-11-23 10:05:00.142	error	by controller[0]: at require (internal/module.js:11:18)
      Caught	2018-11-23 10:05:00.142	error	by controller[0]: at Module.require (module.js:596:17)
      Caught	2018-11-23 10:05:00.141	error	by controller[0]: at Function.Module._load (module.js:474:25)
      Caught	2018-11-23 10:05:00.141	error	by controller[0]: at Function.Module._resolveFilename (module.js:547:15)
      Caught	2018-11-23 10:05:00.141	error	by controller[0]: Error: Cannot find module 'coffee-compiler'
      Caught	2018-11-23 10:05:00.141	error	by controller[0]: ^
      Caught	2018-11-23 10:05:00.141	error	by controller[0]: throw err;
      Caught	2018-11-23 10:05:00.140	error	by controller[0]: module.js:549
      host.raspberrypi	2018-11-23 10:04:57.939	info	instance system.adapter.javascript.0 started with pid 2470
      host.raspberrypi	2018-11-23 10:04:57.906	info	object change system.adapter.javascript.0</anonymous></anonymous>
      In der IO Broker Übersicht steht:
      raspberrypi
      Plattform: linux
      RAM: 927.1 MB
      Node.js: v8.11.1
      NPM: 1.4.21
        dna909 last edited by
        Installiere bitte mal eine neuere npm-Version.
        1.4.21 ist ja schon ein bissel sehr alt :lol:
        dna909
          Habe alles gestern erst aufgesetzt. Per SSH auf den Raspberry schalten. Und wie sind da die Befehle?
          • AlCalzone
            @Realleachim:
            Habe alles gestern erst aufgesetzt. Per SSH auf den Raspberry schalten. Und wie sind da die Befehle? `
            npm i -g npm
            möglicherweise muss <u>sudo</u> davor.
              Jetzt funktioniert es. Habe nun Version 6.4.1
              Habe genau nach Tutorial gearbeitet. Keine Ahnung was da passiert ist.
              Danke!
