    4. [Gelöst] Fehler bei Installation von Java/Blockly
      DJ-Mix last edited by
      ich erhalte folgende Fehlermeldung beim installieren von Blockly.
      Da ich Anfänger bin, bin ich ratlos.
      ` > $ ./iobroker add javascript
      NPM version: 4.6.1
      npm install iobroker.javascript –production --save --prefix "/opt/iobroker" (System call)
      npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      npm
      ERR! path /root/.npm/_logsnpm ERR! code EACCES
      npm ERR! errno -13
      npm ERR! syscall scandir
      npm ERR! Error: EACCES: permission denied, scandir '/root/.npm/_logs'npm ERR! { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
      npm ERR! errno: -13,
      npm ERR! code: 'EACCES',
      npm ERR! syscall: 'scandir',
      npm ERR! path: '/root/.npm/_logs' }
      npm ERR!
      npm
      ERR! Please try running this command again as root/Administrator.
      glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs' errno: -13,
      code: 'EACCES',
      syscall: 'scandir',
      npm ERR! path /root/.npm/long-timeout/0.1.1/packagenpm ERR! code EACCES
      npm ERR! errno -13
      npm
      ERR! syscall mkdirnpm ERR! Error: EACCES: permission denied, mkdir '/root/.npm/long-timeout/0.1.1/package'
      npm ERR! { Error: EACCES: permission denied, mkdir '/root/.npm/long-timeout/0.1.1/package'
      npm ERR! syscall: 'mkdir',
      npm ERR! path: '/root/.npm/long-timeout/0.1.1/package',
      npm ERR! parent: 'node-schedule' }
      npm ERR!
      npm ERR! Please try running this command again as root/Administrator.
      │ npm update check failed │
      │ Try running with sudo or get access │
      │ to the local update config store via │
      │ sudo chown -R $USER:$(id -gn $USER) /root/.config │
      npm
      ERR! code ELIFECYCLE
      npm ERR! errno 243
      npm ERR! iobroker.javascript@4.0.1 postinstall: node ./install/installTypings.jsnpm ERR! Exit status 243
      npm ERR! npm ERR! Failed at the iobroker.javascript@4.0.1 postinstall script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2018-12-03T19_28_53_634Z-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.javascript: 243
      ERROR: process exited with code 25 `
      Was kann ich hier tun, damit es funktioniert.
      Vielen Dank Vorab
      VG
      DJ-Mix
      Edit: Problem gelöst mit Anleitung hier im Forum (Java Beitrag).
      Nun habe ich jedoch das Problem, dass wenn ich ein Send To Objekt hinzufügen möchte erst die Cloud beenden muss, da es sonst
      nicht auswählbar ist???
      81.1k
