    4. You are sending to fast error im Log & CCU2 deswegen tot…
    • etv
      etv last edited by
      Liebe Leute,
      einen eher nicht so feinen (weil Heizung in der Nach tot) Fehler hatte ich letzte Nacht:
      ! 2016-01-11 01:22:01.199 - info: javascript.0 script.js.Spritpreise: –------------------ Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
      ! 2016-01-11 01:26:00.875 - info: host.etv-iob-main Delete log file iobroker.2016-01-04.log
      ! 2016-01-11 01:30:00.900 - info: admin.0 terminating http server on port 8081
      ! 2016-01-11 01:30:00.998 - info: web.0 terminating http server on port 8082
      ! 2016-01-11 01:30:01.004 - info: web.0 terminated http server on port 8082
      ! 2016-01-11 01:30:00.993 - info: hm-rpc.0 binrpc -> 192.168.68.222:2001 init ["xmlrpc_bin://192.168.68.223:2001",""]
      ! 2016-01-11 01:30:01.626 - info: pushbullet.0 cleaned everything up…
      ! 2016-01-11 01:30:02.515 - info: admin.0 terminating with timeout
      ! 2016-01-11 01:30:03.253 - info: pushbullet.0 terminating with timeout
      ! 2016-01-11 01:32:01.201 - info: javascript.0 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
      ! 2016-01-11 01:33:01.145 - info: hm-rpc.0 binrpc <- system.listMethods ["hm-rpc.0"]
      ! 2016-01-11 01:42:01.141 - info: javascript.0 script.js.Spritpreise: –------------------ Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
      ! 2016-01-11 01:52:01.254 - info: javascript.0 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
      ! 2016-01-11 01:33:01.185 - info: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
      ! 2016-01-11 01:58:31.179 - error: hm-rpc.0 Error: You are sending too fast
      ! 2016-01-11 02:00:01.186 - error: hm-rpc.0 Error: You are sending too fast
      ! 2016-01-11 02:01:31.190 - error: hm-rpc.0 Error: You are sending too fast
      ! 2016-01-11 02:02:01.145 - info: javascript.0 script.js.Spritpreise: –------------------ Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
      ! 2016-01-11 02:03:01.193 - error: hm-rpc.0 Error: You are sending too fast
      ! 2016-01-11 02:04:31.197 - error: hm-rpc.0 Error: You are sending too fast
      ! 2016-01-11 02:06:01.199 - error: hm-rpc.0 Error: You are sending too fast
      ! 2016-01-11 02:07:31.203 - error: hm-rpc.0 Error: You are sending too fast
      …und von da weg nun alle 1:30 diesen Fehler im Log...das Benzinpreis Script ist jedoch die ganze Nacht ohne Fehler durchgelaufen.
      Warum ist um 1:30 iobroker gestoppt worden? Alles bis auf Javascript war weg und zur selben Zeit hat sich dann die CCU2 aufgehängt und keinen einzigen Schaltbefehl mehr versendet. D.H. gelaufen ist die CCU in der Früh, ich konnte auch im WebUI Schaltbefehle absetzen, sie wurden aber nicht ausgeführt....detto ein Sync mit HomeDroid ist auch ohne Probleme gegangen, nur die States waren nicht richtig.
      Ein Reboot des Raspi's hat dann wieder alles auf "normal" gestellt und es ist wieder alles gelaufen.
      Ich hab im Forum schon gesucht und auch den Threat von pix gefunden, aber bei mir wird nix geschaltet und um diese Uhrzeit (1:30) läuft auch kein schedule.
      Einzig meine Anwesenheitserkennung ist da aktiv und seit gestern neu - das war sie aber auch schon den ganzen Abend und ich bin um 22:30 Uhr ins Bett = der Fehler trat erst 3 Stunden später auf, also schließe ich dieses Script auch aus (auch weil es alle 30 Sekunden ausgeführt wird) - trotzdem anbei das Script
      ! // Anwesenheitscheck - V1.5
      ! // wegen der Brösel rund um Tom's Telefon
      ! // mal ein Versuch, es hier zu lösen…
      ! // Ping geht OK = Tom da
      ! on ({id: "ping.0.etv-iob-main.192_168_68_31"/Telefon_Tom/, change: "gt" }, function () {
      ! // Tom ist anwesend
      ! setState("hm-rega.0.6457"/anwesend TOM/, true);
      ! log("------------------------------------------------Anwesenheit: TOM IST HIER --------------------------------------------------------------------");
      ! // anwesend = auch munter
      ! var tomSchlaeft = getState("hm-rega.0.7641"/schlafend TOM/).val;
      ! if (tomSchlaeft) {
      ! setState("hm-rega.0.7641"/schlafend TOM/, false);
      ! log("------------------------------------------------Anwesenheit: TOM IST munter --------------------------------------------------------------------");
      ! // tomZ zurück setzen auf 0
      ! setState("javascript.0.anwesend.Tom", 0);
      ! // Ping geht nicht OK - Tom weg oder Telefon schläft
      ! on ({id: "ping.0.etv-iob-main.192_168_68_31"/Telefon_Tom/, val: false }, function () {
      ! var ping = getState("ping.0.etv-iob-main.192_168_68_31"/Telefon_Tom/).val;
      ! var tomS = getState("hm-rega.0.7641"/schlafend TOM/).val;
      ! var tomZ = getState("javascript.0.anwesend.Tom").val;
      ! if (tomZ != 99) {
      ! // versuche das Telefon zu wecken - Version 1 mit dem TNES Tool
      ! var request = require('request');
      ! request.post({
      ! url: 'http://192.168.68.31:8765',
      ! form: { title: "wakmeup" }
      ! }, function(error, response, body) {
      ! if (error) log(info, 'error');
      ! tomZ = tomZ +1;
      ! log("------------------------------------------------Anwesenheit: Versuch das Telefon zu wecken Nr: " + tomZ + " --------------------------------------------------------------------");
      ! // wenn es 5x geweckt wurde und noch immer nicht reagiert, dann ist Tom weg!
      ! if (tomZ >= 5){
      ! setState("hm-rega.0.6457"/anwesend TOM/, false);
      ! log("------------------------------------------------Anwesenheit: TOM IST WEG --------------------------------------------------------------------");
      ! tomZ = 99;
      ! // ab 21:00 Uhr - Tom hat geht nun auch schlafen
      ! jetzt = new Date();
      ! var Std = jetzt.getHours();
      ! if (!tomS && Std.toFixed(0) >= 21) {
      ! log("------------------------------------------------Anwesenheit: TOM GEHT schlafen --------------------------------------------------------------------");
      ! setState("javascript.0.anwesend.Tom", tomZ);
      Mein Intervall beim hm.rega.0 ist default mit 30 Sekunden und beim h.rpc.0 kann man nix einstellen
      Hat wer eine Idee?
      etv
      • Thisoft
        Thisoft last edited by
        ja diesen bösen "You are sending too fast" error hatte ich auch schon. Ausgelöst wird der durch irgend eine Unpäßlichkeit des hm.rpc-Adapters. Dementsprechend kann man den Fehler auch beseitigen in dem man den RPC-Adapter einfach neu startet. IoBroker an sich ist deshalb keineswegs "tot" wie du auch daran siehst dass andere Scripte etc. weiterlaufen. Nur 😉 die Funkkommunikation zu Homematic ist tot.
        Was eigentlich den Fehler verursacht konnte ich bisher auch noch nicht nachvollziehen. Allerdings steht schon die Vermutung im Raum dass da vielleicht zu viele Funkbefehle zu kurz hintereinander gesendet werden sollen und deshalb die Homematic ihrerseits wegen DutyCycle o.ä. "zumacht". Einen Zusammenahng mit einem bestimmten Script konnte ich aber bisher trotz provozierender Tests auch noch nicht herstellen. Du kannst aber wenn der Fehler öfters auftaucht mal das Log-Level des RPC-Adapters auf "debug" stellen in der Hoffnung dass man dann im Log einen Zusammenhang entdecken könnte.
        Gruß Thilo
        • etv
          etv last edited by
          Servus Thilo,
          danke für die Info - das mit dem Debug-Level ist eine gute Idee!! Ich werd' mein System mal weiter beobachten - lief ja jetzt einige Wochen ohne gröbere Probleme - und sollte es erneut auftreten, werd' ich den Loglevel hoch drehen…
          etv
          4191_iobroker.log
          4191_einstellung_ohne_delay.pdf
          4191_testbeschreibung_version_21-b01.docx
          4191_heizungsscript_21b01_test.txt
            StefSign last edited by
            ich bin mir nicht sicher ob es auch in diese Richtung geht…
            Nach dem ich auf neue Hardware gesetzt habe, ein Intel NUC statt XU3, scheint dieser schnelle NUC die Homemtatic CCU2 regelrecht platt gemacht zu haben, soll heissen nach einiger Zeit konnte ich auf das Homematic Webinterface nicht mehr zugreifen und hm.rega.0 brachte Fehlermeldungen.
            Ich habe dann gestern alles (nach zwei Versuchen) wieder zurück auf den XU3 gestellt. Werde heute der Sache mal nach gehen und mir das Log genauer ansehen.
            Situation:
            • hm.rega.0 (hm.rega.1 für eine alte CCU nicht) brachte viele Fehler im ioBroker Log (viele Polling Timeouts)
            • Nodejs Version 4.x
            Kann eine schnellere ioBroker Plattform die CCU überlasten? Ein Polling von 30 Sekunden scheint mir nicht zu hoch, die Fehlermeldungen im Log tauchten aber im Sekunden Takt auf.
            BTW, der Umzug war einfach…alles per "tar" auf die neue Plattform und dann mittels "iobroker host this" den neuen Hostnamen übernehmen.
            Stefan
            • etv
              etv last edited by
              …meine Fehler hatte ich ziemlich genau alle 90 Sekunden - wo die her kommen ist mir sowieso ein Rätsel, weil ich eben auch den Pollintervall auf 30 Sekunden hab....
              Naja - weiter beobachten - wenn das einmal in zwei Monaten ist, dann ist's ja OK...läuft dann ja länger als so mancher Windows Rechner :lol:
              etv
              • etv
                etv last edited by
                Hurra….der Fehler ist wieder da - gestern um Punkt 18:00 Uhr hat sich iobroker wieder teilweise vertschüsst und die CCU lahm gelegt...
                ! 2016-01-15 17:32:01.134 - info: javascript.0 script.js.Spritpreise: –------------------ Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                ! 2016-01-15 17:42:00.995 - info: javascript.0 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                ! 2016-01-15 17:52:00.975 - info: javascript.0 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                ! 2016-01-15 18:00:00.240 - info: web.0 terminating http server on port 8082
                ! 2016-01-15 18:00:00.244 - info: web.0 terminated http server on port 8082
                ! 2016-01-15 10:50:41.603 - warn: admin.0 Reconnection to DB.
                ! 2016-01-15 18:00:00.261 - info: admin.0 terminating http server on port 8081
                ! 2016-01-15 10:50:46.568 - info: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
                ! 2016-01-15 10:50:46.740 - warn: hm-rpc.0 Reconnection to DB.
                ! 2016-01-15 18:00:00.288 - info: hm-rpc.0 binrpc -> 192.168.68.222:2001 init ["xmlrpc_bin://192.168.68.223:2001",""]
                ! 2016-01-15 18:00:00.823 - info: pushbullet.0 cleaned everything up…
                ! 2016-01-15 18:00:01.790 - info: admin.0 terminating with timeout
                ! 2016-01-15 18:00:02.332 - info: pushbullet.0 terminating with timeout
                ! 2016-01-15 18:02:00.928 - info: javascript.0 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                ! 2016-01-15 18:03:00.490 - info: hm-rpc.0 binrpc <- system.listMethods ["hm-rpc.0"]
                ! 2016-01-15 18:12:00.893 - info: javascript.0 script.js.Spritpreise: –------------------ Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                ! 2016-01-15 18:22:01.041 - info: javascript.0 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                ! 2016-01-15 18:03:00.528 - info: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
                ! 2016-01-15 18:28:30.529 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:30:00.537 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:31:30.540 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:32:01.010 - info: javascript.0 script.js.Spritpreise: –------------------ Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                ! 2016-01-15 18:33:00.543 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:34:30.546 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:36:00.548 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:37:30.551 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:39:00.554 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:40:30.557 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:42:00.560 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:42:01.158 - info: javascript.0 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                ! 2016-01-15 18:43:30.563 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:45:00.568 - error: hm-rpc.0 Error: You are sending too fast
                ! 2016-01-15 18:46:30.572 - error: hm-rpc.0 Error: You are sending too fast
                Wieder das selbe Spiel - web.0 terminiert, dann admin.0, dann verliert hm-rpc.0 seine Verbindung zur DB und das Spiel mit "you are sending too fast" geht los mit dem Effekt, dass die CCU nichts mehr schaltet…..
                Das einzige was normal weiter läuft ist javascript - mein Benzinpreis Script holt sich in regelmäßigen Abständen die aktuellen Preise, d.h. auch wieder, dass iobroker grundsätzlich noch läuft - nur die Schnittstellen nach außen (webinterface ud ccu) klappen alle nicht mehr - auch VIS zeigt "no connection" am Tablett an...
                Ich hab nun mal wie von Thisoft empfohlen den Loglevel auf debug gestellt - vielleicht findet sich ja da was drinnen....
                Grüße von einem frierenden, weil natürlich wieder keine Heizung gelaufen ist,
                etv
                  @etv:
                  etv `
                  Kannst du RAM mal beobachten?
                  • etv
                    etv last edited by
                    [quote="Bluefox"
                    OK, mach' ich - ich hoffe, dass er die Daten auch wegschreiben kann knapp bevor er dann hängt. Aktuell hat er 5% belegt.
                    Auf diesem Raspi ist nur ioBroker drauf, sonst nix und folgende Instanzen laufen:
                    Was hat es beim Daten Loggen (History) eigentlich mit der Entprellzeit? ich hab die beim Memory nun auf 1 Sekunde gestellt. Ist das sinnvoll/-los?
                    etv
                    • etv
                      etv last edited by
                      @Bluefox:
                      Kannst du RAM mal beobachten? `
                      Hallo Bluefox,
                      irgendwie stimmt der Wert den ich im Admin Panel zum Thema Memory sehe (system.host.etv-iob-main.mem) nicht mit der Realität überein, oder ist der Wert, das was gerade an Speicher frei ist??
                      Aktuell zeigt er mir 5% im Admin Panel an und laut top auf der Konsole sind ca. 40k von einem Gig frei….das würde ja fast hin kommen, oder?
                      Das ist der aktuelle Output von Top auf der Console
                      top - 17:33:47 up  6:48,  1 user,  load average: 0,10, 0,41, 0,61
                      Tasks: 110 total,   1 running, 109 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  2,6 us,  0,2 sy,  0,0 ni, 97,2 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
                      KiB Mem:    948108 total,   916580 used,    31528 free,   111148 buffers
                      KiB Swap:   102396 total,       56 used,   102340 free.   226108 cached Mem
                      Zeitgleich der Wert im Admin Panel: 3%
                      Heute ist web.0 und socketio auch wieder "baden gegangen" - ich war aber gerade auf der Console und hab gleich einen reboot gemacht - war ein Fehler, hätte warten sollen was weiter passiert 😄
                      Auf jeden Fall war da der Wert beim Speicher im SQL-Log bei 1% und da ist der crash gewesen….
                      Der Wert von 1% kommt aber des öfteren im Log vor, kann sein, dass es aus dieser Ecke kommt, oder?
                      Nachdem ich für die ioBroker App den socket-io Adapter laufen hab, hab ich jetzt mal den integrierten von web.0 "abgedreht" und bei web.0 auf den eigentlichen socket-io Adapter "umgeleitet"....
                      etv
                      • V
                        versteckt last edited by
                        Hallo etv, du setzt ja einen Raspi ein, installier doch den iobroker.rpi Adapter, und schalte dort die
                        History aktiv.
                        Dann hast du gleich mal alle relevanten Werte (Temperatur, CPU, Memory, Netzwerk) von deinem Raspi
                        und kannst dir das in Ruhe ansehen.
                        LG Christian
                        • etv
                          etv last edited by
                          Hallo Christian,
                          hab's gerade installiert mit "npm install https://github.com/husky-koglhof/iobrok … all/master" und auch nach iobroker neu starten finde ich den Adapter, bzw. die Instanz oder sonst was nicht...
                          vcgencmd hab ich in javascript geladen und der Ordner iobroker.rpi ist auch in den node-modules vorhanden
                          etv
                          • V
                            Siehst du in der Objekte Lasche etwas vom rpi Adapter?
                            Gesendet von meinem iPhone mit Tapatalk
                            • N
                              nobody last edited by
                              Hi
                              war bei mir auch so.
                              Versuche mal
                              Iobroker upload rpi
                              iobroker add rpi
                              über die Konsole.
                              Gesendet von meinem SM-G900F mit Tapatalk
                              • etv
                                etv last edited by
                                @nobody:
                                Iobroker upload rpi
                                iobroker add rpi `
                                ..danke nobody - das hat geholfen!
                                @versteckt:
                                Siehst du in der Objekte Lasche etwas vom rpi Adapter? `
                                …nein da war nichts, aber jetzt ist der Adapter da und es funzt!
                                Der Adapter ist der Hit!! 😄
                                Ich hab nun mal memory_free und load5 zur History hinzugefügt...schauen wir mal, was sich da so tut.
                                Temperatur ist bei 48° bei geschlossenem Gehäuse, habs nun aufgemacht (und gleich nur mehr 43°) - die werd' ich nicht überwachen, da ist denke ich keine Gefahr
                                Danke euch!
                                etv
                                • V
                                  Hallo etv!
                                  Das freut mich, genau deswegen habe ich ihn entwickelt. Bei mir war auch das Temperaturthema
                                  und ist nun gelöst.
                                  LG Christian
                                    aquapro last edited by
                                    @StefSign:
                                    Nach dem ich auf neue Hardware gesetzt habe, ein Intel NUC statt XU3, scheint dieser schnelle NUC die Homemtatic CCU2 regelrecht platt gemacht zu haben, soll heissen nach einiger Zeit konnte ich auf das Homematic Webinterface nicht mehr zugreifen und hm.rega.0 brachte Fehlermeldungen. `
                                    Hallo Stefan,
                                    kurze Frage, welches NUC hast Du und welches OS? Ich will auch umsteigen, wegen dem zu geringen Speicher vom Pi, nur befürchte ich genau Deine genannten Probleme.
                                    Teile von iobroker gehen noch etwas größzügig mit Speicher um. Deshalb muss der Pi bei mir weg, wenn ich noch weiter mit iobroker testen will. Verteilt auf mehrere Pi ist auch sehr anfällig. Je nachdem wie die Situation ist, gibt es ein munteres starten und stoppen der Adapter, aber das ist ein anderes Thema.
                                    Tino
                                      @versteckt:
                                      Hallo etv!
                                      und ist nun gelöst.
                                      LG Christian `
                                      Hallo Christian,
                                      kannst auch einen für die Banane aus dem Hut zaubern? 😉
                                      Tino
                                      • etv
                                        etv last edited by
                                        @versteckt:
                                        Hallo etv!
                                        und ist nun gelöst.
                                        LG Christian `
                                        …einmal bin ich noch lästig 😄
                                        Ich hab folgende Werte im rpi-Adapter angehackerlt
                                        • CPU
                                        • Raspberry
                                        • Speicher
                                        • Temperatur
                                        Ich bekomm beim Speicher regelmäbige Updates aber bei den CPU Werten nicht. Temperatur ändert sich auch, die Raspberry Werte sind sowieso statisch, bis auf die Spannung nehme ich an....
                                        Aber warum tut sich bei den CPU Werten (load1, load5 und load15) nix?
                                        etv
                                        • V
                                          BananaPi ist doch grundsätzlich zu Raspberry Pi kompatibel.
                                          Das bedeutet, das du eigentlich den Adapter verwenden kannst.
                                          Die "Raspberry" Checkbox bitte nicht verwenden, dies muss ich mir erst ansehen.
                                          LG Christian
                                          • etv
                                            etv last edited by
                                            @Bluefox:
                                            Hallo Bluefox,
                                            RAM hab ich die letzten Tage versucht zu loggen (siehe weiter oben), zum Schluss mit dem rpi-Adapter von Christian, doch leider hilft es nix, weil das Logging auch abschmiert…jedoch nicht bis zum Blockieren der CCU!!
                                            Hier der LOG des heutigen Absturzes - zur Abfolge:
                                            • alles läuft OK,
                                            • um 15:30 geht es los mit info: hm-rpc.0 binrpc -> 192.168.68.222:2001 init ["xmlrpc_bin://192.168.68.223:2001",""]
                                            • danach stürzen ein paar Adaopter ab, man kommt nicht mehr auf admin via Browser
                                            • auf der Console via SSH schau ich mit tail mit…
                                            • über eine Stunde passiert nix, außer dass jacasvript Programme normal laufen
                                            • dann gebe ich auf der Console "iobroker start" ein und ab geht die Post...siehe ab 16:43
                                            • da geht dann gar nix mehr, kein admin via Browser und SSH Verbindung bricht ab (wegen Timeout)
                                            • das hab ich mir dann 13 Minuten angeschaut und dand den Raspi ausgesteckt und neu gestartet...
                                            • jo - und jetzt läuft wieder alles...
                                            ! 2016-01-19 15:22:01.733 - info: javascript.1 script.js.Spritpreise: –------------------ Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                                            ! 2016-01-19 15:28:14.554 - info: socketio.0 sendTo "getHistory" to system.adapter.sql.0 from system.adapter.socketio.0: {"id":"hm-rpc.0.LEQ0099321.1.TEMPERATURE","options":{"start":1453192184,"end":1453213784,"ignoreNull":false,"aggregate":"average","step":"300","instance":"sql.0"}}
                                            ! 2016-01-19 15:28:14.934 - info: sql.0 Send: 72 of: 139 in: 364ms
                                            ! 2016-01-19 15:28:14.938 - info: sql.0 sendTo "getHistory" to system.adapter.socketio.0 from system.adapter.sql.0: {"result":[{"ts":1453192334,"val":null},{"ts":1453192634,"val":-7.5},{"ts":1453192934,"val":-7.15},{"ts":1453193234,"val":-6.95},{"ts":1453193534,"val":-6.8},{"ts":1453193834,"val":-6.6},{"ts":1453194134,"val":-6.4},{"ts":1453194434,"val":-6.1},{"ts":1453194734,"val":-5.95},{"ts":1453195034,"val":-5.8},{"ts":1453195334,"val":-5.7},{"ts":1453195634,"val":-5.5},{"ts":1453195934,"val":-5.4},{"ts":1453196234,"val":-5.2},{"ts":1453196534,"val":-5.2},{"ts":1453196834,"val":-5.1},{"ts":1453197134,"val":-4.95},{"ts":1453197434,"val":-4.8},{"ts":1453197734,"val":-4.75},{"ts":1453198034,"val":-4.6},{"ts":1453198334,"val":-4.45},{"ts":1453198634,"val":-4.4},{"ts":1453198934,"val":-4.3},{"ts":1453199234,"val":-4.3},{"ts":1453199534,"val":-4.15},{"ts":1453199834,"val":-3.95},{"ts":1453200134,"val":-3.8},{"ts":1453200434,"val":-3.65},{"ts":1453200734,"val":-3.5},{"ts":1453201034,"val":-3.4},{"ts":1453201334,"val":-3.25},{"ts":1453201634,"val":-3.15},{"ts":1453201934,"val":-3},{"ts":1453202234,"val":-2.95},{"ts":1453202534,"val":-2.8},{"ts":1453202834,"val":-2.6},{"ts":1453203134,"val":-2.55},{"ts":1453203434,"val":-2.4},{"ts":1453203734,"val":-2.25},{"ts":1453204034,"val":-2.2},{"ts":1453204334,"val":-2.1},{"ts":1453204634,"val":-2.1},{"ts":1453204934,"val":-1.95},{"ts":1453205234,"val":-1.9},{"ts":1453205534,"val":-1.85},{"ts":1453205834,"val":-1.8},{"ts":1453206134,"val":-1.7},{"ts":1453206434,"val":-1.6},{"ts":1453206734,"val":-1.5},{"ts":1453207034,"val":-1.4},{"ts":1453207334,"val":-1.4},{"ts":1453207634,"val":-1.35},{"ts":1453207934,"val":-1.25},{"ts":1453208234,"val":-1.2},{"ts":1453208534,"val":-1.1},{"ts":1453208834,"val":-1.03},{"ts":1453209134,"val":-1},{"ts":1453209434,"val":-1},{"ts":1453209734,"val":-1},{"ts":1453210034,"val":-1.05},{"ts":1453210334,"val":-1.2},{"ts":1453210634,"val":-1.2},{"ts":1453210934,"val":-1.2},{"ts":1453211234,"val":-1.2},{"ts":1453211534,"val":-1.2},{"ts":1453211834,"val":-1.25},{"ts":1453212134,"val":-1.3},{"ts":1453212434,"val":-1.35},{"ts":1453212734,"val":-1.4},{"ts":1453213034,"val":-1.4},{"ts":1453213334,"val":-1.45},{"ts":1453213634,"val":-1.5}],"step":300,"error":null}
                                            ! 2016-01-19 15:30:00.770 - info: hm-rpc.0 binrpc -> 192.168.68.222:2001 init ["xmlrpc_bin://192.168.68.223:2001",""]
                                            ! 2016-01-19 15:30:01.006 - info: admin.0 terminating http server on port 8081
                                            ! 2016-01-19 15:30:01.034 - info: socketio.0 terminating http server on port 8084
                                            ! 2016-01-19 15:30:01.187 - info: web.0 terminating http server on port 8082
                                            ! 2016-01-19 15:30:01.663 - info: web.0 terminated http server on port 8082
                                            ! 2016-01-19 15:30:03.208 - info: admin.0 terminating with timeout
                                            ! 2016-01-19 15:30:05.215 - info: pushbullet.0 cleaned everything up…
                                            ! 2016-01-19 15:30:07.541 - info: pushbullet.0 terminating with timeout
                                            ! 2016-01-19 15:33:15.031 - info: socketio.0 sendTo "getHistory" to system.adapter.sql.0 from system.adapter.socketio.0: {"id":"hm-rpc.0.LEQ0099321.1.TEMPERATURE","options":{"start":1453213784,"end":1453214084,"ignoreNull":false,"aggregate":"average","count":1,"instance":"sql.0"}}
                                            ! 2016-01-19 15:42:00.895 - info: javascript.1 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                                            ! 2016-01-19 16:02:00.831 - info: javascript.1 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                                            ! 2016-01-19 16:22:00.907 - info: javascript.1 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                                            ! 2016-01-19 16:42:00.833 - info: javascript.1 script.js.Spritpreise: -------------------- Spritpreise eingelesen - �AMTC-Spritfeed: Billigste Diesel-Tankstellen (Steiermark) Anzahl: 25
                                            ! 2016-01-19 16:43:14.727 - info: host.etv-iob-main iobroker.js-controller version 0.8.2 js-controller starting
                                            ! 2016-01-19 16:43:14.751 - info: host.etv-iob-main Copyright (c) 2014-2015 bluefox, hobbyquaker
                                            ! 2016-01-19 16:43:14.755 - info: host.etv-iob-main hostname: etv-iob-main
                                            ! 2016-01-19 16:43:14.756 - info: host.etv-iob-main ip addresses: 192.168.68.223 fe80::d289:1043:c916:ee58
                                            ! 2016-01-19 16:43:14.887 - info: inMem-states listening on port 9000
                                            ! 2016-01-19 16:43:15.306 - info: inMem-objects listening on port 9001
                                            ! 2016-01-19 16:43:15.335 - info: host.etv-iob-main InMemoryDB connected
                                            ! 2016-01-19 16:43:15.373 - info: host.etv-iob-main 27 instances found
                                            ! 2016-01-19 16:43:15.380 - info: host.etv-iob-main starting 19 instances
                                            ! 2016-01-19 16:43:15.515 - info: host.etv-iob-main instance system.adapter.admin.0 started with pid 13204
                                            ! 2016-01-19 16:43:16.245 - warn: javascript.1 Reconnection to DB.
                                            ! 2016-01-19 16:43:16.427 - warn: javascript.1 Reconnection to DB.
                                            ! 2016-01-19 16:43:16.594 - warn: hm-rpc.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:17.615 - warn: hm-rega.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:17.920 - warn: hm-rega.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:18.909 - warn: socketio.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:20.087 - info: host.etv-iob-main instance system.adapter.javascript.0 started with pid 13209
                                            ! 2016-01-19 16:43:20.838 - warn: web.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:20.825 - warn: javascript.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:20.850 - warn: rpi.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:21.506 - warn: javascript.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:21.589 - warn: web.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:21.646 - warn: rpi.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:30.925 - error: admin.0 no connection to objects DB
                                            ! 2016-01-19 16:43:32.319 - info: host.etv-iob-main instance system.adapter.hm-rpc.0 started with pid 13218
                                            ! 2016-01-19 16:43:32.492 - error: javascript.0 no connection to objects DB
                                            ! 2016-01-19 16:43:32.417 - info: host.etv-iob-main instance system.adapter.hm-rega.0 started with pid 13219
                                            ! 2016-01-19 16:43:32.556 - info: host.etv-iob-main instance system.adapter.web.0 started with pid 13228
                                            ! 2016-01-19 16:46:15.046 - error: xhr poll error
                                            ! 2016-01-19 16:46:15.060 - error: Error: xhr poll error
                                            ! at XHR.Transport.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:66:13)
                                            ! at Request. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:122:10)
                                            ! at Request.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
                                            ! at Request.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:278:8)
                                            ! at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:225:18)
                                            ! at Timer.listOnTimeout (timers.js:119:15)
                                            ! 2016-01-19 16:46:19.929 - error: hm-rpc.0 no connection to objects DB
                                            ! 2016-01-19 16:46:19.934 - error: hm-rega.0 no connection to objects DB
                                            ! 2016-01-19 16:46:28.490 - warn: web.0 Reconnection to DB.
                                            ! 2016-01-19 16:46:13.032 - info: host.etv-iob-main instance system.adapter.sql.0 started with pid 13250
                                            ! 2016-01-19 16:46:13.330 - info: host.etv-iob-main instance scheduled system.adapter.ical.0 0,30 * * * *
                                            ! 2016-01-19 16:52:13.138 - warn: hm-rega.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:16.952 - warn: hm-rpc.0 Reconnection to DB.
                                            ! 2016-01-19 16:52:13.157 - warn: hm-rpc.0 Reconnection to DB.
                                            ! 2016-01-19 16:52:13.271 - warn: web.0 Reconnection to DB.
                                            ! 2016-01-19 16:43:18.964 - warn: socketio.0 Reconnection to DB.
                                            ! 2016-01-19 16:52:13.355 - warn: socketio.0 Reconnection to DB.
                                            ! 2016-01-19 16:52:13.481 - warn: javascript.0 Reconnection to DB.
                                            ! 2016-01-19 16:52:13.889 - warn: javascript.1 Reconnection to DB.
                                            ! 2016-01-19 16:46:13.404 - info: host.etv-iob-main instance system.adapter.ical.0 started with pid 13256
                                            ! 2016-01-19 16:46:13.550 - info: host.etv-iob-main instance scheduled system.adapter.ical.1 7 6 * * *
                                            ! 2016-01-19 16:52:14.051 - warn: hm-rega.0 Reconnection to DB.
                                            ! 2016-01-19 16:52:14.094 - warn: hm-rpc.0 Reconnection to DB.
                                            ! 2016-01-19 16:52:14.121 - warn: socketio.0 Reconnection to DB.
                                            ! 2016-01-19 16:52:14.129 - warn: javascript.0 Reconnection to DB.
                                            ! 2016-01-19 16:52:14.220 - warn: web.0 Reconnection to DB.
                                            ! 2016-01-19 16:52:14.191 - warn: javascript.1 Reconnection to DB.
                                            ! 2016-01-19 16:46:13.645 - info: host.etv-iob-main instance system.adapter.ical.1 started with pid 13257
                                            ! 2016-01-19 16:46:14.101 - info: host.etv-iob-main instance system.adapter.socketio.0 started with pid 13265
                                            ! 2016-01-19 16:46:14.516 - info: host.etv-iob-main instance system.adapter.pushbullet.0 started with pid 13288
                                            ! 2016-01-19 16:46:15.047 - info: host.etv-iob-main instance system.adapter.ping.0 started with pid 13295
                                            ! 2016-01-19 16:46:15.381 - info: host.etv-iob-main instance system.adapter.sayit.0 started with pid 13300
                                            ! 2016-01-19 16:46:19.648 - info: host.etv-iob-main instance system.adapter.rpi.0 started with pid 13301
                                            ! 2016-01-19 16:46:20.427 - info: host.etv-iob-main instance system.adapter.javascript.1 started with pid 13319
                                            ! 2016-01-19 16:17:21.924 - info: host.etv-iob-main iobroker.js-controller version 0.8.2 js-controller starting
                                            ! 2016-01-19 16:17:21.949 - info: host.etv-iob-main Copyright (c) 2014-2015 bluefox, hobbyquaker
                                            ! 2016-01-19 16:17:21.953 - info: host.etv-iob-main hostname: etv-iob-main
                                            ! 2016-01-19 16:17:21.954 - info: host.etv-iob-main ip addresses: 192.168.68.223 fe80::d289:1043:c916:ee58
                                            ! 2016-01-19 16:17:22.110 - info: inMem-states listening on port 9000
                                            ! 2016-01-19 16:56:37.729 - info: inMem-objects listening on port 9001
                                            ! 2016-01-19 16:56:37.758 - info: host.etv-iob-main InMemoryDB connected
                                            ! 2016-01-19 16:56:37.801 - info: host.etv-iob-main 27 instances found
                                            ! 2016-01-19 16:56:37.809 - info: host.etv-iob-main starting 19 instances
                                            ! 2016-01-19 16:56:37.948 - info: host.etv-iob-main instance system.adapter.admin.0 started with pid 1305
                                            ! 2016-01-19 16:56:41.894 - info: host.etv-iob-main instance system.adapter.javascript.0 started with pid 1311
                                            ! 2016-01-19 16:56:45.893 - info: host.etv-iob-main instance system.adapter.hm-rpc.0 started with pid 1320
                                            ! 2016-01-19 16:56:48.639 - info: admin.0 starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.admin
                                            ! 2016-01-19 16:56:48.847 - info: admin.0 requesting all states
                                            ! 2016-01-19 16:56:48.857 - info: admin.0 requesting all objects
                                            ! 2016-01-19 16:56:48.864 - info: admin.0 Request actual repository...
                                            ! 2016-01-19 16:56:48.872 - info: admin.0 http server listening on port 8081
                                            ! 2016-01-19 16:56:48.874 - info: admin.0 Use link "http://localhost:8081" to configure.
                                            ! 2016-01-19 16:56:50.085 - info: host.etv-iob-main instance system.adapter.hm-rega.0 started with pid 1329
                                            ! 2016-01-19 16:56:50.764 - info: admin.0 received all states
                                            ! 2016-01-19 16:56:51.066 - info: javascript.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.javascript
                                            ! 2016-01-19 16:56:51.125 - info: javascript.0 requesting all states
                                            ! 2016-01-19 16:56:51.138 - info: javascript.0 requesting all objects
                                            ! 2016-01-19 16:56:51.027 - info: hm-rpc.0 starting. Version 0.5.2 in /opt/iobroker/node_modules/iobroker.hm-rpc
                                            ! 2016-01-19 16:56:51.702 - info: admin.0 received all objects
                                            ! 2016-01-19 16:56:52.585 - info: host.etv-iob-main Update repository "default" under "conf/sources-dist.json"</anonymous>
                                            Irgendwelche Ideen - außer neu installieren 😄
                                            etv
                                            102
                                            16993
