    4. Banana eingerfroren mit iobroker log Fehlermeldungen
      rascal last edited by
      hey,
      in der Nacht hat sich der banana mit iobroker drauf verabschiedet, er läuft erst seit 2 Tagen oder so… vielleicht hilft das Log ja irgendwie:
      squeezebox-0	2016-01-14 08:09:19	info	Got event from b8:27:eb:06:7c:c3: duration 0
      squeezebox-0	2016-01-14 08:09:19	info	Got event from 02:58:09:83:0e:b1: duration 0
      squeezebox-0	2016-01-14 08:08:49	info	Got event from b8:27:eb:06:7c:c3: duration 0
      squeezebox-0	2016-01-14 08:08:49	info	Got event from 02:58:09:83:0e:b1: duration 0
      squeezebox-0	2016-01-14 08:08:19	info	Got event from b8:27:eb:06:7c:c3: duration 0
      squeezebox-0	2016-01-14 08:08:19	info	Got event from 02:58:09:83:0e:b1: duration 0
      squeezebox-0	2016-01-14 08:07:49	info	Got event from b8:27:eb:06:7c:c3: duration 0
      squeezebox-0	2016-01-14 08:07:49	info	Got event from 02:58:09:83:0e:b1: duration 0
      host-Dachbodenraum	2016-01-14 08:07:32	info	instance system.adapter.node-red.0 terminated with code 0 (OK)
      node-red-0	2016-01-14 08:07:32	info	terminating
      host-Dachbodenraum	2016-01-14 08:07:32	info	stopInstance system.adapter.node-red.0 killing pid 666
      node-red-0	2016-01-14 08:07:31	info	node-red exited with null
      node-red-0	2016-01-14 08:07:31	info	kill node-red task
      host-Dachbodenraum	2016-01-14 08:07:31	info	stopInstance system.adapter.node-red.0
      host-Dachbodenraum	2016-01-14 08:07:31	info	object change system.adapter.node-red.0
      admin-0	2016-01-14 08:07:21	info	Repository received successfully.
      node-red-0	2016-01-14 08:07:20	info	Starting node-red: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      squeezebox-0	2016-01-14 08:07:20	info	Got event from b8:27:eb:06:7c:c3: duration 0
      squeezebox-0	2016-01-14 08:07:20	info	Got event from 02:58:09:83:0e:b1: duration 0
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:06:7c:c3: time 71.1648589935303
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:06:7c:c3: duration 0
      squeezebox-0	2016-01-14 08:07:18	info	Got event from 02:58:09:83:0e:b1: time 71.0872098770142
      squeezebox-0	2016-01-14 08:07:18	info	Got event from 02:58:09:83:0e:b1: duration 0
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:06:7c:c3: status 0 1 tags:K player_name:Kueche-und-Garage player_connected:1 player_ip:192.168.1.51:50848 power:1 signalstrength:0 mode:play remote:1 current_title:Radio Wien
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:06:7c:c3: album
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:06:7c:c3: artist
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:06:7c:c3: mixer muting
      squeezebox-0	2016-01-14 08:07:18	info	Got event from 02:58:09:83:0e:b1: status 0 1 tags:K player_name:Dachbodenraum player_connected:1 player_ip:192.168.1.54:39442 power:1 signalstrength:0 mode:play remote:1 current_title:Radio Wien time
      squeezebox-0	2016-01-14 08:07:18	info	Got event from 02:58:09:83:0e:b1: album
      squeezebox-0	2016-01-14 08:07:18	info	Got event from 02:58:09:83:0e:b1: artist
      squeezebox-0	2016-01-14 08:07:18	info	Got event from 02:58:09:83:0e:b1: mixer muting
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:ef:c0:24: status 0 1 tags:K player_name:WC-oben player_connected:1 player_ip:192.168.1.53:46742 power:0 signalstrength:0 mode:stop remote:1 current_title:Radio Wien time:70.62
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:ef:c0:24: album
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:ef:c0:24: artist
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:ef:c0:24: mixer muting
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:49:e2:37: status 0 1 tags:K player_name:Badezimmer player_connected:1 player_ip:192.168.1.52:49807 power:0 signalstrength:0 mode:stop remote:1 current_title:Radio Wien time:70
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:49:e2:37: album
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:49:e2:37: artist
      squeezebox-0	2016-01-14 08:07:18	info	Got event from b8:27:eb:49:e2:37: mixer muting
      squeezebox-0	2016-01-14 08:07:18	info	httpport: 9000
      squeezebox-0	2016-01-14 08:07:18	info	Found player b8:27:eb:06:7c:c3
      squeezebox-0	2016-01-14 08:07:18	info	Found player 02:58:09:83:0e:b1
      squeezebox-0	2016-01-14 08:07:18	info	Found player b8:27:eb:ef:c0:24
      squeezebox-0	2016-01-14 08:07:18	info	Found player b8:27:eb:49:e2:37
      squeezebox-0	2016-01-14 08:07:18	info	creating/updating player channels
      node-red-0	2016-01-14 08:07:17	info	starting. Version 0.3.5 in /opt/iobroker/node_modules/iobroker.node-red
      squeezebox-0	2016-01-14 08:07:17	info	starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.squeezebox
      squeezebox-0	2016-01-14 08:07:15	error	no connection to states DB
      hm-rpc-0	2016-01-14 08:07:14	info	xmlrpc -> 405 devices
      host-Dachbodenraum	2016-01-14 08:07:13	warn	warning: Timeout by read all package.json (62) seconds
      hm-rpc-0	2016-01-14 08:07:12	info	xmlrpc <- listDevices ["hm-rpc.0"]
      hm-rpc-0	2016-01-14 08:07:12	info	xmlrpc -> 192.168.1.4:2001 init ["http://192.168.1.54:2001","hm-rpc.0"]
      hm-rpc-0	2016-01-14 08:07:12	info	xmlrpc server is trying to listen on 192.168.1.54:2001
      node-red-0	2016-01-14 08:07:09	error	no connection to states DB
      squeezebox-0	2016-01-14 08:07:08	error	no connection to objects DB
      hm-rega-0	2016-01-14 08:07:07	info	got state values
      hm-rega-0	2016-01-14 08:07:05	info	request state values
      hm-rega-0	2016-01-14 08:07:05	info	deleted 0 variables
      hm-rega-0	2016-01-14 08:07:05	info	added/updated 53 variables
      hm-rega-0	2016-01-14 08:07:05	info	got 53 variables
      host-Dachbodenraum	2016-01-14 08:07:04	info	instance system.adapter.vis-google-fonts.0 terminated while should be started once
      node-red-0	2016-01-14 08:07:02	error	no connection to objects DB
      hm-rega-0	2016-01-14 08:07:01	info	deleted 0 programs
      hm-rega-0	2016-01-14 08:07:01	info	added/updated 25 programs
      hm-rega-0	2016-01-14 08:07:01	info	got 25 programs
      host-Dachbodenraum	2016-01-14 08:07:00	info	instance system.adapter.vis.0 terminated while should be started once
      host-Dachbodenraum	2016-01-14 08:06:59	info	instance system.adapter.squeezebox.0 started with pid 677
      hm-rpc-0	2016-01-14 08:06:54	info	starting. Version 0.5.2 in /opt/iobroker/node_modules/iobroker.hm-rpc
      vis-google-fonts-0	2016-01-14 08:06:53	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.vis-google-fonts
      host-Dachbodenraum	2016-01-14 08:06:52	info	instance system.adapter.node-red.0 started with pid 666
      hm-rega-0	2016-01-14 08:06:42	info	added/updated rooms to enum.rooms
      hm-rega-0	2016-01-14 08:06:42	info	added/updated functions to enum.functions
      hm-rega-0	2016-01-14 08:06:41	info	added/updated 1 favorites to enum.favorites
      hm-rega-0	2016-01-14 08:06:41	info	time difference local-ccu 1s
      hm-rega-0	2016-01-14 08:06:41	info	ReGaHSS 192.168.1.4 up
      hm-rega-0	2016-01-14 08:06:34	info	subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
      hm-rega-0	2016-01-14 08:06:34	info	starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.hm-rega
      vis-0	2016-01-14 08:06:31	info	starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.vis
      host-Dachbodenraum	2016-01-14 08:06:35	info	Update repository "default" under "conf/sources-dist.json"
      admin-0	2016-01-14 08:06:35	info	received all objects
      web-0	2016-01-14 08:06:33	info	http server listening on port 8082
      web-0	2016-01-14 08:06:33	info	socket.io server listening on port 8082
      web-0	2016-01-14 08:06:27	info	starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.web
      admin-0	2016-01-14 08:06:33	info	received all states
      host-Dachbodenraum	2016-01-14 08:06:31	info	instance system.adapter.hm-rpc.0 started with pid 592
      admin-0	2016-01-14 08:06:28	info	Use link "http://localhost:8081" to configure.
      admin-0	2016-01-14 08:06:28	info	http server listening on port 8081
      admin-0	2016-01-14 08:06:28	info	Request actual repository...
      admin-0	2016-01-14 08:06:28	info	requesting all objects
      admin-0	2016-01-14 08:06:28	info	requesting all states
      admin-0	2016-01-14 08:06:27	info	starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.admin
      host-Dachbodenraum	2016-01-14 08:06:26	info	instance system.adapter.hm-rega.0 started with pid 581
      host-Dachbodenraum	2016-01-14 08:06:18	info	instance system.adapter.web.0 started with pid 575
      host-Dachbodenraum	2016-01-14 08:06:14	info	instance system.adapter.admin.0 started with pid 572
      host-Dachbodenraum	2016-01-14 08:06:14	info	starting 11 instances
      host-Dachbodenraum	2016-01-14 08:06:14	info	19 instances found
      host-Dachbodenraum	2016-01-14 08:06:14	info	InMemoryDB connected
      inMem-objects	2016-01-14 08:06:14	info	listening on port 9001
      inMem-states	2016-01-14 08:06:13	info	listening on port 9000
      Cannot	2016-01-14 08:06:13	error	parse /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json.bak: SyntaxError: Unexpected end of input
      Cannot	2016-01-14 08:06:13	error	parse /opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: SyntaxError: Unexpected end of input
      host-Dachbodenraum	2016-01-14 08:06:13	info	ip addresses: 192.168.1.54 fe80::58:9ff:fe83:eb1
      host-Dachbodenraum	2016-01-14 08:06:13	info	hostname: Dachbodenraum
      host-Dachbodenraum	2016-01-14 08:06:13	info	Copyright (c) 2014-2015 bluefox, hobbyquaker
      host-Dachbodenraum	2016-01-14 08:06:13	info	iobroker.js-controller version 0.8.2 js-controller starting
      squeezebox-0	2016-01-14 00:24:29	info	Got event from 02:58:09:83:0e:b1: album
      squeezebox-0	2016-01-14 00:24:29	info	Got event from 02:58:09:83:0e:b1: artist
      squeezebox-0	2016-01-14 00:24:29	info	Got event from 02:58:09:83:0e:b1: playlist stop
      squeezebox-0	2016-01-14 00:23:22	info	Got event from 02:58:09:83:0e:b1: prefset server snLastSyncUp 1452727402
      squeezebox-0	2016-01-14 00:22:52	info	Got event from 02:58:09:83:0e:b1: album
      squeezebox-0	2016-01-14 00:22:52	info	Got event from 02:58:09:83:0e:b1: artist
      squeezebox-0	2016-01-14 00:22:52	info	Got event from 02:58:09:83:0e:b1: menustatus ARRAY(0x8b4ed88) add 02:58:09:83:0e:b1
      squeezebox-0	2016-01-14 00:22:52	info	Got event from 02:58:09:83:0e:b1: prefset server power 0
      squeezebox-0	2016-01-14 00:22:52	info	Got event from 02:58:09:83:0e:b1: menustatus ARRAY(0x8866c38) add 02:58:09:83:0e:b1
      squeezebox-0	2016-01-14 00:22:52	info	Got event from 02:58:09:83:0e:b1: playlist pause 1
      squeezebox-0	2016-01-14 00:22:52	info	Got event from b8:27:eb:06:7c:c3: menustatus ARRAY(0x8b70218) add b8:27:eb:06:7c:c3
      squeezebox-0	2016-01-14 00:22:52	info	Got event from b8:27:eb:ef:c0:24: menustatus ARRAY(0x8b5d5b8) add b8:27:eb:ef:c0:24
      squeezebox-0	2016-01-14 00:22:52	info	Got event from b8:27:eb:49:e2:37: menustatus ARRAY(0x878c1e8) add b8:27:eb:49:e2:37
      squeezebox-0	2016-01-14 00:22:45	info	Got event from b8:27:eb:06:7c:c3: menustatus ARRAY(0x8b6fa80) add b8:27:eb:06:7c:c3
      • sissiwup
        sissiwup last edited by
        dazu brauchst du das Linux-Log.
        Hast du mal deinen Speicher beobachtet?
        Kannst du auch einfach loggen und dann nachträglich anschauen, ob der das Problem ist.
        Wenns der Speicher ist: Swap mal auf 2 GB hochsetzen.
        Läuft dann zwar sehr langsam, wenn er swap braucht, bleibt aber nicht stehen.
