    4. [fixed] Cannot download json from https://raw.githubus
    • derAuge
      derAuge last edited by
      Bei der Installation vom ioBroker Adapter "web" erscheinen folgende Fehlermeldungen:
      Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker***************
      Danach wird jedoch der Adapter installiert.
      Hier das gesamte log:
      ! web.0 2015-03-05 18:42:25 info starting. Version 0.2.5 in /root/DS/iobroker/node_modules/iobroker.web
      ! iobroker 2015-03-05 18:42:24 info exit 0
      ! iobroker 2015-03-05 18:42:24 info object system.adapter.web.0 created
      ! host.ioBroker 2015-03-05 18:42:24 info instance system.adapter.web.0 started with pid 3464
      ! host.ioBroker 2015-03-05 18:42:24 info object change system.adapter.web.0
      ! iobroker 2015-03-05 18:42:24 info object system.adapter.web.0.alive created
      ! iobroker 2015-03-05 18:42:24 info object system.adapter.web.0.connected created
      ! iobroker 2015-03-05 18:42:24 info object system.adapter.web.0.memHeapUsed created
      ! iobroker 2015-03-05 18:42:24 info object system.adapter.web.0.memHeapTotal created
      ! iobroker 2015-03-05 18:42:24 info object system.adapter.web.0.memRss created
      ! iobroker 2015-03-05 18:42:24 info object system.adapter.web.0.uptime created
      ! iobroker 2015-03-05 18:42:24 info create instance web
      ! iobroker 2015-03-05 18:42:24 info object connected created
      ! iobroker 2015-03-05 18:42:24 info object system.adapter.web created
      ! iobroker 2015-03-05 18:42:24 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
      ! iobroker 2015-03-05 18:42:24 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
      ! iobroker 2015-03-05 18:42:24 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
      ! iobroker 2015-03-05 18:42:24 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
      ! iobroker 2015-03-05 18:42:24 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/animated-overlay.gif lib/css/themes/jquery-ui/redmond/images/animated-overlay.gif image/gif
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_flat_0_aaaaaa_40x100.png lib/css/themes/jquery-ui/redmond/images/ui-bg_flat_0_aaaaaa_40x100.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_flat_55_fbec88_40x100.png lib/css/themes/jquery-ui/redmond/images/ui-bg_flat_55_fbec88_40x100.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_75_d0e5f5_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_75_d0e5f5_1x400.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_95_fef1ec_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_95_fef1ec_1x400.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_gloss-wave_55_5c9ccc_500x100.png lib/css/themes/jquery-ui/redmond/images/ui-bg_gloss-wave_55_5c9ccc_500x100.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_f5f8f9_1x100.png lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_f5f8f9_1x100.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_fcfdfd_1x100.png lib/css/themes/jquery-ui/redmond/images/ui-bg_inset-hard_100_fcfdfd_1x100.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_217bc0_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_217bc0_256x240.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_2e83ff_256x240.png image/png
      ! iobroker 2015-03-05 18:42:23 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_6da8d5_256x240.png image/png
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_cd0a0a_256x240.png image/png
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_d8e7f3_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_d8e7f3_256x240.png image/png
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_f9bd01_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_f9bd01_256x240.png image/png
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/jquery-ui.css lib/css/themes/jquery-ui/redmond/jquery-ui.css text/css
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/jquery-ui.min.css lib/css/themes/jquery-ui/redmond/jquery-ui.min.css text/css
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/jquery.ui.theme.css lib/css/themes/jquery-ui/redmond/jquery.ui.theme.css text/css
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/grid.locale-all.js lib/js/grid.locale-all.js application/javascript
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.10.2.min.map lib/js/jquery-1.10.2.min.map application/octet-stream
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.0.min.map lib/js/jquery-1.11.0.min.map application/octet-stream
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.1.min.js lib/js/jquery-1.11.1.min.js application/javascript
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
      ! iobroker 2015-03-05 18:42:22 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
      ! iobroker 2015-03-05 18:42:21 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
      ! iobroker 2015-03-05 18:42:21 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
      ! iobroker 2015-03-05 18:42:21 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
      ! iobroker 2015-03-05 18:42:21 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
      ! iobroker 2015-03-05 18:42:21 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
      ! iobroker 2015-03-05 18:42:21 info upload web /root/DS/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
      ! iobroker 2015-03-05 18:42:21 info got /root/DS/iobroker/node_modules/iobroker.web/www
      ! iobroker 2015-03-05 18:42:21 info upload web.admin /root/DS/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
      ! iobroker 2015-03-05 18:42:21 info upload web.admin /root/DS/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
      ! iobroker 2015-03-05 18:42:21 info got /root/DS/iobroker/node_modules/iobroker.web/admin
      ! iobroker 2015-03-05 18:42:21 info install adapter web
      ! iobroker 2015-03-05 18:42:21 info └── iobroker.socketio@0.2.2 (request@2.51.0, socket.io@1.1.0)
      ! iobroker 2015-03-05 18:42:21 info ├── request@2.38.0 (json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.5.2, qs@0.6.6, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, node-uuid@1.4.2, mime-types@1.0.2, form-data@0.1.4, http-signature@0.10.1, tough-cookie@0.12.1, hawk@1.1.1)
      ! iobroker 2015-03-05 18:42:21 info ├── body-parser@1.5.2 (media-typer@0.2.0, qs@0.6.6, raw-body@1.3.0, bytes@1.0.0, depd@0.4.4, type-is@1.3.2, iconv-lite@0.4.4)
      ! iobroker 2015-03-05 18:42:21 info ├── express@4.4.5 (parseurl@1.0.1, utils-merge@1.0.0, merge-descriptors@0.0.2, cookie@0.1.2, escape-html@1.0.1, cookie-signature@1.0.4, range-parser@1.0.0, vary@0.1.0, qs@0.6.6, fresh@0.2.2, serve-static@1.2.3, methods@1.0.1, buffer-crc32@0.2.3, path-to-regexp@0.1.2, debug@1.0.2, accepts@1.0.7, type-is@1.2.1, proxy-addr@1.0.1, send@0.4.3)
      ! iobroker 2015-03-05 18:42:21 info ├── express-session@1.7.6 (utils-merge@1.0.0, cookie@0.1.2, cookie-signature@1.0.4, on-headers@1.0.0, parseurl@1.3.0, buffer-crc32@0.2.3, depd@0.4.4, debug@1.0.4, uid-safe@1.0.1)
      ! iobroker 2015-03-05 18:42:21 info ├── xtend@2.0.6 (is-object@0.1.2, object-keys@0.2.0)
      ! iobroker 2015-03-05 18:42:21 info ├── passport@0.2.1 (pause@0.0.1, passport-strategy@1.0.0)
      ! iobroker 2015-03-05 18:42:21 info ├── passport-local@1.0.0 (passport-strategy@1.0.0)
      ! iobroker 2015-03-05 18:42:21 info ├── cookie-parser@1.3.4 (cookie-signature@1.0.6, cookie@0.1.2)
      ! iobroker 2015-03-05 18:42:21 info ├── iobroker.simple-api@0.0.3
      ! iobroker 2015-03-05 18:42:21 info iobroker.web@0.2.5 root/DS/iobroker/node_modules/iobroker.web├── connect-flash@0.1.1
      ! iobroker 2015-03-05 18:42:18 info > (node-gyp rebuild 2> builderror.log) || (exit 0)
      ! iobroker 2015-03-05 18:42:18 info > ws@0.4.31 install /root/DS/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
      ! iobroker 2015-03-05 18:42:15 info > (node-gyp rebuild 2> builderror.log) || (exit 0)
      ! iobroker 2015-03-05 18:42:15 info > ws@0.4.31 install /root/DS/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/node_modules/socket.io/node_modules/engine.io/node_modules/ws
      ! iobroker 2015-03-05 18:42:07 error deprecated object-keys@0.2.0: Please update to the latest object-keys
      ! iobroker 2015-03-05 18:42:07 error WARN
      ! iobroker 2015-03-05 18:42:07 error npm
      ! iobroker 2015-03-05 18:42:03 info npm install iobroker.web –production --prefix '/root/DS/iobroker'
      ! iobroker 2015-03-05 18:42:02 info Cannot download json from https://raw.githubusercontent.com/ioBro ... ckage.json. Error: Error: ETIMEDOUT
      ! iobroker 2015-03-05 18:41:59 info add web
      ! admin.0 2015-03-05 18:21:06 info received all states
      ! admin.0 2015-03-05 18:21:06 info received all objects
      ! admin.0 2015-03-05 18:21:06 info Use link 'http://localhost:8081' to configure.
      ! admin.0 2015-03-05 18:21:06 info http server listening on port 8081
      ! admin.0 2015-03-05 18:21:06 info requesting all objects
      ! admin.0 2015-03-05 18:21:06 info requesting all states
      ! admin.0 2015-03-05 18:21:06 info starting. Version 0.3.19 in /root/DS/iobroker/node_modules/iobroker.admin
      derAuge
        @derAuge:
        <code>Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker***************
        Das ist Timeout von npm.. Wird in der nächste Version von js-controller besser.
        Oder so http://forum.iobroker.org/viewtopic.php?f=22&t=373#p2794</code>
