    4. [gelöst]Fehler in iobroker.knx
    • ruhigundrelaxed
      ruhigundrelaxed last edited by
      ersteinmal ein frohes neues!!
      Ich habe einen seltsamen Fehler und brauche eure Unterstützung.
      Nach einer Neuinstallation bekomme ich o.g. Adapter nicht mehr ans rennen. Er terminiert mit code(1). Ursächlich war wohl die Tatsache, dass er "adapter.js" aufgrund einer fehlerhaften Pfadangabe nicht requiren konnte. Nach manueller korrektur:
      ( "require(__dirname + '/../../lib/adapter.js')" -> require(__dirname + '/../iobroker.js-controller/lib/adapter.js') in knx.js rennt er zwar los, trifft
      allerdings relativ schnell die Wand:
      { Name: 'Rolladen K Move', Address: '0/0/11' }
      { _id: '0/0/11',
        type: 'state',
        common: { name: 'Rolladen K Move' },
        native: {} }
      2016-01-15 13:22:53.408  - error: uncaught exception: Maximum call stack size exceeded
      2016-01-15 13:22:53.420  - error: RangeError: Maximum call stack size exceeded
          at onwriteError (_stream_writable.js:305:22)
          at onwrite (_stream_writable.js:335:5)
          at WritableState.onwrite (_stream_writable.js:105:5)
          at fireErrorCallbacks (net.js:456:13)
          at Socket._destroy (net.js:467:5)
          at Socket._writeGeneric (net.js:658:10)
          at Socket._write (net.js:711:8)
          at doWrite (_stream_writable.js:301:12)
          at writeOrBuffer (_stream_writable.js:288:5)
          at Socket.Writable.write (_stream_writable.js:217:11)
      2016-01-15 13:22:53.725  - error: uncaught exception: Cannot set property 'end' of null
      2016-01-15 13:22:53.730  - error: TypeError: Cannot set property 'end' of null
          at Object.require.unload (/opt/iobroker/node_modules/iobroker.knx/knx.js:52:42)
          at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2768:21)
          at process.g (events.js:199:16)
          at process.emit (events.js:107:17)
          at process.exit (node.js:600:17)
          at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2826:21)
          at Timer.listOnTimeout (timers.js:119:15)
      2016-01-15 13:22:53.743  - error: host.zuhause instance system.adapter.knx.0 terminated with code 0 (OK)
      Ausserdem fällt mir auf, dass der Adapter in Version 0.0.1 installiert wird, obwohl laut iobroker 0.2.10 aktuell ist.
      Fällt irgendjemand was dazu ein?
      Martin
      • ruhigundrelaxed
        Habe ein wenig rumgebastelt und konnte das Problem lösen.
        Falls jemand zufällig das gleiche Problem hat, hier ist meine Lösung.
        1.) Wie schon im Eingangspost erwähnt: ( "require(__dirname + '/../../lib/adapter.js')" -> require(__dirname + '/../iobroker.js-controller/lib/adapter.js') in knx.js
        2.) Im Verzeichniss des Adapters ein: "npm install eibd" absetzen.
        Ich werde mich heute abend mal dransetzen und die defekte gegen die funktionierende Installation vergleichen.
        Ich vermute das der Adapter eine falsche Version von eibd installiert.
        Desweiteren wird wohl die Codebasis von 0.2.10 installiert, aber 0.0.1 angezeigt.
        • V
          versteckt last edited by
          Hey super, du nutzt bereits knx?
          Ich habe einen Endkunden der auch knx besitzt und da muss ich demnächst eine ioBroker Installation durchführen.
          Wenn ich Fragen / Probleme habe, darf ich mich an dich wenden?
          LG Christian
