    4. Daten aus einer .js verwenden (Suntrol Datenlogger STL200)
      Matzes last edited by
      ich würde gerne Daten aus einer .js Datei importieren.
      Die Datei kann ich im Browser aufrufen
      http://192.168.100.150/min_cur.js
      und gibt folgendes aus:
      var Datum="17.01.16"
      var Uhrzeit="01:52:03"
      var Pac=0
      var aPdc=new Array(0,0,0)
      var curStatusCode = new Array(2)
      curStatusCode[0]=0
      curStatusCode[1]=255
      var curFehlerCode = new Array(2)
      curFehlerCode[0]=0
      curFehlerCode[1]=0
      var PacArr= [[2204], [0]];
      var PdcArr= [[0,0,0], [0,0,0]];
      var sStrWIFI = 0
      var sStrGPRS = 0
      var tBsent = 21722739
      var tBrecv = 7449541
      Wie schaffe ich es z.B. den Wert von Pac (in diesem Fall 0) oder den Wert von PacArr auszulesen und in iobroker zu übernehmen?
      Meine Trial an Error Versuche haben leider nicht gefruchtet.Danke für euere Unterstützung.
      Gruß,
      Mathias
        Es gibt wahrscheinlich deutlich einfachere Lösungen… aber es funktioniert 🙂
        Der Zahlenwert von PacArr (aktueller Verbrauch) aus der Datei min_cur.js wird ausgegeben.
        [{"id":"c38549e2.2b4d3","type":"http request","z":"47ffde65.d8b548","name":"","method":"GET","ret":"txt","url":"http://192.168.100.150/min_cur.js","x":359,"y":144,"wires":[["14fd5301.fb019d"]]},{"id":"14fd5301.fb019d","type":"csv","z":"47ffde65.d8b548","name":"","sep":"#","hdrin":false,"hdrout":"","multi":"one","ret":"\\n","temp":"","x":514,"y":144,"wires":[["56c84588.3f79bc"]]},{"id":"9dbb677b.04cc68","type":"debug","z":"47ffde65.d8b548","name":"","active":true,"console":"false","complete":"payload","x":677,"y":521,"wires":[]},{"id":"20fa4cd4.d126a4","type":"inject","z":"47ffde65.d8b548","name":"","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":false,"x":215,"y":144,"wires":[["c38549e2.2b4d3"]]},{"id":"56c84588.3f79bc","type":"contrib-json","z":"47ffde65.d8b548","engine":"JSONSelect","command":"jq","expr":":root > .col1","complete":"property","prop":"payload","name":"","x":670,"y":144,"wires":[["1434dacc.bbba45"]]},{"id":"1434dacc.bbba45","type":"switch","z":"47ffde65.d8b548","name":"","property":"payload","rules":[{"t":"cont","v":"var PacArr="}],"checkall":"false","outputs":1,"x":204,"y":258,"wires":[["120fc56.0302f3b"]]},{"id":"120fc56.0302f3b","type":"splitter","z":"47ffde65.d8b548","name":"","property":"payload","x":718,"y":253,"wires":[["3c86b62f.80e042"]]},{"id":"d760741b.a7ac18","type":"splitter","z":"47ffde65.d8b548","name":"","property":"payload","x":713,"y":341,"wires":[["b7fb999c.b130c8"]]},{"id":"3c86b62f.80e042","type":"string-split","z":"47ffde65.d8b548","name":"","source_object":"msg","source_property":"","target_object":"msg","target_property":"","split_on":"var PacArr= [[","x":535,"y":340,"wires":[["d760741b.a7ac18"]]},{"id":"eff0fe12.e0aff8","type":"string-split","z":"47ffde65.d8b548","name":"","source_object":"msg","source_property":"","target_object":"msg","target_property":"","split_on":"]","x":536,"y":414,"wires":[["88dbfbe6.4cfda8"]]},{"id":"b7fb999c.b130c8","type":"switch","z":"47ffde65.d8b548","name":"","property":"payload","rules":[{"t":"cont","v":"]];"}],"checkall":"true","outputs":1,"x":194,"y":412,"wires":[["98712918.d2b5e"]]},{"id":"530a8fbc.30c8f","type":"switch","z":"47ffde65.d8b548","name":"","property":"payload","rules":[{"t":"cont","v":"["},{"t":"gte","v":"0"},{"t":"cont","v":","}],"checkall":"true","outputs":3,"x":183,"y":522,"wires":[[],["9dbb677b.04cc68"],[]]},{"id":"88dbfbe6.4cfda8","type":"splitter","z":"47ffde65.d8b548","name":"","property":"payload","x":707,"y":412,"wires":[["530a8fbc.30c8f"]]},{"id":"98712918.d2b5e","type":"change","z":"47ffde65.d8b548","name":"","rules":[{"t":"change","p":"payload","from":"]];","to":"#","re":false}],"action":"","property":"","from":"","to":"","reg":false,"x":362,"y":413,"wires":[["eff0fe12.e0aff8"]]}]
        Und hier noch der Flow für das Auslesen des Tagesgesamtverbrauches aus der days.js
        [{"id":"7aec4a2b.f4aaf4","type":"http request","z":"47ffde65.d8b548","name":"","method":"GET","ret":"txt","url":"http://192.168.100.150/days.js","x":382,"y":1130,"wires":[["330d8bc8.57cf9c"]]},{"id":"53022e08.fef72","type":"debug","z":"47ffde65.d8b548","name":"","active":true,"console":"false","complete":"payload","x":1066,"y":1448,"wires":[]},{"id":"49123c17.c1f774","type":"inject","z":"47ffde65.d8b548","name":"","topic":"","payload":"","payloadType":"none","repeat":"","crontab":"","once":false,"x":238,"y":1130,"wires":[["7aec4a2b.f4aaf4"]]},{"id":"44b29e7c.6300d8","type":"splitter","z":"47ffde65.d8b548","name":"","property":"payload","x":777,"y":1131,"wires":[["8acb8b2f.336ad"]]},{"id":"361cafaa.503ba","type":"splitter","z":"47ffde65.d8b548","name":"","property":"payload","x":780,"y":1243,"wires":[["19ebd8d4.67e28f"]]},{"id":"330d8bc8.57cf9c","type":"string-split","z":"47ffde65.d8b548","name":"","source_object":"msg","source_property":"","target_object":"msg","target_property":"","split_on":"da[dx++]","x":597,"y":1127,"wires":[["44b29e7c.6300d8"]]},{"id":"8acb8b2f.336ad","type":"string-split","z":"47ffde65.d8b548","name":"","source_object":"msg","source_property":"","target_object":"msg","target_property":"","split_on":";","x":590,"y":1246,"wires":[["361cafaa.503ba"]]},{"id":"19ebd8d4.67e28f","type":"switch","z":"47ffde65.d8b548","name":"","property":"payload","rules":[{"t":"cont","v":"="}],"checkall":"false","outputs":1,"x":377,"y":1346,"wires":[["70bf053c.4aac54"]]},{"id":"2e7c78ff.16c058","type":"switch","z":"47ffde65.d8b548","name":"","property":"payload","rules":[{"t":"cont","v":"="},{"t":"else"}],"checkall":"true","outputs":2,"x":377,"y":1451,"wires":[[],["53022e08.fef72"]]},{"id":"70bf053c.4aac54","type":"string-split","z":"47ffde65.d8b548","name":"","source_object":"msg","source_property":"","target_object":"msg","target_property":"","split_on":"|","x":584,"y":1346,"wires":[["27f1be91.f77002"]]},{"id":"27f1be91.f77002","type":"splitter","z":"47ffde65.d8b548","name":"","property":"payload","x":777,"y":1348,"wires":[["2e7c78ff.16c058"]]}]
        Damit das ganze funktioniert müssen noch folgende Node-Red Pakete installiert werden:
        npm install node-red-contrib-splitter
        npm install node-red-contrib-primitives
        npm install node-red-contrib-json
          stoepselinho last edited by
          hallo,
          ich würde auch gerne die aktuellen Ertrag und den aktuellen Verbrauch auslesen.
          leider weis ich nicht wie man das script richtig schreibt.
          kann auch die http://192.168.xxx.xxx/pc.js?min aufrufen.
          sieht dann so bei mir aus:
          var Boot=99
          var AnlagenKWP=3420
          var time_start = new Array(8,7,6,6,6,6,6,7,7,7,7,8)
          var time_end = new Array(17,18,20,21,21,22,22,21,20,19,17,17)
          var sollMonth = new Array(1,4,9,11,12,15,15,12,10,6,3,2)
          var SollYearKWP=800
          var AnzahlWR = 2
          var MaxWRP=new Array(AnzahlWR)
          MaxWRP[0]=new Array(4500,100000,2400000,14000000)
          MaxWRP[1]=new Array(3200,20000,550000,3000000)
          var WRInfo = new Array(AnzahlWR)
          WRInfo[0]=new Array("S0-IN","         1",15000,1,"S0-Zähler",1,null,null,0,null,9,2,0,1000,null)
          WRInfo[0][14]=2
          WRInfo[0][15]=0
          WRInfo[0][16]=0
          WRInfo[1]=new Array("Kostal","         1",3420,1,"Namenlos",2,null,null,3420,null,17,0,0,1000,null)
          WRInfo[1][6]=new Array("String 1","String 2")
          WRInfo[1][7]=new Array(1,1)
          WRInfo[1][9]=new Array(1715,1715)
          WRInfo[1][16]=2
          var HPTitel="[Anlagenbezeichnung]"
          var HPBetreiber="[Betreibername]"
          var HPEmail="[Kontakt-Emailadresse]"
          var HPStandort="[Standort der Anlage]"
          var HPModul="[Beschreibung der Module und Hersteller]"
          var HPWR/var HPLeistung="[Größe der Anlage] kWp"
          var HPInbetrieb="[Installationsdatum]"
          var HPAusricht="[Modulneigung und Ausrichtung]"
          var BannerZeile1="[Kurzbez.Anlage]"
          var BannerZeile2="4,5 kWp in 99999 Musterort"
          var BannerZeile3="im Netz seit Januar 2008"
          var BannerLink="www.suntrol-portal.com/benutzer"
          var StatusCodes = new Array(2)
          var FehlerCodes = new Array(2)
          StatusCodes[0] = "Power"
          FehlerCodes[0] = ""
          StatusCodes[1] = "Aus,Leerlauf,Anfahren,MPP,abgeregelt MPP,Einspeisen"
          FehlerCodes[1] = " ,Lüfterstörung,Netzstörung,Netzstörung,Fehlerstrom,Isolationsfehler,Reserve,Übertemperatur,Reserve,Systemstörung ENS,Systemstörung Intern"
          var Verguetung=1664
          var Serialnr = 1613383396
          var Firmware = "2.8.4 Build 56"
          var FirmwareDate = "27.01.2014"
          var WRTyp = "MULTIPROTOCOL"
          var OEMTyp = 5
          var SLTyp = "200"
          var SLVer = 2
          var SLHW = 74
          var SLBV = 22
          var Intervall = 300
          var SLDatum = "28.01.17"
          var SLUhrzeit = "18:23:38"
          var isTemp=false
          var isOnline=true
          var eventsHP=1
          var exportDir/var Lang="DE"
          var AnzahlGrp=0
          var CFDatum = "25.01.17"
          var CFUhrzeit = "20:17:47"
          var SCB = false
          var SCBIF1 = 0
          var webMenuFull = 0
          var IPlatform = 2
          var DateFormat ="dd.mm.yy"
          var TimeFormat ="HH:MM:ss"
          var TimeFormatNoSec ="HH:MM"
          var Currency ="€"
          var CurrencySub ="Cent"
          var CurrencyFirst ="0"
          var ISOCode ="DE"
          var DSTMode ="1"
          var Dezimalseparator =","
          var WeightUnit ="KG"
          var DirectMarketing = false
          var AdamAvailable=0
          var netProfile=0
          var pmControlType=3
          var pmReductionOnSerialType=2
          var windinverters=0
          var Datum="28.01.17"
          var Uhrzeit="18:23:38"
          var Pac=0
          curStatusCode[0]=0
          curFehlerCode[0]=0
          curFehlerCode[1]=0
          var PacArr= [[644], [0]];
          var sStrWIFI = 0
          var sStrGPRS = 0
          var tBsent = 12382569974
          var tBrecv = 1066588003
          m[mi++]="28.01.17 18:20:00|623;0;8368|0;0;0;6275;0;0"
          m[mi++]="28.01.17 18:15:00|623;0;8317|0;0;0;6275;0;0"
          m[mi++]="28.01.17 18:10:00|652;0;8265|0;0;0;6275;0;0"
          m[mi++]="28.01.17 18:05:00|1847;0;8212|0;0;0;6275;0;0"
          m[mi++]="28.01.17 18:00:00|762;0;8052|0;0;0;6275;0;0"
          m[mi++]="28.01.17 17:55:00|767;0;7990|0;0;0;6275;0;0"
          m[mi++]="28.01.17 17:50:00|819;0;7927|0;0;0;6275;0;0"
          m[mi++]="28.01.17 17:45:00|1035;0;7860|0;0;0;6275;0;0"
          m[mi++]="28.01.17 17:40:00|815;0;7777|0;0;0;6275;0;0"
          m[mi++]="28.01.17 17:35:00|853;0;7709|0;0;0;6275;0;0"
          m[mi++]="28.01.17 17:30:00|1273;0;7640|0;0;0;6275;0;0"
          m[mi++]="28.01.17 17:25:00|779;0;7521|0;0;0;6275;0;0"
          m[mi++]="28.01.17 17:20:00|807;0;7455|0;0;0;6275;88;88"
          m[mi++]="28.01.17 17:15:00|828;0;7387|0;0;0;6275;391;392"
          m[mi++]="28.01.17 17:10:00|729;0;7319|0;0;0;6275;406;407"
          m[mi++]="28.01.17 17:05:00|746;0;7256|0;0;0;6275;415;415"
          m[mi++]="28.01.17 17:00:00|741;0;7194|0;0;0;6275;432;433"
          m[mi++]="28.01.17 16:55:00|678;0;7132|0;0;0;6275;434;434"
          m[mi++]="28.01.17 16:50:00|608;0;7074|8;10;6;6275;158;158"
          m[mi++]="28.01.17 16:45:00|504;0;7023|15;11;14;6275;176;176"
          m[mi++]="28.01.17 16:40:00|493;0;6981|22;16;17;6275;180;181"
          m[mi++]="28.01.17 16:35:00|455;0;6940|35;27;19;6274;202;202"
          m[mi++]="28.01.17 16:30:00|473;0;6902|52;32;32;6271;217;217"
          m[mi++]="28.01.17 16:25:00|452;0;6862|75;38;51;6266;234;234"
          m[mi++]="28.01.17 16:20:00|467;0;6825|94;55;53;6260;234;234"
          m[mi++]="28.01.17 16:15:00|505;0;6785|124;65;75;6252;237;237"
          m[mi++]="28.01.17 16:10:00|468;0;6744|143;89;71;6241;250;250"
          m[mi++]="28.01.17 16:05:00|484;0;6704|153;73;98;6229;262;262"
          m[mi++]="28.01.17 16:00:00|519;0;6664|158;84;92;6216;268;268"
          m[mi++]="28.01.17 15:55:00|537;0;6620|138;72;83;6203;264;264"
          m[mi++]="28.01.17 15:50:00|527;0;6575|134;78;72;6192;273;273"
          m[mi++]="28.01.17 15:45:00|533;0;6531|142;73;84;6181;292;292"
          m[mi++]="28.01.17 15:40:00|519;0;6487|187;113;93;6169;298;298"
          m[mi++]="28.01.17 15:35:00|522;0;6444|240;119;143;6153;290;290"
          m[mi++]="28.01.17 15:30:00|507;0;6401|238;133;128;6132;277;277"
          m[mi++]="28.01.17 15:25:00|956;0;6358|205;111;114;6113;291;291"
          m[mi++]="28.01.17 15:20:00|453;0;6284|206;99;126;6096;303;303"
          m[mi++]="28.01.17 15:15:00|616;0;6246|221;107;136;6078;305;306"
          m[mi++]="28.01.17 15:10:00|605;0;6195|233;125;130;6060;307;307"
          m[mi++]="28.01.17 15:05:00|539;0;6143|252;135;139;6040;304;305"
          m[mi++]="28.01.17 15:00:00|516;0;6097|251;134;141;6019;286;286"
          m[mi++]="28.01.17 14:55:00|494;0;6053|258;141;141;5998;287;287"
          m[mi++]="28.01.17 14:50:00|467;0;6008|226;111;135;5977;293;293"
          m[mi++]="28.01.17 14:45:00|547;0;5968|254;157;120;5958;292;292"
          m[mi++]="28.01.17 14:40:00|445;0;5925|275;142;157;5937;294;294"
          m[mi++]="28.01.17 14:35:00|423;0;5888|290;163;153;5914;286;286"
          m[mi++]="28.01.17 14:30:00|447;0;5852|305;130;209;5890;287;287"
          m[mi++]="28.01.17 14:25:00|478;0;5815|310;186;157;5864;280;280"
          m[mi++]="28.01.17 14:20:00|486;0;5775|352;164;224;5838;286;286"
          m[mi++]="28.01.17 14:15:00|488;0;5736|442;245;239;5808;293;294"
          m[mi++]="28.01.17 14:10:00|504;0;5695|505;302;250;5770;306;307"
          m[mi++]="28.01.17 14:05:00|506;0;5653|701;420;333;5727;308;309"
          m[mi++]="28.01.17 14:00:00|497;0;5611|770;338;491;5667;311;312"
          m[mi++]="28.01.17 13:55:00|478;0;5569|869;441;489;5602;313;313"
          m[mi++]="28.01.17 13:50:00|510;0;5528|975;415;627;5528;312;313"
          m[mi++]="28.01.17 13:45:00|496;0;5485|1028;680;418;5446;325;325"
          m[mi++]="28.01.17 13:40:00|517;0;5443|1102;431;741;5360;327;327"
          m[mi++]="28.01.17 13:35:00|451;0;5402|1229;585;718;5267;352;352"
          m[mi++]="28.01.17 13:30:00|477;0;5364|1343;471;952;5164;359;359"
          m[mi++]="28.01.17 13:25:00|454;0;5325|1670;762;1001;5049;362;363"
          m[mi++]="28.01.17 13:20:00|461;0;5287|1842;1504;432;4908;388;388"
          m[mi++]="28.01.17 13:15:00|443;0;5249|1953;826;1221;4753;400;401"
          m[mi++]="28.01.17 13:10:00|464;0;5211|1519;714;894;4588;401;402"
          m[mi++]="28.01.17 13:05:00|452;0;5173|1572;861;793;4466;408;409"
          m[mi++]="28.01.17 13:00:00|490;0;5136|936;466;529;4340;411;412"
          m[mi++]="28.01.17 12:55:00|534;0;5095|1288;704;654;4264;403;404"
          m[mi++]="28.01.17 12:50:00|531;0;5050|794;393;450;4159;403;404"
          m[mi++]="28.01.17 12:45:00|602;0;5006|1504;883;698;4086;413;413"
          m[mi++]="28.01.17 12:40:00|645;0;4953|1840;660;1272;3956;414;414"
          m[mi++]="28.01.17 12:35:00|588;0;4899|1784;1154;720;3802;417;418"
          m[mi++]="28.01.17 12:30:00|823;0;4851|1850;890;1056;3653;418;419"
          m[mi++]="28.01.17 12:25:00|745;0;4772|1836;615;1314;3499;419;419"
          m[mi++]="28.01.17 12:20:00|574;0;4717|1768;1091;768;3347;419;420"
          m[mi++]="28.01.17 12:15:00|731;0;4658|1783;893;982;3200;422;422"
          m[mi++]="28.01.17 12:10:00|1200;0;4596|1749;925;912;3052;425;426"
          m[mi++]="28.01.17 12:05:00|653;0;4495|1728;950;866;2906;424;425"
          m[mi++]="28.01.17 12:00:00|591;0;4436|1662;976;774;2762;423;423"
          m[mi++]="28.01.17 11:55:00|1022;0;4386|1593;974;699;2628;423;423"
          m[mi++]="28.01.17 11:50:00|1123;0;4302|1638;812;911;2492;421;422"
          m[mi++]="28.01.17 11:45:00|674;0;4207|1491;838;730;2358;426;427"
          m[mi++]="28.01.17 11:40:00|472;0;4149|1661;719;1030;2231;423;424"
          m[mi++]="28.01.17 11:35:00|469;0;4109|1583;1005;662;2094;426;427"
          m[mi++]="28.01.17 11:30:00|834;0;4070|1564;1182;464;1961;430;430"
          m[mi++]="28.01.17 11:25:00|507;0;4018|1639;887;834;1831;435;436"
          m[mi++]="28.01.17 11:20:00|502;0;3975|1550;744;888;1694;431;431"
          m[mi++]="28.01.17 11:15:00|483;0;3933|1379;1073;381;1567;428;429"
          m[mi++]="28.01.17 11:10:00|753;0;3893|1280;635;716;1454;433;434"
          m[mi++]="28.01.17 11:05:00|1022;0;3832|1329;1015;386;1347;433;433"
          m[mi++]="28.01.17 11:00:00|451;0;3749|1293;802;562;1236;430;431"
          m[mi++]="28.01.17 10:55:00|485;0;3710|1254;305;1020;1129;430;430"
          m[mi++]="28.01.17 10:50:00|492;0;3670|1258;318;1012;1024;431;432"
          m[mi++]="28.01.17 10:45:00|565;0;3629|1243;626;689;921;433;433"
          m[mi++]="28.01.17 10:40:00|624;0;3581|1231;619;683;817;435;436"
          m[mi++]="28.01.17 10:35:00|596;0;3530|1141;655;551;715;435;436"
          m[mi++]="28.01.17 10:30:00|625;0;3479|1053;565;553;621;433;434"
          m[mi++]="28.01.17 10:25:00|613;0;3427|1010;543;531;533;423;424"
          m[mi++]="28.01.17 10:20:00|599;0;3377|858;452;468;451;404;405"
          m[mi++]="28.01.17 10:15:00|643;0;3327|757;421;391;381;387;387"
          m[mi++]="28.01.17 10:10:00|548;0;3275|739;465;331;318;379;380"
          m[mi++]="28.01.17 10:05:00|467;0;3228|636;302;388;258;370;371"
          m[mi++]="28.01.17 10:00:00|470;0;3189|501;278;270;205;366;366"
          m[mi++]="28.01.17 09:55:00|1298;0;3150|327;210;153;167;353;353"
          m[mi++]="28.01.17 09:50:00|834;0;3044|315;166;185;139;334;334"
          m[mi++]="28.01.17 09:45:00|479;0;2993|269;136;165;114;321;321"
          m[mi++]="28.01.17 09:40:00|533;0;2953|189;94;121;93;302;302"
          m[mi++]="28.01.17 09:35:00|545;0;2909|194;124;99;76;282;282"
          m[mi++]="28.01.17 09:30:00|524;0;2863|124;66;81;61;263;263"
          m[mi++]="28.01.17 09:25:00|511;0;2819|100;62;59;51;257;258"
          m[mi++]="28.01.17 09:20:00|553;0;2778|93;50;64;43;250;250"
          m[mi++]="28.01.17 09:15:00|718;0;2729|84;52;53;36;247;247"
          m[mi++]="28.01.17 09:10:00|467;0;2675|66;42;43;29;243;243"
          m[mi++]="28.01.17 09:05:00|449;0;2636|57;42;33;23;232;232"
          m[mi++]="28.01.17 09:00:00|446;0;2599|35;18;32;19;222;222"
          m[mi++]="28.01.17 08:55:00|508;0;2562|36;28;24;16;228;228"
          m[mi++]="28.01.17 08:50:00|646;0;2511|38;27;27;13;244;245"
          m[mi++]="28.01.17 08:45:00|1046;0;2389|30;28;18;10;287;287"
          m[mi++]="28.01.17 08:40:00|2541;0;2243|28;14;29;7;335;336"
          m[mi++]="28.01.17 08:35:00|2587;0;2015|19;9;23;5;366;367"
          m[mi++]="28.01.17 08:30:00|511;0;1789|11;6;17;0;368;368"
          m[mi++]="28.01.17 08:25:00|438;0;1746|7;5;14;0;369;369"
          m[mi++]="28.01.17 08:20:00|404;0;1710|7;0;18;0;361;361"
          m[mi++]="28.01.17 08:15:00|312;0;1676|0;1;0;0;285;285"
          m[mi++]="28.01.17 08:10:00|298;0;1650|0;0;0;0;142;150"
          m[mi++]="28.01.17 08:05:00|297;0;1625|0;0;0;0;0;0"
          m[mi++]="28.01.17 08:00:00|322;0;1601|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:55:00|266;0;1574|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:50:00|268;0;1552|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:45:00|283;0;1530|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:40:00|261;0;1507|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:35:00|267;0;1486|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:30:00|209;0;1463|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:25:00|169;0;1445|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:20:00|371;0;1431|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:15:00|315;0;1404|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:10:00|177;0;1374|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:05:00|198;0;1360|0;0;0;0;0;0"
          m[mi++]="28.01.17 07:00:00|212;0;1343|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:55:00|203;0;1325|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:50:00|209;0;1308|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:45:00|213;0;1290|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:40:00|205;0;1273|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:35:00|222;0;1256|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:30:00|212;0;1237|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:25:00|204;0;1220|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:20:00|160;0;1202|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:15:00|160;0;1189|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:10:00|144;0;1176|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:05:00|597;0;1164|0;0;0;0;0;0"
          m[mi++]="28.01.17 06:00:00|139;0;1122|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:55:00|149;0;1111|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:50:00|152;0;1098|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:45:00|152;0;1085|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:40:00|207;0;1073|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:35:00|214;0;1055|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:30:00|215;0;1037|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:25:00|209;0;1020|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:20:00|258;0;1002|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:15:00|258;0;981|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:10:00|271;0;959|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:05:00|279;0;936|0;0;0;0;0;0"
          m[mi++]="28.01.17 05:00:00|225;0;912|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:55:00|192;0;893|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:50:00|203;0;877|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:45:00|159;0;860|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:40:00|135;0;847|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:35:00|178;0;836|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:30:00|143;0;821|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:25:00|142;0;809|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:20:00|149;0;797|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:15:00|656;0;785|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:10:00|135;0;732|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:05:00|142;0;720|0;0;0;0;0;0"
          m[mi++]="28.01.17 04:00:00|140;0;709|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:55:00|140;0;697|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:50:00|146;0;685|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:45:00|133;0;674|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:40:00|151;0;662|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:35:00|160;0;649|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:30:00|187;0;636|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:25:00|183;0;620|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:20:00|197;0;605|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:15:00|205;0;588|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:10:00|193;0;572|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:05:00|143;0;555|0;0;0;0;0;0"
          m[mi++]="28.01.17 03:00:00|180;0;549|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:55:00|145;0;533|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:50:00|136;0;521|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:45:00|149;0;510|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:40:00|162;0;497|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:35:00|188;0;484|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:30:00|213;0;469|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:25:00|218;0;450|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:20:00|227;0;432|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:15:00|222;0;413|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:10:00|230;0;395|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:05:00|290;0;376|0;0;0;0;0;0"
          m[mi++]="28.01.17 02:00:00|313;0;353|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:55:00|194;0;327|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:50:00|150;0;312|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:45:00|183;0;299|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:40:00|191;0;284|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:35:00|202;0;268|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:30:00|194;0;252|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:25:00|199;0;236|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:20:00|206;0;219|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:15:00|219;0;202|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:10:00|173;0;184|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:05:00|156;0;169|0;0;0;0;0;0"
          m[mi++]="28.01.17 01:00:00|125;0;156|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:55:00|137;0;145|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:50:00|154;0;134|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:45:00|132;0;121|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:40:00|149;0;110|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:35:00|160;0;97|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:30:00|156;0;84|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:25:00|174;0;71|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:20:00|187;0;56|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:15:00|179;0;41|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:10:00|161;0;26|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:05:00|156;0;12|0;0;0;0;0;0"
          m[mi++]="28.01.17 00:00:00|186;0;0|0;0;0;0;0;0"
          da[dx++]="28.01.17|8368;2587|6275;1953"
            der aktuelle Verbrauch entspricht dem von mir ausgelesenen Wert PacArr.
            Ich lese den aktuellen Ertrag über die Webseite meines PIKO WR. Ist hier ebenfalls im Forum beschrieben. Wenn du noch Bedarf hast kann ich mir ansehen wie man den aktuellen Ertrag über Node-Red ausliest.
            Gruß,
            Matze
            1.0k
