    4. Nach update startet iobroker nicht mehr
      Maddog-1 last edited by
      nach dem update startet der iobroker nicht mehr.
      sudo iobroker start
      Starting iobroker controller daemon...
      /opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136
                  throw new Error(msg.error);
      Error: /opt/iobroker/node_modules/iobroker.js-controller/controller.js:1
      (function (exports, require, module, __filename, __dirname) { ��u<��\����
      SyntaxError: Invalid or unexpected token
          at createScript (vm.js:56:10)
          at Object.runInThisContext (vm.js:97:10)
          at Module._compile (module.js:542:28)
          at Object.Module._extensions..js (module.js:579:10)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
          at Module.require (module.js:497:17)
          at require (internal/module.js:20:19)
          at init (/opt/iobroker/node_modules/daemonize2/lib/wrapper.js:105:17)
          at ChildProcess. <anonymous>(/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:136:19)
          at emitTwo (events.js:106:13)
          at ChildProcess.emit (events.js:191:7)
          at process.nextTick (internal/child_process.js:787:12)
          at _combinedTickCallback (internal/process/next_tick.js:73:7)
          at process._tickCallback (internal/process/next_tick.js:104:9)</anonymous>
      hatte dann folgendes gemacht sudo npm install iobroker.js-controller –production
      da bekomme ich aber ebenfalls fehler.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: redis@^2.8.0 (node_modules/iobroker.js-controller/node_modules/redis):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Failed to parse json
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Unexpected token 'v' at 1:8
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY:        views[view].widgets[id].data['visibility-val'] = false;
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY:        ^
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File: /root/.npm/redis/2.8.0/package/package.json
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: le-challenge-fs@^2.0.8 (node_modules/iobroker.js-controller/node_modules/le-challenge-fs):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Unexpected token 't' at 1:1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: tus('Forbidden') // => 403\nstatus(306) // throws, as it's not supported by nod
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File: /root/.npm/le-challenge-fs/2.0.8/package/package.json
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: winston-syslog@^1.2.6 (node_modules/iobroker.js-controller/node_modules/winston-syslog):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Unexpected token 'e' at 1:1
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: exports.parse = require('./lib/parse');
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: File: /root/.npm/winston-syslog/1.2.6/package/package.json
      npm ERR! file /root/.npm/jszip/3.1.5/package/package.json
      npm ERR! code EJSONPARSE
      npm ERR! Failed to parse json
      npm ERR! Unexpected token 'e' at 1:1
      npm ERR! ength,f=new o(i,s,u,a),l=this.$lines.slice(e,t+1);return this.applyDelta({start
      npm ERR! ^
      npm ERR! File: /root/.npm/jszip/3.1.5/package/package.json
      npm ERR! Failed to parse package.json data.
      npm ERR! package.json must be actual JSON, not just JavaScript.
      npm ERR!
      npm ERR! This is not a bug in npm.
      npm ERR! Tell the package author to fix their package.json file. JSON.parse
      npm ERR!     /root/.npm/_logs/2018-12-23T18_01_40_031Z-debug.log
      komme hier nichtmehr weiter
      • apollon77
        apollon77 last edited by
        Ich würde sagen deine sd Karte macht den Abgang. Am besten rette was geht und starte mit neuer as Karte.
        Gesendet vom Handy …
        81.1k
