    4. Diverse Probleme nach Backup (u.a. "you are sending too fast")
      M1R0O last edited by
      Hallo und frohe Weihnachten,
      ich habe, nach Einspielen meines Backups, einige Probleme mit dem System. Vorher lief alles problemlos, aber seit 1 Woche erhalte ich diverse Fehler insbesondere bzgl. meiner Homematic Rolladenadapter.
      Hier mal mein LOG:
      2018-12-24 11:05:58.607 - error: hm-rpc.0 Error: You are sending too fast
      2018-12-24 11:05:58.607 - error: hm-rpc.0 binrpc -> setValue ["1","LEVEL",0.7] FLOAT
      2018-12-24 11:05:58.608 - error: hm-rpc.0 Error: You are sending too fast
      2018-12-24 11:05:58.609 - error: hm-rpc.0 binrpc -> setValue ["1","LEVEL",0.7] FLOAT
      2018-12-24 11:05:58.609 - error: hm-rpc.0 Error: You are sending too fast
      2018-12-24 11:05:58.610 - error: hm-rpc.0 binrpc -> setValue ["1","LEVEL",0.7] FLOAT
      2018-12-24 11:05:58.610 - error: hm-rpc.0 Error: You are sending too fast
      2018-12-24 11:05:58.611 - error: hm-rpc.0 binrpc -> setValue ["1","LEVEL",0.7] FLOAT
      2018-12-24 11:05:58.612 - error: hm-rpc.0 Error: You are sending too fast
      2018-12-24 11:05:58.612 - error: hm-rpc.0 binrpc -> setValue ["1","LEVEL",0.7] FLOAT
      2018-12-24 11:06:15.732 - error: hm-rpc.0 binrpc -> setValue ["1","LEVEL",0.3] FLOAT
      2018-12-24 11:06:15.732 - error: hm-rpc.0 Error: response timeout
      2018-12-24 11:06:16.519 - warn: hm-rpc.0 Reconnection to DB.
      2018-12-24 11:06:16.522 - warn: hm-rpc.0 Reconnection to DB.
      2018-12-24 11:06:16.557 - error: hm-rpc.0 already running
      2018-12-24 11:06:16.593 - error: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
      2018-12-24 11:06:16.593 - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
      2018-12-24 11:06:26.091 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 20118
      2018-12-24 11:06:26.134 - info: host.raspberrypi instance system.adapter.ping.0 started with pid 20124
      2018-12-24 11:06:26.175 - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 20129
      2018-12-24 11:06:27.605 - info: ping.0 starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ping, node: v8.14.0
      2018-12-24 11:06:27.702 - info: discovery.0 starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v8.14.0
      2018-12-24 11:06:27.909 - info: hm-rpc.1 starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.14.0
      2018-12-24 11:06:28.473 - info: hm-rpc.1 xmlrpc server is trying to listen on 192.168.XXX.XX:2010
      2018-12-24 11:06:28.475 - info: hm-rpc.1 xmlrpc client is trying to connect to 192.168.XXX.XX:2010/ with ["http://192.168.178.38:2010","hm-rpc.1"]
      2018-12-24 11:06:28.559 - info: hm-rpc.1 Connected
      2018-12-24 11:06:28.871 - info: hm-rpc.1 xmlrpc <- listDevices ["hm-rpc.1"]
      2018-12-24 11:06:28.887 - info: hm-rpc.1 xmlrpc -> 0 devices
      2018-12-24 11:06:29.243 - info: hm-rpc.1 xmlrpc <- newDevices 9
      2018-12-24 11:06:29.273 - info: hm-rpc.1 new HmIP devices/channels after filter: 0
      2018-12-24 11:06:30.547 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855282.0.UNREACH_ALARM to "Fenster9:0.UNREACH_ALARM"
      2018-12-24 11:06:30.564 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855282.0.STICKY_UNREACH_ALARM to "Fenster9:0.STICKY_UNREACH_ALARM"
      2018-12-24 11:06:30.589 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855282.0.DUTYCYCLE_ALARM to "Fenster9:0.DUTYCYCLE_ALARM"
      2018-12-24 11:06:30.623 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855282.0.DEVICE_IN_BOOTLOADER_ALARM to "Fenster9:0.DEVICE_IN_BOOTLOADER_ALARM"
      2018-12-24 11:06:30.637 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855282.0.CONFIG_PENDING_ALARM to "Fenster9:0.CONFIG_PENDING_ALARM"
      2018-12-24 11:06:30.651 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855282.0.UPDATE_PENDING_ALARM to "Fenster9:0.UPDATE_PENDING_ALARM"
      2018-12-24 11:06:30.680 - info: hm-rega.0 renamed hm-rpc.0.OEQ1854040.0.UPDATE_PENDING_ALARM to "Fenster7:0.UPDATE_PENDING_ALARM"
      2018-12-24 11:06:30.706 - info: hm-rega.0 renamed hm-rpc.0.OEQ1854040.0.UNREACH_ALARM to "Fenster7:0.UNREACH_ALARM"
      2018-12-24 11:06:30.730 - info: hm-rega.0 renamed hm-rpc.0.OEQ1854040.0.STICKY_UNREACH_ALARM to "Fenster7:0.STICKY_UNREACH_ALARM"
      2018-12-24 11:06:30.746 - info: hm-rega.0 renamed hm-rpc.0.OEQ1854040.0.DUTYCYCLE_ALARM to "Fenster7:0.DUTYCYCLE_ALARM"
      2018-12-24 11:06:30.759 - info: hm-rega.0 renamed hm-rpc.0.OEQ1854040.0.DEVICE_IN_BOOTLOADER_ALARM to "Fenster7:0.DEVICE_IN_BOOTLOADER_ALARM"
      2018-12-24 11:06:30.800 - info: hm-rega.0 renamed hm-rpc.0.OEQ1854040.0.CONFIG_PENDING_ALARM to "Fenster7:0.CONFIG_PENDING_ALARM"
      2018-12-24 11:06:30.806 - info: hm-rega.0 renamed hm-rpc.0.OEQ1852569.0.UPDATE_PENDING_ALARM to "Fenster4:0.UPDATE_PENDING_ALARM"
      2018-12-24 11:06:30.812 - info: hm-rega.0 renamed hm-rpc.0.OEQ1852569.0.UNREACH_ALARM to "Fenster4:0.UNREACH_ALARM"
      2018-12-24 11:06:30.818 - info: hm-rega.0 renamed hm-rpc.0.OEQ1852569.0.STICKY_UNREACH_ALARM to "Fenster4:0.STICKY_UNREACH_ALARM"
      2018-12-24 11:06:30.825 - info: hm-rega.0 renamed hm-rpc.0.OEQ1852569.0.DUTYCYCLE_ALARM to "Fenster4:0.DUTYCYCLE_ALARM"
      2018-12-24 11:06:30.832 - info: hm-rega.0 renamed hm-rpc.0.OEQ1852569.0.DEVICE_IN_BOOTLOADER_ALARM to "Fenster4:0.DEVICE_IN_BOOTLOADER_ALARM"
      2018-12-24 11:06:30.867 - info: hm-rega.0 renamed hm-rpc.0.OEQ1852569.0.CONFIG_PENDING_ALARM to "Fenster4:0.CONFIG_PENDING_ALARM"
      2018-12-24 11:06:30.882 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855592.0.UPDATE_PENDING_ALARM to "Fenster3:0.UPDATE_PENDING_ALARM"
      2018-12-24 11:06:30.909 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855592.0.UNREACH_ALARM to "Fenster3:0.UNREACH_ALARM"
      2018-12-24 11:06:30.934 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855592.0.STICKY_UNREACH_ALARM to "Fenster3:0.STICKY_UNREACH_ALARM"
      2018-12-24 11:06:30.947 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855592.0.DUTYCYCLE_ALARM to "Fenster3:0.DUTYCYCLE_ALARM"
      2018-12-24 11:06:30.966 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855592.0.DEVICE_IN_BOOTLOADER_ALARM to "Fenster3:0.DEVICE_IN_BOOTLOADER_ALARM"
      2018-12-24 11:06:30.993 - info: hm-rega.0 renamed hm-rpc.0.OEQ1855592.0.CONFIG_PENDING_ALARM to "Fenster3:0.CONFIG_PENDING_ALARM"
      2018-12-24 11:06:46.622 - info: host.raspberrypi instance system.adapter.hm-rpc.0 started with pid 20166
      2018-12-24 11:06:48.466 - info: hm-rpc.0 starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.14.0
      2018-12-24 11:06:48.893 - info: hm-rpc.0 binrpc server is trying to listen on 192.168.XXX.XX:2001
      2018-12-24 11:06:48.894 - info: hm-rpc.0 binrpc client is trying to connect to 192.168.XXX.XX:2001undefined with ["xmlrpc_bin://192.168.178.38:2001","hm-rpc.0"]
      2018-12-24 11:06:48.928 - info: hm-rpc.0 binrpc <- system.listMethods ["hm-rpc.0"]
      2018-12-24 11:06:48.940 - info: hm-rpc.0 binrpc <- listDevices ["hm-rpc.0"]
      2018-12-24 11:06:49.015 - info: hm-rpc.0 binrpc -> 64 devices
      2018-12-24 11:06:49.129 - info: hm-rpc.0 Connected
      2018-12-24 11:10:34.462 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.XXX.XX vis.0
      2018-12-24 11:13:05.226 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.XXX.XX
      2018-12-24 11:13:05.325 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.XXX.XX vis.0
      2018-12-24 11:13:11.289 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.XXX.X
      2018-12-24 11:13:45.908 - info: javascript.0 Start javascript script.js.Rolläden.alle_auf
      2018-12-24 11:13:45.922 - info: javascript.0 script.js.Rolläden.alle_auf: registered 0 subscriptions and 0 schedules
      2018-12-24 11:13:46.882 - info: javascript.0 Stop script script.js.Rolläden.alle_auf
      2018-12-24 11:16:20.091 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.XXX.XX vis.0
      2018-12-24 11:17:24.470 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.XXX.XX
      ! 2018-12-24 11:30:00.043 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 20859
      2018-12-24 11:30:02.805 - info: ical.0 starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v8.14.0
      2018-12-24 11:30:03.711 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.XXX.XX
      2018-12-24 11:30:06.206 - info: ical.0 processing URL: JeMiLeJo https://calendar.google.com/calendar/ical/7dlg40o511dm2bb83n9p1ln3e8%40group.calendar.google.com/private-b2668a731d8ec6a5fe870a996eb2ac5a/basic.ics
      2018-12-24 11:30:13.840 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (OK)
      2018-12-24 11:31:29.900 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.XXX.XX vis.0
      2018-12-24 11:34:12.915 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.XXX.XX
      2018-12-24 11:34:13.054 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.XXX.XX vis.0
      2018-12-24 11:34:41.906 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.XXX.XX
      Dies ist das dazughörige Skript, welches ein halbes Jahr problemlos lief, jetzt nicht mehr:
       <xml xmlns="http://www.w3.org/1999/xhtml"><block type="schedule" id="Ocf*a?-+jA6.0IdQV4r2" x="-312" y="-213"><field name="SCHEDULE">* * * * 1-5</field>
          <statement name="STATEMENT"><block type="astro" id="h~?pM-cW#!zWN^v|VaQ@"><field name="TYPE">dawn</field>
              <field name="OFFSET">+190</field>
              <statement name="STATEMENT"><block type="controls_if" id="|x@o-c_hM[FO(}R9xxjH"><mutation elseif="1"></mutation>
                  <value name="IF0"><block type="logic_compare" id="I7bSu3E]OB833[.*cu]o"><field name="OP">EQ</field>
                      <value name="A"><block type="get_value" id="W:5pR*XaoRCO9rT.SdEq"><field name="ATTR">val</field>
                          <field name="OID">hm-rpc.0.OEQ1852569.1.LEVEL</field></block></value>
                      <value name="B"><block type="math_number" id=")Q1@Zzc4eenw*:_^!hu5"><field name="NUM">100</field></block></value></block></value>
                  <statement name="DO0"><block type="control" id="p[(dor4nR130N3CtZOz}"><mutation delay_input="false"></mutation>
                      <value name="VALUE"><block type="math_number" id="u7},a}B*ubqR6dv_^;#W"><field name="NUM">70</field></block></value></block></statement>
                  <value name="IF1"><block type="logic_compare" id="v65m/O46ktsOHUS#8%sJ"><field name="OP">EQ</field>
                      <value name="A"><block type="get_value" id="OmU_zX%h,g^n0|d_EIop"><field name="ATTR">val</field>
                      <value name="B"><block type="math_number" id="MBF01QvCSl9z!Hd4:R+c"><field name="NUM">0</field></block></value></block></value>
                  <statement name="DO1"><block type="control" id="Q1RPH{6?,w%5@okEn-g*"><mutation delay_input="false"></mutation>
                      <value name="VALUE"><block type="math_number" id="{V*[8#8=!F,#w5!c.0kZ"><field name="NUM">30</field></block></value></block></statement>
                  <next><block type="controls_if" id="zkSZ*-/Lx]C~gea]@1ME"><mutation elseif="1"></mutation>
                      <value name="IF0"><block type="logic_compare" id="7~}Pu9CGrX;M:yST*^f8"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="Ok^GLKf,mjBE[p)Q.Erb"><field name="ATTR">val</field>
                              <field name="OID">hm-rpc.0.OEQ1855592.1.LEVEL</field></block></value>
                          <value name="B"><block type="math_number" id="U7fO|!A_lN6G-W^eD,)f"><field name="NUM">100</field></block></value></block></value>
                      <statement name="DO0"><block type="control" id="]Q{kS,Z9ZPm;(In?Ck~p"><mutation delay_input="false"></mutation>
                          <value name="VALUE"><block type="math_number" id="}*Ij0+bPDeZ6B{JoBw*I"><field name="NUM">70</field></block></value></block></statement>
                      <value name="IF1"><block type="logic_compare" id="@?.NNLtQdA8s-@0TmpgB"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="4vpo4O{3uhJ*-c9G[tSM"><field name="ATTR">val</field>
                          <value name="B"><block type="math_number" id="P3}(GtDxm)mQv[frN)jL"><field name="NUM">0</field></block></value></block></value>
                      <statement name="DO1"><block type="control" id="9q!Hl!Q]pH]hpI3^3eA?"><mutation delay_input="false"></mutation>
                          <value name="VALUE"><block type="math_number" id="SZt[Kefpl?Y0yX0kr^,M"><field name="NUM">30</field></block></value></block></statement>
                      <next><block type="controls_if" id="1n_,__%ow!+^!O/Yo?Wk"><mutation elseif="1"></mutation>
                          <value name="IF0"><block type="logic_compare" id="4%z9GLl_EE@?(=}NWt;W"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="Q.R.wcs#?3B^dlPF~(KL"><field name="ATTR">val</field>
                                  <field name="OID">hm-rpc.0.OEQ1854040.1.LEVEL</field></block></value>
                              <value name="B"><block type="math_number" id="XZVJ~0nvt2cfzlRz=JVn"><field name="NUM">100</field></block></value></block></value>
                          <statement name="DO0"><block type="control" id="^Cx1fMasfDNtl]vE7:9d"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="math_number" id="b{-7srRcbx**n1Q#(:~:"><field name="NUM">70</field></block></value></block></statement>
                          <value name="IF1"><block type="logic_compare" id="`C=f3UQ)4Nm^zHkgXGVB"><field name="OP">EQ</field>
                              <value name="A"><block type="get_value" id="*SE]IP:`R,!,MCi?lHwb"><field name="ATTR">val</field>
                              <value name="B"><block type="math_number" id="]DOir|f{=VmJ2DY`)Q{5"><field name="NUM">0</field></block></value></block></value>
                          <statement name="DO1"><block type="control" id="*}qxr|`{U_=Gye{tDX+f"><mutation delay_input="false"></mutation>
                              <value name="VALUE"><block type="math_number" id="v}g4DeCRdg#IF)V2K-}_"><field name="NUM">30</field></block></value></block></statement>
                          <next><block type="controls_if" id="%A`|g4tBBaOrmZ``qD^R"><mutation elseif="1"></mutation>
                              <value name="IF0"><block type="logic_compare" id="S_1cB*(U:]!`1oPlR!.G"><field name="OP">EQ</field>
                                  <value name="A"><block type="get_value" id="Nq~-R+j,,@^4Pq!Yc|7c"><field name="ATTR">val</field>
                                      <field name="OID">hm-rpc.0.OEQ1855282.1.LEVEL</field></block></value>
                                  <value name="B"><block type="math_number" id="X#8YgJtYFba[%Wv}IYXR"><field name="NUM">100</field></block></value></block></value>
                              <statement name="DO0"><block type="control" id="0jivLk3^XZlw_)+1g9vc"><mutation delay_input="false"></mutation>
                                  <value name="VALUE"><block type="math_number" id="Sj|9lcGADhMkycPvseKr"><field name="NUM">70</field></block></value></block></statement>
                              <value name="IF1"><block type="logic_compare" id="t{~YOp.gvd`qLwJ,rFiq"><field name="OP">EQ</field>
                                  <value name="A"><block type="get_value" id="nf8@_k}M_cMU-kv(9a]{"><field name="ATTR">val</field>
                                  <value name="B"><block type="math_number" id="q!2q(U5lYjS1sXYUwfT5"><field name="NUM">0</field></block></value></block></value>
                              <statement name="DO1"><block type="control" id="qHAXjJxB7dUd{24bp8tz"><mutation delay_input="false"></mutation>
                                  <value name="VALUE"><block type="math_number" id="=K:hI;+M*gSZwj@glIv{"><field name="NUM">30</field></block></value></block></statement></block></next></block></next></block></next></block></statement></block></statement></block>
        <block type="controls_if" id=",r/V}5YbAf0rY^IJ+]:(" disabled="true" x="388" y="88"><value name="IF0"><block type="logic_compare" id="0D@DI2w}FLww!9qf?7pm"><field name="OP">NEQ</field>
              <value name="A"><block type="get_value" id="iR}a0L?r)G;Dx_vcJ5q{"><field name="ATTR">val</field>
              <value name="B"><block type="math_number" id="Q`grS#O4H=,VHMTv)/ET"><field name="NUM">50</field></block></value></block></value>
          <statement name="DO0"><block type="control" id="6D[t2]b~LUI?h`#5mrX2"><mutation delay_input="false"></mutation>
              <value name="VALUE"><block type="math_number" id="q!JgofXndBg3^xJ.WM`,"><field name="NUM">30</field></block></value></block></statement>
          <next><block type="controls_if" id="S*L(+iR.!AxMyAC}f[Sa" disabled="true"><value name="IF0"><block type="logic_compare" id="R=QANH`yeVA]vHQk)%ka"><field name="OP">NEQ</field>
                  <value name="A"><block type="get_value" id="v-w(o1fCj/%:m5SZE/`R"><field name="ATTR">val</field>
                  <value name="B"><block type="math_number" id="Tkfb,B.mT~pN66O[)1Re"><field name="NUM">30</field></block></value></block></value>
              <statement name="DO0"><block type="control" id=".+Qw{%Fafw=D~b3AH@GR"><mutation delay_input="false"></mutation>
                  <value name="VALUE"><block type="math_number" id="K~69nE;hO?`VD0WDZ(~2"><field name="NUM">30</field></block></value></block></statement>
              <next><block type="controls_if" id="H#-tgjloQ%MG}dLh(mb_" disabled="true"><value name="IF0"><block type="logic_compare" id="+{D#Wm,XwkU^:c(8iq{A"><field name="OP">NEQ</field>
                      <value name="A"><block type="get_value" id="gq:lB#+!Y*jAY_6Zr7o4"><field name="ATTR">val</field>
                      <value name="B"><block type="math_number" id="4QtK2dp!Et(EZV~]KF[J"><field name="NUM">30</field></block></value></block></value>
                  <statement name="DO0"><block type="control" id="uqP0z^,1AWlnJd2Tfd-n"><mutation delay_input="false"></mutation>
                      <value name="VALUE"><block type="math_number" id="Fo*5(dq=`+5eko{ywABR"><field name="NUM">30</field></block></value></block></statement>
                  <next><block type="controls_if" id="}H?-*u{?iSRZgZrOwDYj" disabled="true"><value name="IF0"><block type="logic_compare" id="@fVR~5/6yJc2O-nxB^:5"><field name="OP">NEQ</field>
                          <value name="A"><block type="get_value" id="6C18T^}@bsPRsa7)66%="><field name="ATTR">val</field>
                          <value name="B"><block type="math_number" id="XH)~x@FFCyhSLP^gh={B"><field name="NUM">30</field></block></value></block></value>
                      <statement name="DO0"><block type="control" id="hEPcIr85R|{OoUM_HfI+"><mutation delay_input="false"></mutation>
                          <value name="VALUE"><block type="math_number" id="%Tz]9h.S3Cdp%[rSKt7B"><field name="NUM">30</field></block></value></block></statement></block></next></block></next></block></next></block></xml>
      Ich habe hier im Forum einige Themen zum Fhler "you are sending too fast" gelesen, leider haben mir diese aber nicht geholfen.
      Daher hoffe ich nun auf Eure Unterstützung.
      HoHoHo
      • apollon77
        apollon77 last edited by
        Mal JavaScript Adapter neu gestartet?
        Gesendet vom Handy …
          Ich habe bisher den RPi komplett neu gestartet, die Homematic-Adapter neu installiert.
          Den Javascript-Adapter starte ich trotzdem mal neu - denke aber nicht, dass das etwas bringen wird.
          Interessanterweise hatte ich vorgestern die gleichen Probleme, gestern neu installiert - keine Probleme, heute wieder…
          Edit: Ausgabe des LOG nach Neustart:
          javascript.0 2018-12-24 13:17:11.582 info script.js.Licht.Kerzen_abends_an_2h: registered 0 subscriptions and 1 schedule
          javascript.0 2018-12-24 13:17:11.574 info Start javascript script.js.Licht.Kerzen_abends_an_2h
          javascript.0 2018-12-24 13:17:11.573 info script.js.Rolläden.Rolläden_abends_zu: registered 0 subscriptions and 1 schedule
          javascript.0 2018-12-24 13:17:11.566 info Start javascript script.js.Rolläden.Rolläden_abends_zu
          javascript.0 2018-12-24 13:17:11.565 info script.js.Rolläden.Rolläden_23h_zu: registered 0 subscriptions and 1 schedule
          javascript.0 2018-12-24 13:17:11.555 info Start javascript script.js.Rolläden.Rolläden_23h_zu
          javascript.0 2018-12-24 13:17:11.553 info script.js.Licht.Kerzen_AN_Timer_6h: registered 0 subscriptions and 0 schedules
          javascript.0 2018-12-24 13:17:11.546 info Start javascript script.js.Licht.Kerzen_AN_Timer_6h
          javascript.0 2018-12-24 13:17:11.545 info script.js.Licht.Kerzen_AN_Timer_4h: registered 0 subscriptions and 0 schedules
          javascript.0 2018-12-24 13:17:11.537 info Start javascript script.js.Licht.Kerzen_AN_Timer_4h
          javascript.0 2018-12-24 13:17:11.535 info script.js.Licht.Kerzen_AUS: registered 0 subscriptions and 0 schedules
          javascript.0 2018-12-24 13:17:11.529 info Start javascript script.js.Licht.Kerzen_AUS
          javascript.0 2018-12-24 13:17:11.528 info script.js.Licht.Kerzen_AN: registered 0 subscriptions and 0 schedules
          javascript.0 2018-12-24 13:17:11.521 info Start javascript script.js.Licht.Kerzen_AN
          javascript.0 2018-12-24 13:17:11.518 info script.js.Licht.WHZLichtToggle: registered 0 subscriptions and 0 schedules
          javascript.0 2018-12-24 13:17:11.511 info Start javascript script.js.Licht.WHZLichtToggle
          javascript.0 2018-12-24 13:17:11.510 info script.js.Licht.Außenlicht_abends_an: registered 0 subscriptions and 1 schedule
          javascript.0 2018-12-24 13:17:11.503 info Start javascript script.js.Licht.Außenlicht_abends_an
          javascript.0 2018-12-24 13:17:11.501 info script.js.Licht.Außenlicht_abends_aus: registered 0 subscriptions and 1 schedule
          javascript.0 2018-12-24 13:17:11.495 info Start javascript script.js.Licht.Außenlicht_abends_aus
          javascript.0 2018-12-24 13:17:11.493 info script.js.Licht.Außenlicht_abends_aus_23: registered 0 subscriptions and 1 schedule
          javascript.0 2018-12-24 13:17:11.484 info Start javascript script.js.Licht.Außenlicht_abends_aus_23
          javascript.0 2018-12-24 13:17:11.481 info script.js.Media.enigma2_X: registered 21 subscriptions and 0 schedules
          javascript.0 2018-12-24 13:17:11.475 error script.js.Media.enigma2_X: WEBIF_VERSION in Enigma2 Adapter-Einstellungen AUSWÄHLEN und das Buttonscript erneut starten!
          javascript.0 2018-12-24 13:17:11.474 warn at script.js.Media.enigma2_X:50:16
          javascript.0 2018-12-24 13:17:11.471 warn getState "enigma2.0.command.Button-Config.Webif" not found (3)
          javascript.0 2018-12-24 13:17:11.471 warn at script.js.Media.enigma2_X:49:6
          javascript.0 2018-12-24 13:17:11.468 warn getState "enigma2.0.command.Button-Config.PW" not found (3)
          javascript.0 2018-12-24 13:17:11.467 warn at script.js.Media.enigma2_X:48:8
          javascript.0 2018-12-24 13:17:11.464 warn getState "enigma2.0.command.Button-Config.USER" not found (3)
          javascript.0 2018-12-24 13:17:11.464 warn at script.js.Media.enigma2_X:47:8
          javascript.0 2018-12-24 13:17:11.461 warn getState "enigma2.0.command.Button-Config.Port" not found (3)
          javascript.0 2018-12-24 13:17:11.460 warn at script.js.Media.enigma2_X:46:6
          javascript.0 2018-12-24 13:17:11.454 warn getState "enigma2.0.command.Button-Config.IP" not found (3)
          javascript.0 2018-12-24 13:17:11.444 info Start javascript script.js.Media.enigma2_X
          javascript.0 2018-12-24 13:17:11.440 info script.js.Rolläden.alle_zu: registered 0 subscriptions and 0 schedules
          javascript.0 2018-12-24 13:17:11.433 info Start javascript script.js.Rolläden.alle_zu
          javascript.0 2018-12-24 13:17:11.432 error at TCP.onread (net.js:601:20)
          javascript.0 2018-12-24 13:17:11.432 error at Socket.Readable.push (_stream_readable.js:208:10)
          javascript.0 2018-12-24 13:17:11.431 error at readableAddChunk (_stream_readable.js:250:11)
          javascript.0 2018-12-24 13:17:11.431 error at addChunk (_stream_readable.js:263:12)
          javascript.0 2018-12-24 13:17:11.431 error at Socket.emit (events.js:211:7)
          javascript.0 2018-12-24 13:17:11.431 error at emitOne (events.js:116:13)
          javascript.0 2018-12-24 13:17:11.431 error at Socket._ultron.on (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:138:22)
          javascript.0 2018-12-24 13:17:11.430 error at Receiver.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:139:10)
          javascript.0 2018-12-24 13:17:11.430 error at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:165:16)
          javascript.0 2018-12-24 13:17:11.430 error at Receiver.getData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:330:12)
          javascript.0 2018-12-24 13:17:11.430 error at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:389:14)
          javascript.0 2018-12-24 13:17:11.429 error at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
          javascript.0 2018-12-24 13:17:11.429 error at WebSocket.emit (events.js:211:7)
          javascript.0 2018-12-24 13:17:11.429 error at emitOne (events.js:116:13)
          javascript.0 2018-12-24 13:17:11.429 error at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
          javascript.0 2018-12-24 13:17:11.429 error at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
          javascript.0 2018-12-24 13:17:11.428 error at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
          javascript.0 2018-12-24 13:17:11.428 error at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
          javascript.0 2018-12-24 13:17:11.428 error at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
          javascript.0 2018-12-24 13:17:11.428 error at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
          javascript.0 2018-12-24 13:17:11.427 error at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:456:14)
          javascript.0 2018-12-24 13:17:11.427 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
          javascript.0 2018-12-24 13:17:11.427 error at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
          javascript.0 2018-12-24 13:17:11.427 error at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
          javascript.0 2018-12-24 13:17:11.427 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
          javascript.0 2018-12-24 13:17:11.426 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
          javascript.0 2018-12-24 13:17:11.426 error at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
          javascript.0 2018-12-24 13:17:11.426 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
          javascript.0 2018-12-24 13:17:11.426 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
          javascript.0 2018-12-24 13:17:11.426 error at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
          javascript.0 2018-12-24 13:17:11.425 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
          javascript.0 2018-12-24 13:17:11.425 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
          javascript.0 2018-12-24 13:17:11.425 error at Socket.adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:815:17)
          javascript.0 2018-12-24 13:17:11.425 error at createActiveObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1192:20)
          javascript.0 2018-12-24 13:17:11.425 error at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1138:37)
          javascript.0 2018-12-24 13:17:11.424 error at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:949:28)
          javascript.0 2018-12-24 13:17:11.424 error at Object.createScript (vm.js:80:10)
          javascript.0 2018-12-24 13:17:11.424 error SyntaxError: Unexpected identifier
          javascript.0 2018-12-24 13:17:11.424 error ^^^^^^^^^
          javascript.0 2018-12-24 13:17:11.423 error ALLES AUSWÄHLEN
          javascript.0 2018-12-24 13:17:11.423 error at script.js.javasript_1_rest_Sonne.Astro_Zeiten:1
          javascript.0 2018-12-24 13:17:11.423 error script.js.javasript_1_rest_Sonne.Astro_Zeiten compile failed:
          javascript.0 2018-12-24 13:17:11.410 info Start javascript script.js.javasript_1_rest_Sonne.Astro_Zeiten
          javascript.0 2018-12-24 13:17:11.409 info script.js.Astro.Astro_Zeiten_1: registered 0 subscriptions and 1 schedule
          javascript.0 2018-12-24 13:17:11.380 info Start javascript script.js.Astro.Astro_Zeiten_1
          javascript.0 2018-12-24 13:17:11.379 info script.js.Astro.Zeiten: registered 0 subscriptions and 11 schedules
          javascript.0 2018-12-24 13:17:11.344 info Start javascript script.js.Astro.Zeiten
          javascript.0 2018-12-24 13:17:11.343 info script.js.Rolläden.Rolläden_abends_30%: registered 0 subscriptions and 1 schedule
          javascript.0 2018-12-24 13:17:11.333 info Start javascript script.js.Rolläden.Rolläden_abends_30%
          javascript.0 2018-12-24 13:17:11.331 info script.js.Rolläden.Rolläden_Wochenende_auf: registered 0 subscriptions and 1 schedule
          javascript.0 2018-12-24 13:17:11.310 info Start javascript script.js.Rolläden.Rolläden_Wochenende_auf
          javascript.0 2018-12-24 13:17:11.306 info script.js.Rolläden.Rolläden_wochentags_auf: registered 0 subscriptions and 1 schedule
          javascript.0 2018-12-24 13:17:11.212 info Start javascript script.js.Rolläden.Rolläden_wochentags_auf
          javascript.0 2018-12-24 13:17:11.007 info received all objects
          javascript.0 2018-12-24 13:17:08.858 info received all states
          javascript.0 2018-12-24 13:17:07.521 info requesting all objects
          javascript.0 2018-12-24 13:17:07.518 info requesting all states
          javascript.0 2018-12-24 13:17:07.504 info starting. Version 4.0.5 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.14.0
          javascript.0 2018-12-24 13:17:07.495 error : message handler implemented, but messagebox not enabled. Define common.messagebox in io-package.json for adapter or delete message handler.
          host.raspberrypi 2018-12-24 13:17:02.684 info instance system.adapter.javascript.0 started with pid 24104
          host.raspberrypi 2018-12-24 13:17:00.242 info instance system.adapter.javascript.0 terminated with code 0 (OK)
          host.raspberrypi 2018-12-24 13:17:00.150 info stopInstance system.adapter.javascript.0 killing pid 1630
          host.raspberrypi 2018-12-24 13:17:00.149 info object change system.adapter.javascript.0</anonymous></anonymous></anonymous></anonymous>
          • Peoples
            Peoples last edited by
            @M1R0O:
            Wenn ich das richtig deute, verwendest du den JavaScript Adapter in der Version 4.0.5 oder? Wenn das noch nicht immer so war bzw. du die Fehler erst seit dem Upgrade auf diese Version hast, würde ich einfach wieder auf die stable 3.6.4 gehen.
            Ich hatte zahlreiche Probleme mit dieser Version.
            • apollon77
              Sind alle Probleme mit der 4.0.5 als issues gemeldet?
              • Peoples
                @apollon77:
                Gesendet vom Handy … `
                Zu meiner Schande muss ich gestehen dass ich das Noch nicht gemacht habe.
                Aber ich forste mich die Tage durch die offenen Issues und ergänze was ich feststellen konnte und noch fehlt!
                • apollon77
                  Das wäre super. Die hauptneuerungen sind an sich die Oberfläche und nicht in der Ausführungslogik.
                    Den Downgrade zur Version 3.6.4 habe ich durchgeführt.
                    Ich werde berichten, ob dies erfolgreich war.
                    Danke euch vorerst.
                    Update:
                    Ich habe jetzt einige Tage keine Probleme mehr gehabt. Der Downgrade war somit für mich erfolgreich.
                    THX @peoples
                      Zu früh gefreut!
                      So ganz rund läuft es einfach nicht.
                      Es gibt diverse Probleme, auch nach dem Downgrade des Javascript-Adapters.
                      Seit neuem startet mein ioBroker täglich um 17:00 Uhr neu und ich habe keine Ahnung warum.
                      Das Problem das ich "too fast" sende, habe ich auch z.T. immer noch.
                      Im Anhang mal das gesamte LOG des Tages.
                      Vielleicht kann es sich ja jemand mal ansehen.
                      THX
                      7670_log09.01.19.txt
                      • Peoples
                        Hast du ihn komplett deinstalliert und dann neu aufgesetzt?
                          @peoples:
                          Hast du ihn komplett deinstalliert und dann neu aufgesetzt? `
                          Wen?
                          Ich habe den ioBroker aus einem Backup eingespielt u d dann den Java-Adapter neu aufgesetzt, wg. einiger Probleme.
                          604
