    4. Funktion ausführen wenn Smartphone in Reichweite kommt [Gelöst]
      magifox last edited by
      welche Voraussetzungen müssen erfüllt sein, dass man automtisch eine Funktion auslöst wenn man das Smartphone in Reichweite kommt. (z.B. Heizung ein)
      Gibt es da eine Lösung mit Node-RED?
        dondon4002 last edited by
        Klar, z.b. mit ner Fritzbox und dem Modul "node-red-contrib-fritz"
        Musst hier nur deine MAC Adresse vom Handy angeben und die Fritzbox Daten
        [{"id":"8193bec1.ab0e2","type":"function","z":"12894464.d36a6c","name":"format output","func":"msg.payload = msg.payload.NewActive\nreturn msg;\n","outputs":1,"noerr":0,"x":640,"y":160,"wires":[["e10b8db6.e65618"]]},{"id":"e10b8db6.e65618","type":"debug","z":"12894464.d36a6c","name":"","active":true,"tosidebar":true,"console":false,"complete":"false","x":850,"y":160,"wires":[]},{"id":"1df720be.9bcdb7","type":"fritzbox-in","z":"12894464.d36a6c","device":"226d6f30.6449e","name":"","service":"urn:dslforum-org:service:Hosts:1","action":"GetSpecificHostEntry","arguments":"{\"NewMACAddress\":\"value\"}","x":410,"y":160,"wires":[["8193bec1.ab0e2"]]},{"id":"a24eaab8.1743c","type":"inject","z":"12894464.d36a6c","name":"20:82:C0:26:86:FE","topic":"","payload":"{\"NewMACAddress\":\"30:X7:XD:XX:XX:XX\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":"","x":190,"y":160,"wires":[["1df720be.9bcdb7"]]},{"id":"226d6f30.6449e","type":"fritzbox-config","z":"","name":"","host":"192.168.1.1","port":"49000","ssl":false}]
          danke!!!
          hat auf Anhieb geklappt!
          • haselchen
            haselchen Most Active last edited by
            Bitte ein [Gelöst] in den Threadtitel wegen der Übersichtlichkeit 😉
