    4. [gelöst] snapshot vom flot/browser
      homecineplexx last edited by
      hallo
      ich hab leider nichts gefunden, daher meine frage.
      gibts ein gutes (einfaches) tool für die command-line, mit dem ich meinen flot als .jpg .gif oder sonst was speichern kann,
      damit ichs dann eventuell per mail/telegram usw verschicken kann?
      danke
      lg
        dna909 last edited by
        Probiers doch mit dem Adapter hier: Screenshot mit PhantomJS
        dna909
          super, danke
          werd ich heute probieren.
            Verdammt - installation geht ned.
            Zuerst upgrade auf npm 6.5.0
            Und dann erst kein Erfolg
              jemand eine idee??
              RPI 3B+
              Node.js v8.14.0
              NPM 6.4.1
              $ ./iobroker add phantomjs  --host RPI_Slave1
              NPM version: 6.4.1
              npm install iobroker.phantomjs --production --save --prefix "/opt/iobroker" (System call)
              Unexpected platform or architecture: linux/armIt seems there is no binary available for your platform/architecture
              Try to install PhantomJS globally
              npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm ERR! code ELIFECYCLEnpm ERR! errno 1
              npm ERR! phantomjs-prebuilt@2.1.16 install: `node install.js`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the phantomjs-prebuilt@2.1.16 install script.
              npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              npm ERR!     /home/iobroker/.npm/_logs/2019-01-10T16_32_48_343Z-debug.log
              host.RPI_Master install adapter phantomjs
              NPM version: 6.4.1npm install iobroker.phantomjs --production --save --prefix "/opt/iobroker" (System call)
              npm
              npm
              npm ERR! phantomjs-prebuilt@2.1.16 install: `node install.js`npm ERR! Exit status 1
              npm ERR! npm ERR! Failed at the phantomjs-prebuilt@2.1.16 install script.
              npm ERR!     /home/iobroker/.npm/_logs/2019-01-10T16_33_39_525Z-debug.log
              NPM version: 6.4.1
              npm
              npm ERR! errno 1npm
              npm ERR!
              npm ERR!
               Failed at the phantomjs-prebuilt@2.1.16 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-01-10T16_34_29_877Z-debug.log
              ERROR: host.RPI_Master Cannot install phantomjs
              ERROR: process exited with code 13
                hat niemand eine idee bezüglich meines phantomjs problems oder mit welchem anderen tool ich sowas hinbekommen könnte?
                • Segway
                  Segway last edited by
                  Mal die readme gelesen ???
                  ` > Prerequire
                  It is used prebuild package of phantomjs. If for your system the prebuild does not exist, you cannot use this adapter. On some linux systems the additional library "libfontconfig" is required. It can be installed as follow:
                  sudo apt-get install libfontconfig `
                    danke
                    eigentlich schon, aber heißt das nun, dass es mit phantomjs gar nicht geht am rpi oder nur wenn ich das davor installiere?
                    @Segway:
                    ` > Prerequire
                    79.9k
