    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Ошибка cannot delete
      shimaro last edited by
      всем привет
      с недавнего времени в логе регулярно появляется серия ошибок:
      Cannot	2019-01-10 15:54:23.920	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_14-28_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.919	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_13-37_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.919	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_11-37_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.918	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_09-37_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.918	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_07-37_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.917	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_05-36_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.917	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_03-36_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.916	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_01-36_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.916	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_23-35_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.915	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_23-13_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.915	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_22-34_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.914	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_20-34_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.914	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_18-33_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.914	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_16-33_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.913	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_14-33_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.913	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_12-33_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.912	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_10-33_states.json.gz: {}
      Cannot	2019-01-10 15:54:23.911	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_10-32_states.json.gz: {}
      Вроде бы все работает корректно, но смущает
      Буду рад совету, с чем может быть связано и как убрать.
      Спасибо.
        Pooh last edited by
        Проверить права на папку и от кого иоб запущен
        • V
          voretsen last edited by
          Грохнул день, чтобы разобраться...
          Ошибка не в правах и не в открытых файлах, которые никто не закрыл... Все проще.
          \opt\ioroker\node_modules\iobroker.js-controller\lib\objects\objectsInMemServer.js
          содержит функцию
          function deleteOldBackupFiles() {...},
          в которой вот такой кусок кода:
          try {
                  fs.unlink(backupDir + file);
                } catch (e) {
                   log.error(`Cannot delete file "${backupDir + file}: ${JSON.stringify(e)}`);
          Здесь используется асинхронный unlink без второго параметра и то ли глючит, то ли выплевывает ошибку "по дефолту" - do not know...
          Можно поставить вместо него fs.unlinkSync, но я предпочел не портить синхронностью асинхронность
          fs.unlink(backupDir + file, function (err) {
             if (err) log.error(`Cannot delete file "${backupDir + file}: ${JSON.stringify(err)}`); });
          Такой унлинк вполне хорошо стирает старые бэкапы без ошибок.
          Совершенно аналогичный кусок кода в
          \opt\ioroker\node_modules\iobroker.js-controller\lib\states\statesInMemServer.js
          (см. ту же функцию)
          Кстати, в процессе ковыряния в этом деле выяснилось, что настойки для бэкапов objects und states в opt\iobroker\iobroker-data\iobroker.json не подхватываются сетапом. Разбираться пока некогда.
          Я человек в обчестве новый, готов скинуть инфу разрабам, но с немецким совсем плохо и не знаю куда 🙂
          salambelgorod 1 Reply Last reply Reply Quote 0
          • salambelgorod
            salambelgorod @voretsen last edited by
            @voretsen said in Ошибка cannot delete:
            Привет мил человек, а ты есть в телеграме? https://t.me/iobroker
            По хорошему то пулреквест бы сделать ну или хотяб ишуе..
            https://github.com/ioBroker/ioBroker.js-controller/blob/master/lib/objects/objectsInMemServer.js
