    4. Fehler im Log / Amazon Dash Adapter funktioniert nicht mehr
      Realzippo last edited by
      Hallo.
      Leider funktioniert mein Amazon Das Adapter nicht mehr.
      Von einem anderen User habe ich bereits den Tip, dass es wohl nicht an der Installation der neuen Amazon Dash Adapter Version liegt.
      Das ist die Fehlermeldung aus dem LOG:
      host.raspberrypi 2019-01-19 13:31:25.577 error instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
      host.raspberrypi 2019-01-19 13:31:25.577 error Caught by controller[0]: at Object.Module._extensions..js (module.js:579:10)
      host.raspberrypi 2019-01-19 13:31:25.576 error Caught by controller[0]: at Module._compile (module.js:570:32)
      host.raspberrypi 2019-01-19 13:31:25.576 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
      host.raspberrypi 2019-01-19 13:31:25.576 error Caught by controller[0]: at require (internal/module.js:20:19)
      host.raspberrypi 2019-01-19 13:31:25.576 error Caught by controller[0]: at Module.require (module.js:497:17)
      host.raspberrypi 2019-01-19 13:31:25.576 error Caught by controller[0]: at Function.Module._load (module.js:438:3)
      host.raspberrypi 2019-01-19 13:31:25.576 error Caught by controller[0]: at tryModuleLoad (module.js:446:12)
      host.raspberrypi 2019-01-19 13:31:25.575 error Caught by controller[0]: at Module.load (module.js:487:32)
      host.raspberrypi 2019-01-19 13:31:25.575 error Caught by controller[0]: at Object.Module._extensions..node (module.js:597:18)
      host.raspberrypi 2019-01-19 13:31:25.575 error Caught by controller[0]: at Error (native)
      host.raspberrypi 2019-01-19 13:31:25.572 error Caught by controller[0]: Error: Module version mismatch. Expected 48, got 67.</anonymous>
      • apollon77
        apollon77 last edited by
        Warum doppelt?? Du hast das in einem anderen Thread schon gepostet 😞
        Gesendet vom Handy …
          t1m0 last edited by
          Bekomme es gerade auch nicht mehr installert
          $ ./iobroker add amazon-dash –host rock64
          NPM version: 6.4.1
          npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
          WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
          E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
          ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::Callback(uv_poll_t*, int, int)’:../socket_watcher.cpp:77:60: warning: ‘v8::Local v8::valueNan::MakeCallback(v8::Localv8::object, v8::Localv8::function, int, v8::Localv8::value*)’ is deprecated [-Wdeprecated-declarations]
          Nan::MakeCallback(watcher->handle(), callback, argc, argv);
          In file included from ../socket_watcher.hpp:8:0,
          from ../socket_watcher.cpp:5:
          ../../nan/nan.h:959:46: note: declared here
          NAN_DEPRECATED inline v8::Local v8::valueMakeCallback(
          ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: No such file or directory #include <pcap pcap.h="">^
          compilation terminated.
          make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1
          gyp
          ERR! build error
          gyp ERR!
          stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
          gyp ERR! stack at emitTwo (events.js:126:13)
          gyp ERR! stack at ChildProcess.emit (events.js:214:7)
          gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp
          ERR! System Linux 4.4.167-rockchip64gyp ERR!
          command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap
          gyp ERR! node -v
          v8.15.0gyp ERR! node-gyp -v v3.8.0
          gyp ERR! not ok
          npm
          ERR! code ELIFECYCLEnpm
          ERR! errno 1
          npm ERR!
          pcap@2.1.0 install: node-gyp rebuildnpm ERR! Exit status 1
          npm ERR!
          npm
          ERR! Failed at the pcap@2.1.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2019-01-20T17_43_42_022Z-debug.log
          host.rock64 install adapter amazon-dash
          NPM version: 6.4.1
          npm install iobroker.amazon-dash –production --save --prefix "/opt/iobroker" (System call)</pcap></v8::value></v8::value></v8::function></v8::object></v8::value>
          • apollon77
            Bitte readme zum Adapter lesen. Entweder das angegebene pcap Modul selbst mit apt-get installieren oder der Adapter muss als root installiert werden.
