Kann HomeMatic ReGaHSS und RPC nicht installieren
ich kann die beiden Homematic Adapter nicht installieren. Es kommen folgende Fehlermeldungen.
HomeMatic ReGaHSS
Fertig mit Fehler: (node:5509) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.$ ./iobroker add hm-rega --host raspberrypi ERROR: (node:5509) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead. NPM version: 1.4.21 npm install iobroker.hm-rega --production --save --prefix "/opt/iobroker" (System call) (node:5523) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead. npm WARN package.json ansi-wrap@0.1.0 license should be a valid SPDX license expression npm WARN package.json arraybuffer.slice@0.0.6 No license field. npm WARN package.json asn1js@1.2.12 No license field. npm WARN package.json base64-arraybuffer@0.1.5 No license field. npm WARN package.json bcrypt-pbkdf@1.0.1 No repository field. npm WARN package.json better-assert@1.0.2 No license field. npm WARN package.json blob@0.0.4 No license field. npm WARN package.json buffers@0.1.1 No license field. npm WARN package.json busboy@0.2.14 No license field. npm WARN package.json callsite@1.0.0 No repository field.npm WARN package.json callsite@1.0.0 No license field. npm WARN package.json chainsaw@0.1.0 license should be a valid SPDX license expression npm WARN package.json component-bind@1.0.0 No license field.npm WARN package.json component-emitter@1.1.2 No license field. npm WARN package.json component-inherit@0.0.3 No license field. npm WARN package.json connect-flash@0.1.1 No license field. npm WARN package.json cycle@1.0.3 No license field. npm WARN package.json daemonize2@0.4.2 No repository field.npm WARN package.json daemonize2@0.4.2 No license field. npm WARN package.json dgram@1.0.1 dgram is also the name of a node core module. npm WARN package.json dicer@0.2.5 No license field. npm WARN package.json eyes@0.1.8 No repository field.npm WARN package.json eyes@0.1.8 No license field. npm WARN package.json ftp@0.3.10 No license field. npm WARN package.json glossy@0.1.7 No license field. npm WARN package.json has-binary@0.1.7 No repository field. npm WARN package.json has-binary2@1.0.3 No repository field. npm WARN package.json i@0.3.6 No license field.npm WARN package.json indexof@0.0.1 No repository field. npm WARN package.json indexof@0.0.1 No license field. npm WARN package.json json-schema@0.2.3 No license field. npm WARN package.json json3@3.3.2 No license field. npm WARN package.json jsonify@0.0.0 license should be a valid SPDX license expression npm WARN package.json ms@0.7.1 No license field. npm WARN package.json object-component@0.0.3 No repository field. npm WARN package.json object-component@0.0.3 No license field. npm WARN package.json options@0.0.6 No license field. npm WARN package.json passport-local@1.0.0 No license field. npm WARN package.json passport-strategy@1.0.0 No license field. npm WARN package.json pause@0.0.1 No repository field.npm WARN package.json pause@0.0.1 No license field. npm WARN package.json pkijs@1.3.33 No license field. npm WARN package.json pushover-notifications@0.2.4 No license field. npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module. npm WARN package.json put@0.0.6 license should be a valid SPDX license expression npm WARN package.json revalidator@0.1.8 license should be a valid SPDX license expression npm WARN package.json sax@0.4.3 license should be a valid SPDX license expression npm WARN package.json streamsearch@0.1.2 No license field.npm WARN package.json string_decoder@0.10.31 string_decoder is also the name of a node core module. npm WARN package.json suncalc@1.8.0 No license field. npm WARN package.json to-array@0.1.4 No license field. npm WARN package.json traverse@0.3.9 license should be a valid SPDX license expression npm WARN package.json utile@0.3.0 No license field. npm WARN package.json unix-dgram@0.2.3 license should be a valid SPDX license expression npm WARN package.json wake_on_lan@0.0.4 No license field. npm WARN package.json xmlbuilder@0.4.2 No license field. npm WARN package.json xmlhttprequest-ssl@1.5.3 No license field. npm ERR! Error: Method Not Allowednpm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)npm ERR! at /usr/share/npm/lib/cache/add-named.js:203:12npm ERR! at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7) npm ERR! at FSReqWrap.oncomplete (fs.js:135:15) npm ERR! If you need help, you may report this *entire* log, npm ERR! including the npm and node versions, at: npm ERR! <http: github.com/npm/issues=""> npm ERR! System Linux 4.14.79-v7+npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.hm-rega" "--production" "--save" "--prefix" "/opt/iobroker" npm ERR! cwd /npm ERR! node -v v8.11.1npm ERR! npm -v 1.4.21 npm ERR! code E405 npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /npm-debug.log npm ERR! not ok code 0 host.raspberrypi create instance hm-rega ERROR: host.raspberrypi error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json' ERROR: process exited with code 20</http:>und bei HomeMatic RPC:
Fertig mit Fehler: (node:5587) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.$ ./iobroker add hm-rpc --host raspberrypi ERROR: (node:5587) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead. NPM version: 1.4.21 npm install iobroker.hm-rpc --production --save --prefix "/opt/iobroker" (System call) (node:5601) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead. npm WARN package.json ansi-wrap@0.1.0 license should be a valid SPDX license expression npm WARN package.json arraybuffer.slice@0.0.6 No license field. npm WARN package.json asn1js@1.2.12 No license field. npm WARN package.json base64-arraybuffer@0.1.5 No license field. npm WARN package.json bcrypt-pbkdf@1.0.1 No repository field. npm WARN package.json better-assert@1.0.2 No license field. npm WARN package.json blob@0.0.4 No license field. npm WARN package.json buffers@0.1.1 No license field. npm WARN package.json busboy@0.2.14 No license field. npm WARN package.json callsite@1.0.0 No repository field.npm WARN package.json callsite@1.0.0 No license field. npm WARN package.json chainsaw@0.1.0 license should be a valid SPDX license expression npm WARN package.json component-bind@1.0.0 No license field. npm WARN package.json component-emitter@1.1.2 No license field. npm WARN package.json component-inherit@0.0.3 No license field. npm WARN package.json connect-flash@0.1.1 No license field. npm WARN package.json cycle@1.0.3 No license field. npm WARN package.json daemonize2@0.4.2 No repository field.npm WARN package.json daemonize2@0.4.2 No license field. npm WARN package.json dgram@1.0.1 dgram is also the name of a node core module. npm WARN package.json dicer@0.2.5 No license field. npm WARN package.json eyes@0.1.8 No repository field.npm WARN package.json eyes@0.1.8 No license field. npm WARN package.json ftp@0.3.10 No license field. npm WARN package.json glossy@0.1.7 No license field. npm WARN package.json has-binary@0.1.7 No repository field. npm WARN package.json has-binary2@1.0.3 No repository field. npm WARN package.json i@0.3.6 No license field. npm WARN package.json indexof@0.0.1 No repository field.npm WARN package.json indexof@0.0.1 No license field. npm WARN package.json json-schema@0.2.3 No license field. npm WARN package.json json3@3.3.2 No license field. npm WARN package.json jsonify@0.0.0 license should be a valid SPDX license expression npm WARN package.json ms@0.7.1 No license field. npm WARN package.json object-component@0.0.3 No repository field. npm WARN package.json object-component@0.0.3 No license field. npm WARN package.json options@0.0.6 No license field. npm WARN package.json passport-local@1.0.0 No license field. npm WARN package.json passport-strategy@1.0.0 No license field. npm WARN package.json pause@0.0.1 No repository field. npm WARN package.json pause@0.0.1 No license field. npm WARN package.json pkijs@1.3.33 No license field. npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module. npm WARN package.json pushover-notifications@0.2.4 No license field. npm WARN package.json put@0.0.6 license should be a valid SPDX license expression npm WARN package.json revalidator@0.1.8 license should be a valid SPDX license expression npm WARN package.json sax@0.4.3 license should be a valid SPDX license expression npm WARN package.json streamsearch@0.1.2 No license field. npm WARN package.json string_decoder@0.10.31 string_decoder is also the name of a node core module. npm WARN package.json suncalc@1.8.0 No license field. npm WARN package.json to-array@0.1.4 No license field. npm WARN package.json traverse@0.3.9 license should be a valid SPDX license expression npm WARN package.json utile@0.3.0 No license field. npm WARN package.json wake_on_lan@0.0.4 No license field. npm WARN package.json xmlbuilder@0.4.2 No license field. npm WARN package.json xmlhttprequest-ssl@1.5.3 No license field. npm WARN package.json unix-dgram@0.2.3 license should be a valid SPDX license expression npm ERR! Error: Method Not Allowed npm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)npm ERR! at /usr/share/npm/lib/cache/add-named.js:203:12 npm ERR! at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7) npm ERR! at FSReqWrap.oncomplete (fs.js:135:15) npm ERR! If you need help, you may report this *entire* log, npm ERR! including the npm and node versions, at: npm ERR! <http: github.com/npm/issues=""> npm ERR! System Linux 4.14.79-v7+ npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.hm-rpc" "--production" "--save" "--prefix" "/opt/iobroker" npm ERR! cwd / npm ERR! node -v v8.11.1npm ERR! npm -v 1.4.21 npm ERR! code E405 npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /npm-debug.log npm ERR! not ok code 0 host.raspberrypi create instance hm-rpc ERROR: host.raspberrypi error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json' ERROR: process exited with code 20</http:>Was mache ich falsch?
Manfred
Puh du bist auf npm 1.4 installiere mal npm 4
npm i npm@4 -g
