    4. Probleme Yahka 0.9.0
      michacolonia last edited by
      Hat hier noch jemand Probleme nach dem Update auf 0.9.0
      host.raspberrypi	2019-01-25 17:20:34.069	info	Restart adapter system.adapter.yahka.0 because enabled
      host.raspberrypi	2019-01-25 17:20:34.069	error	instance system.adapter.yahka.0 terminated with code 0 (OK)
      host.raspberrypi	2019-01-25 17:20:34.069	error	Caught by controller[0]: at TIOBrokerAdapter../yahka.ioBroker-adapter.ts.TIOBrokerAdapter.adapterReady (/opt/iobroker/node_modules/iobroker.yahka/main.js:2169:14)
      host.raspberrypi	2019-01-25 17:20:34.068	error	Caught by controller[0]: at TIOBrokerAdapter../yahka.ioBroker-adapter.ts.TIOBrokerAdapter.createHomeKitBridges (/opt/iobroker/node_modules/iobroker.yahka/main.js:2192:27)
      host.raspberrypi	2019-01-25 17:20:34.068	error	Caught by controller[0]: at new THomeKitBridge (/opt/iobroker/node_modules/iobroker.yahka/main.js:1583:14)
      host.raspberrypi	2019-01-25 17:20:34.068	error	Caught by controller[0]: at THomeKitBridge../yahka.homekit-bridge.ts.THomeKitBridge.init (/opt/iobroker/node_modules/iobroker.yahka/main.js:1595:42)
      host.raspberrypi	2019-01-25 17:20:34.068	error	Caught by controller[0]: at THomeKitBridge../yahka.homekit-bridge.ts.THomeKitBridge.createDevice (/opt/iobroker/node_modules/iobroker.yahka/main.js:1669:22)
      host.raspberrypi	2019-01-25 17:20:34.068	error	Caught by controller[0]: at THomeKitBridge../yahka.homekit-bridge.ts.THomeKitBridge.initService (/opt/iobroker/node_modules/iobroker.yahka/main.js:1700:22)
      host.raspberrypi	2019-01-25 17:20:34.067	error	Caught by controller[0]: at THomeKitBridge../yahka.homekit-bridge.ts.THomeKitBridge.initCharacteristic (/opt/iobroker/node_modules/iobroker.yahka/main.js:1725:57)
      host.raspberrypi	2019-01-25 17:20:34.067	error	Caught by controller[0]: at TIOBrokerAdapter../yahka.ioBroker-adapter.ts.TIOBrokerAdapter.CreateBinding (/opt/iobroker/node_modules/iobroker.yahka/main.js:2312:64)
      host.raspberrypi	2019-01-25 17:20:34.067	error	Caught by controller[0]: at Object.createConversionFunction (/opt/iobroker/node_modules/iobroker.yahka/main.js:979:61)
      host.raspberrypi	2019-01-25 17:20:34.066	error	Caught by controller[0]: at Object../yahka.functions/conversion.inverse.ts.TIoBrokerConversion_Inverse.create [as inverse] (/opt/iobroker/node_modules/iobroker.yahka/main.js:592:29)
      host.raspberrypi	2019-01-25 17:20:34.065	error	Caught by controller[0]: TypeError: this.castToNumber is not a function
      host.raspberrypi	2019-01-25 17:20:30.402	info	instance system.adapter.yahka.0 started with pid 4402
      • Homer.J.
        Homer.J. last edited by
        Hab auch ein Problem bei der Installation, iobroker läuft im Docker.
        Hier mal die Ausgabe bei der Installation.
        ! $ ./iobroker upgrade yahka
        ! Update yahka from @0.8.2 to @0.9.0
        ! NPM version: 6.4.1
        ! npm install iobroker.yahka@0.9.0 –production --save --prefix "/opt/iobroker" (System call)
        ! npm
        ! WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.yahka"
        ! npm
        ! WARN deprecated jscs-preset-wikimedia@1.0.1: Deprecated in favour of eslint-config-wikimedia. -- https://phabricator.wikimedia.org/T118941
        ! npm
        ! WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
        ! npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
        ! npm
        ! notice created a lockfile as package-lock.json. You should commit this file.
        ! got /opt/iobroker/node_modules/iobroker.yahka/admin
        ! upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
        ! Update "system.adapter.yahka.0"
        ! upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
        ! upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
        ! upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
        ! upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
        ! upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
        ! upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
        ! upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
        ! upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
        ! upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff application/font-woff
        ! upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf application/x-font-ttf
        ! upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
        ! upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
        ! upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
        ! upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
        ! upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
        ! upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
        ! upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
        ! upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
        ! upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
        ! Adapter "yahka" updated
        ! process exited with code 0
        und hier der Log.
        ! host.iobroker 2019-01-25 17:42:27.527 error instance system.adapter.yahka.0 terminated with code 6 (uncaught exception)
        ! Caught 2019-01-25 17:42:27.527 error by controller[1]: at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
        ! Caught 2019-01-25 17:42:27.527 error by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
        ! Caught 2019-01-25 17:42:27.527 error by controller[1]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
        ! Caught 2019-01-25 17:42:27.527 error by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
        ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
        ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
        ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
        ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
        ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.yahka/main.js:2282:21)
        ! Caught 2019-01-25 17:42:27.526 error by controller[1]: at convertStateValueToNumber (/opt/iobroker/node_modules/iobroker.yahka/main.js:2331:41)
        ! Caught 2019-01-25 17:42:27.526 error by controller[1]: TypeError: Cannot read property 'val' of null
        ! Caught 2019-01-25 17:42:27.526 error by controller[0]: HAP Warning: Characteristic 00000072-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000043-0000-1000-8000-0026BB765291. Adding anyway.</anonymous></anonymous></anonymous>
        PS: gelöst Docker Container upgedatet
        • Espace0401
          Espace0401 last edited by
          Bei mir läuft die Installation auch mit exit 0 durch, allerdings bleibt es die Version 0.8.2.
          • Asgothian
            Asgothian Developer last edited by
            Ich habe das Problem auch, aber nur wenn ich die “inverse” Transfer Funktion nutze. Aktuell habe ich statt dessen scaleint im Einsatz (0,100 HomeKit zu 100,0 iobroker). Damit geht es.
            A
              MacGyver last edited by
              ich habe gerade auf 0.9.0 aktualisiert und nun geht garnichts mehr
              host.ioBroker-Master	2019-01-27 09:53:15.376	error	instance system.adapter.yahka.0 terminated with code 6 (uncaught exception)
              Caught	2019-01-27 09:53:15.375	error	by controller[1]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
              Caught	2019-01-27 09:53:15.375	error	by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
              Caught	2019-01-27 09:53:15.375	error	by controller[1]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
              Caught	2019-01-27 09:53:15.374	error	by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
              Caught	2019-01-27 09:53:15.374	error	by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
              Caught	2019-01-27 09:53:15.374	error	by controller[1]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
              Caught	2019-01-27 09:53:15.373	error	by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
              Caught	2019-01-27 09:53:15.373	error	by controller[1]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
              Caught	2019-01-27 09:53:15.372	error	by controller[1]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.yahka/main.js:2282:21)
              Caught	2019-01-27 09:53:15.372	error	by controller[1]: at convertStateValueToNumber (/opt/iobroker/node_modules/iobroker.yahka/main.js:2331:40)
              Caught	2019-01-27 09:53:15.371	error	by controller[1]: TypeError: Cannot read property 'val' of null
              Caught	2019-01-27 09:53:15.370	error	by controller[0]: HAP Warning: Characteristic 00000022-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000080-0000-1000-8000-0026BB765291\. Adding anyway.</anonymous></anonymous></anonymous>
              • Paulchen67
                Paulchen67 last edited by
                Habe auch auf 0.9.0 Update gemacht.
                Danach ging gar nichts mehr. IoBroker startet um sich kurz darauf komplett
                aufzuhängen. Stecker ziehen und das gleiche Spiel in Dauerschleife.
                Hatte Mühe da mal dazwischen zu kommen und den Yahka Adapter zu Stoppen den ich
                schon als Übeltäter vermutet hatte. Jetzt, da der Adapter steht, geht wieder alles.
                Habe downgrade auf 0.8.2 versucht was aber stand jetzt noch nicht funktioniert hat.
                Ich verstehe nicht warum man ein Update hinstellt welches alles zusammenbügelt.
                Wird sowas vorher nicht getestet bevor es auf die Allgemeinheit los gelassen wird?
                • X
                  xADDRx last edited by
                  gleiches problem
                    Micky79 last edited by
                    Hatte ich auch.
                    0.9.1 behebt zumindest bei mir die Probleme.
                    • X
                      Ein Update funktioniert auch nicht bei mir
                      • Asgothian
                        @xADDRx:
                        gleiches problem `
                        Welches der oben angegebenen Probleme:
                        • fehler in der Inverse conversion Funktion crashed Yahka ?
                        • allgemeiner Fehler crashed Yahka, aber ioBroker läuft normal weiter ?
                        • Fehler im Yahka fuehrt dazu das sich der ioBroker aufzuhängen scheint ?
                        Bitte bei Fehlern zumindest mal einen Log Auszug mitgeben, dann können wir schauen was da schief geht.
                        A.
                        • Espace0401
                          So sieht bei mir der Versuch aus, den Adapter zu aktualisieren:
                          Update yahka from @0.8.2 to @0.9.1
                          NPM version: 6.4.1
                          npm install iobroker.yahka@0.9.1 --production --save --prefix "/opt/iobroker" (System call)
                          npm
                          ERR!
                          code 128
                          npm
                          ERR!
                           Command failed: /usr/bin/git submodule update -q --init --recursivenpm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-485124bc': Keine Berechtigung
                          npm ERR!
                          npm
                           ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2019-01-31T15_32_05_540Z-debug.log
                          upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
                          upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
                          Obwohl er schreibt yahka updated, ist das nicht der Fall. Habe es bei zwei verschiedenen Systemen versucht.
                          • Asgothian
                            @Espace0401:
                            Obwohl er schreibt yahka updated, ist das nicht der Fall. Habe es bei zwei verschiedenen Systemen versucht. `
                            Das Log beschwert sich darüber das kein Zugriff auf ein bestimmtes Verzeichnis existiert:
                            ERR!
                            npm ERR!
                            npm
                            Du müsstest schauen was in diesem Log drin steht. Anscheinend gibt es Rechtsprobleme beim Git command.
                            Ich würde zunächst schauen welche Rechte /root/.npm/_cacache hat, und mit welchem Benutzer ioBroker läuft - mit dem würde auch der Adapter installiert.
                            Nachtrag: kannst Du versuchen einen anderen Adapter von Github zu installieren ? Dann wissen wir zumindest ob es an der Installation über Github oder am Yahka Adapter liegt.
                            A.
                            • X
                              @Asgothian:
                              @xADDRx:
                              gleiches problem `
                              A. `
                              Problem gelöst.
                              Es lag am Cache!
                              npm cache clean, danach ging das Update durch
                              • Asgothian
                                @xADDRx:
                                Problem gelöst.
                                Es lag am Cache!
                                Danke `
                                Fein.
                                • Espace0401
                                  @Asgothian:
                                  @Espace0401:
                                  ERR!
                                  npm ERR!
                                  npm
                                  A. `
                                  Andere Adapter konnte ich Problemlos installieren. Muss ich mir heute Abend mal genauer ansehen.
                                  • Espace0401
                                    Ich habe den Adapter nun erfolgreich über die Konsole aktualisiert. Jetzt die für mich wichtigste Frage: (jw) added io functions for HomeMatic dimmers (#30 and #75). Genau diese Dimmer bekomme ich nicht zum laufen. Könnte mir jemand mal, bei dem es funktioniert seine Einstellungen posten, Danke.
                                    Gruss Joachim
                                    • Espace0401
                                      @Espace0401:
                                      Gruss Joachim `
                                      Hat sich erledigt. Nachdem ich nochmal einen Upload des Adapters gemacht habe, ist die Funktion homematic.dimmer auswählbar. Klappt nun endlich alles so wie es soll. Danke für die gute Arbeit.
                                      1.2k
                                      81.1k
                                      1506
