    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Ошибки при установке Homekit
      avtomat78 last edited by
      Здравствуйте, помогите кто в курсе, бьюсь неделю ничего не получается, отказывается устанавливаться Homekit, Виндовс 7, в логе установки пишет
      ! $ ./iobroker add yahka –host Andrey-PC
      ! NPM version: 6.4.1
      ! npm install iobroker.yahka --production --save --prefix "D:/Program Files/ioBroker" (System call)
      ! gyp
      ! ERR! configure error gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
      ! gyp ERR! stack at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)
      ! gyp ERR!
      ! stack at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
      ! gyp ERR! stack at FSReqWrap.oncomplete (fs.js:154:21)
      ! gyp ERR! System Windows_NT 6.1.7601
      ! gyp ERR! command
      ! "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"gyp ERR!
      ! cwd
      ! D:\Program Files\ioBroker\node_modules\iobroker.yahka\node_modules\curve25519-ngyp ERR! node -v v10.13.0
      ! gyp ERR! node-gyp -v
      ! v3.8.0gyp ERR! not ok
      ! npm
      ! ERR! code ELIFECYCLEnpm ERR! errno
      ! 1
      ! npm
      ! ERR!
      ! curve25519-n@1.4.0 install: node-gyp rebuild
      ! npm
      ! ERR!
      ! Exit status 1
      ! npm
      ! ERR!
      ! npm
      ! ERR!
      ! Failed at the curve25519-n@1.4.0 install script.
      ! npm
      ! ERR!
      ! This is probably not a problem with npm. There is likely additional logging output above.
      ! npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-02-02T20_27_53_094Z-debug.log
      ! host.Andrey-PC install adapter yahka
      ! gyp
      ! gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR!
      ! stack at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)gyp ERR! stack at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)
      ! gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
      ! gyp ERR! stack
      ! at FSReqWrap.oncomplete (fs.js:154:21)
      ! gyp ERR!
      ! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"gyp ERR! cwd D:\Program Files\ioBroker\node_modules\iobroker.yahka\node_modules\curve25519-n
      ! gyp ERR! node -v v10.13.0gyp
      ! ERR! node-gyp -v v3.8.0gyp ERR! not ok
      ! npm
      ! ERR! code ELIFECYCLEnpm ERR! errno 1
      ! npm ERR! curve25519-n@1.4.0 install: node-gyp rebuildnpm ERR! Exit status 1
      ! npm ERR!
      ! npm ERR! Failed at the curve25519-n@1.4.0 install script.
      ! npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      ! npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-02-02T20_28_01_959Z-debug.log
      ! gyp
      ! gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)
      ! gyp ERR! stack at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)
      ! gyp ERR! System Windows_NT 6.1.7601gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
      ! gyp ERR! cwd D:\Program Files\ioBroker\node_modules\iobroker.yahka\node_modules\curve25519-n
      ! gyp ERR! node-gyp -v v3.8.0
      ! gyp
      ! ERR! not ok
      ! npm
      ! 1
      ! ERR! Exit status 1npm ERR!
      ! npm
      ! ERR! Failed at the curve25519-n@1.4.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      ! npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-02-02T20_28_09_016Z-debug.log
      ! ERROR: host.Andrey-PC Cannot install yahka
      ! ERROR: process exited with code 13</anonymous></anonymous></anonymous>
      1.1k
      81.0k
