    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Ошибки драйвера SQL
    Ошибки драйвера SQL
    • I
      instalator last edited by
      sql-0 2016-02-13 14:40:11 error Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(32, 1455352801000, 'HDMI2', 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '32-1455352801000' for key 'PRIMARY'
      sql-0 2016-02-13 14:37:00 info sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0: {"result":[{"ts":1455266437,"val":null},{"ts":1455266869,"val":null},{"ts":1455267301,"val":null},{"ts":1455267733,"val":null},{
      sql-0 2016-02-13 14:37:00 info Send: 200 of: 2528 in: 156ms
      sql-0 2016-02-13 14:36:58 info sendTo "getHistory" to system.adapter.admin.0 from system.adapter.sql.0: {"result":[{"ts":1455352062,"val":null,"ack":true,"from":"system.adapter.mqtt.0","q":0},{"ts":1455352073,"val":null,"ack":true
      sql-0 2016-02-13 14:36:58 info Send: 50 of: 50 in: 62ms
      sql-0 2016-02-13 14:35:11 error Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(32, 1455352501000, 'HDMI2', 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '32-1455352501000' for key 'PRIMARY'
      sql-0 2016-02-13 14:30:11 error Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(32, 1455352201000, 'HDMI2', 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '32-1455352201000' for key 'PRIMARY'
        @instalator:
        ! sql-0 2016-02-13 14:40:11 error Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(32, 1455352801000, 'HDMI2', 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '32-1455352801000' for key 'PRIMARY' sql-0 2016-02-13 14:37:00 info sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0: {"result":[{"ts":1455266437,"val":null},{"ts":1455266869,"val":null},{"ts":1455267301,"val":null},{"ts":1455267733,"val":null},{ sql-0 2016-02-13 14:37:00 info Send: 200 of: 2528 in: 156ms sql-0 2016-02-13 14:36:58 info sendTo "getHistory" to system.adapter.admin.0 from system.adapter.sql.0: {"result":[{"ts":1455352062,"val":null,"ack":true,"from":"system.adapter.mqtt.0","q":0},{"ts":1455352073,"val":null,"ack":true sql-0 2016-02-13 14:36:58 info Send: 50 of: 50 in: 62ms sql-0 2016-02-13 14:35:11 error Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(32, 1455352501000, 'HDMI2', 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '32-1455352501000' for key 'PRIMARY' sql-0 2016-02-13 14:30:11 error Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q) VALUES(32, 1455352201000, 'HDMI2', 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '32-1455352201000' for key 'PRIMARY' `
        Какие настройки?
        • I
          Раньше не было ошибки, настройки не менял.
          • I
            Ошибка периодически выскакивает:
            sql.0	2016-02-26 18:23:50	error	sql.0 Cannot insert INSERT INTO iobroker.ts_string (id, ts, val, ack, _from, q)
             VALUES(32, 1456489420000, 'HDMI2', 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '32-1456489420000' for key 'PRIMARY'
              DAndre last edited by
              Тоже так было,(после оптимизации sql) + винт грузил ужасно.
              Не стал заморачиватся все переменные перевел на History.
              Потом переменные которые мне нужны (типа данные с портов) вернул на sql, 2 недели полет нормальный.
                Haus last edited by
                @DAndre:
                Потом переменные которые мне нужны (типа данные с портов) вернул на sql, 2 недели полет нормальный. `
                Не вы неправы, у меня база вообще на другом сервере лежит вместе с еще одной базой от Андрея все крутится как надо. Может диск кривой?
                  HDD я упомянул так, для информации.
                  После указанных телодвижений у меня пропала ошибка аналогичная как у instalator. Может конечно совпадение.
                    ford7 last edited by
                    Тоже начали выскакивать ошибки:
                    sql-0 2016-02-29 09:11:00 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1456722654000, 88, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                    host-zvmubn 2016-02-29 04:26:11 info Delete log file iobroker.log.2016-02-22
                    sql-0 2016-02-29 03:29:58 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1456702197000, 88, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                    [256_sql3.jpg](/assets/uploads/files/256_sql3.jpg)
                      spectrekr last edited by
                      Аналогично, сегодня посыпались.
                      ! sql-0 2016-02-29 12:24:52 error Cannot insert INSERT INTO iobroker.ts_number (id, ts, val, ack, _from, q) VALUES(7, 1456737892000, 771, 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '7-1456737892000' for key 'PRIMARY'
                      ! sql-0 2016-02-29 12:24:52 error Cannot insert INSERT INTO iobroker.ts_number (id, ts, val, ack, _from, q) VALUES(6, 1456737892000, 19.33, 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '6-1456737892000' for key 'PRIMARY'
                      ! sql-0 2016-02-29 12:24:52 error Cannot insert INSERT INTO iobroker.ts_number (id, ts, val, ack, _from, q) VALUES(5, 1456737892000, 34.67, 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '5-1456737892000' for key 'PRIMARY'
                      ! sql-0 2016-02-29 12:24:52 error Cannot insert INSERT INTO iobroker.ts_number (id, ts, val, ack, _from, q) VALUES(4, 1456737892000, 49.94, 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '4-1456737892000' for key 'PRIMARY'
                      ! sql-0 2016-02-29 12:24:52 error Cannot insert INSERT INTO iobroker.ts_number (id, ts, val, ack, _from, q) VALUES(3, 1456737892000, 31, 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '3-1456737892000' for key 'PRIMARY'
                      ! sql-0 2016-02-29 12:24:52 error Cannot insert INSERT INTO iobroker.ts_number (id, ts, val, ack, _from, q) VALUES(2, 1456737892000, 0.58, 1, 1, 0);: Error: ER_DUP_ENTRY: Duplicate entry '2-1456737892000' for key 'PRIMARY'
                        SQL типов 4 штуки. Пожалуйста конкретизируйте.
                          В моем случае это MySQL
                            Haus last edited by
                            SQL Hystory 0.1.2 MySQL
                              RDim last edited by
                              Подключен к удаленному серверу MySQL 5.5.47 на debian 7.9, cubieboard.
                              ioBroker на debian 8.3 , cubietruck.
                              Полет отличный, ошибок MySQL не замечено.
                                Странно, но со вчерашнего утра больше ни одной ошибки не выскочило.
                                  У меня не перестает.
                                  sql-0	2016-05-12 11:20:26	error	Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463037621000, 38.38, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                  P. s. SQLite3
                                  • E
                                    electric last edited by
                                    @ford7:
                                    P. s. SQLite3 `
                                    Подтверждаю, у меня тоже сыплет ошибки. Настройки по-умолчанию (SQLite3).
                                    Система Linux Debian, БД находится здесь````
                                    /opt/iobroker/iobroker-data/sqlite/sqlite.db
                                    Пробовал играться с настройками минимального интервала (ms), все равно ошибки выскакивают.
                                    sql-0 2016-05-16 22:02:20 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425330000, 25.41, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 22:01:50 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(4, 1463425300000, 46.26, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 22:01:35 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425285000, 25.36, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 22:01:05 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425255000, 25.35, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 22:00:50 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425240000, 25.34, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 22:00:35 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425225000, 25.29, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 22:00:20 warn Cannot get index of "system.host.vm32test.memHeapTotal": Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 22:00:20 error Cannot select SELECT id, type FROM datapoints WHERE name='system.host.vm32test.memHeapTotal';: Error: SQLITE_BUSY: database is locked
                                    host-vm32test 2016-05-16 21:55:21 info instance system.adapter.sql.0 terminated with code 0 (OK)
                                    sql-0 2016-05-16 21:59:50 warn Cannot get index of "system.host.vm32test.memHeapTotal": Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:59:50 error Cannot select SELECT id, type FROM datapoints WHERE name='system.host.vm32test.memHeapTotal';: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:59:35 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(4, 1463425165000, 46.06, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:59:20 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425150000, 25.2, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:59:05 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425135000, 25.17, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:58:50 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425120000, 25.19, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:58:20 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425090000, 25.1, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:58:07 info Send: 4 of: 4 in: 3ms
                                    sql-0 2016-05-16 21:58:05 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425075000, 24.44, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:57:35 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463425045000, 24.45, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:57:16 info Send: 1 of: 1 in: 4ms
                                    sql-0 2016-05-16 21:56:05 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(2, 1463424955000, 23.85, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:56:05 warn Cannot get index of "system.host.vm32test.memHeapTotal": Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:56:05 error Cannot select SELECT id, type FROM datapoints WHERE name='system.host.vm32test.memHeapTotal';: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:55:38 info enabled logging of system.host.vm32test.load
                                    sql-0 2016-05-16 21:55:38 info enabled logging of system.host.vm32test.memRss
                                    sql-0 2016-05-16 21:55:38 info enabled logging of system.host.vm32test.memHeapTotal
                                    sql-0 2016-05-16 21:55:38 info enabled logging of system.host.vm32test.memHeapUsed
                                    sql-0 2016-05-16 21:55:51 error Cannot delete DELETE FROM ts_number WHERE id=3 AND ts < 1431888901;: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:55:51 warn Cannot get index of "system.host.vm32test.memHeapTotal": Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:55:51 error Cannot insert INSERT INTO datapoints (name, type) VALUES('system.host.vm32test.memHeapTotal', 0);: Error: SQLITE_BUSY: database is locked
                                    sql-0 2016-05-16 21:55:48 info No Data
                                    sql-0 2016-05-16 21:55:48 warn Cannot get index of "system.host.vm32test.load": id not found
                                    sql-0 2016-05-16 21:55:38 info Connected to sqlite
                                    sql-0 2016-05-16 21:55:38 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.sql
                                      @electric:
                                      @ford7:
                                      P. s. SQLite3 `
                                      Я уже всё поправил. После 21го опубликую. Или попробуйте с гита
                                        Может я что-то не так делаю…
                                        2016-07-26 22:31:55.986	info	Update repository "fast-online" under "http://download.iobroker.net/sources-dist.json"
                                        sql-0	2016-07-26 21:41:25.562	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469554824557, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:39:25.428	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469554704424, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:37:25.357	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469554584340, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:35:25.189	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469554464175, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:33:25.145	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469554344130, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:31:25.053	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469554224039, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:29:24.995	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469554103986, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:27:24.939	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469553983932, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:25:24.883	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469553863869, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:23:24.819	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469553743803, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:21:24.753	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469553623745, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:17:24.658	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469553383643, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:15:24.599	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469553263588, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:13:24.541	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469553143537, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:11:24.508	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469553023501, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:09:24.444	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469552903431, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                        sql-0	2016-07-26 21:07:24.380	error	Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(5, 1469552783375, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
                                          Может быть такое, что базу кто то ещё открыл?
                                          • E
                                            @Bluefox:
                                            Может быть такое, что базу кто то ещё открыл? `
                                            я тестил версию драйвера пару недель назад с sqlite, та же ошибка была.
                                            Сейчас попробовал, настроил хранение в sqlite параметров памяти сервера, настройки по-умолчанию.
                                            После перезапуска сервера (полного) такие ошибки в логе:
                                            ! sql.0 2016-07-27 11:09:10.567 error sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606939556, 21.56, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql.0 2016-07-27 11:09:10.565 error sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(5, 1469606939556, 44.69, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:08:55.557 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(1, 1469606924547, 150, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:08:55.556 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606924547, 22.01, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:08:40.550 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606909539, 21.72, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:08:40.549 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(5, 1469606909539, 44.84, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:08:25.555 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606894534, 21.19, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:08:25.555 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(5, 1469606894533, 43.8, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:07:55.537 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(1, 1469606864518, 128, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:07:55.533 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606864517, 21.31, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:07:40.524 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(1, 1469606849510, 129, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:07:40.520 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606849510, 21.73, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:07:25.512 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606834501, 21.26, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:07:10.510 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(5, 1469606819492, 45.2, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:07:10.509 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606819493, 21.71, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:06:55.505 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(6, 1469606804487, 31.65, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:06:55.505 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606804487, 21.04, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:06:41.485 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606789468, 21.16, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:06:25.462 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(6, 1469606774450, 30.69, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:06:10.456 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(3, 1469606759441, 33.45, 1, 1, 0);: Error: SQLITE_BUSY: database is locked host-vm32test 2016-07-27 11:06:06.045 info instance system.adapter.yr.0 terminated with code 0 (OK) yr-0 2016-07-27 11:06:00.980 info got weather data from yr.no yr-0 2016-07-27 11:06:00.817 info starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.yr host-vm32test 2016-07-27 11:06:00.438 info instance system.adapter.yr.0 started with pid 6999 sql-0 2016-07-27 11:05:55.458 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(6, 1469606744431, 61.55, 1, 1, 0);: Error: SQLITE_BUSY: database is locked sql-0 2016-07-27 11:05:55.457 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(5, 1469606744431, 58.62, 1, 1, 0);: Error: SQLITE_BUSY: database is locked host-vm32test 2016-07-27 11:05:47.498 info instance system.adapter.yr.0 terminated with code 0 (OK) yr-0 2016-07-27 11:05:42.442 info got weather data from yr.no yr-0 2016-07-27 11:05:41.888 info starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.yr host-vm32test 2016-07-27 11:05:41.432 info instance system.adapter.yr.0 started with pid 6990 host-vm32test 2016-07-27 11:05:41.429 info instance scheduled system.adapter.yr.0 6 * * * * admin-0 2016-07-27 11:05:40.455 info successful connection to socket.io from ::ffff:109.194.66.17 host-vm32test 2016-07-27 11:05:37.437 info instance scheduled system.adapter.weatherunderground.0 */48 * * * * sql-0 2016-07-27 11:05:34.065 info Connected to sqlite sql-0 2016-07-27 11:05:34.046 info enabled logging of system.host.vm32test.freemem sql-0 2016-07-27 11:05:34.045 info enabled logging of system.host.vm32test.load sql-0 2016-07-27 11:05:34.045 info enabled logging of system.host.vm32test.memRss sql-0 2016-07-27 11:05:34.045 info enabled logging of system.host.vm32test.memHeapTotal sql-0 2016-07-27 11:05:34.045 info enabled logging of system.host.vm32test.memHeapUsed sql-0 2016-07-27 11:05:34.045 info enabled logging of system.host.vm32test.mem sql-0 2016-07-27 11:05:34.015 info starting. Version 1.0.9 in /opt/iobroker/node_modules/iobroker.sql host-vm32test 2016-07-27 11:05:33.432 info instance system.adapter.sql.0 started with pid 6981 admin-0 2016-07-27 11:05:30.851 info Repository received successfully. admin-0 2016-07-27 11:05:30.499 info received all states admin-0 2016-07-27 11:05:30.485 info received all objects host-vm32test 2016-07-27 11:05:30.290 info Update repository "default" under "http://download.iobroker.net/sources-dist.json" admin-0 2016-07-27 11:05:30.210 info Use link "https://localhost:8081" to configure. admin-0 2016-07-27 11:05:30.210 info https server listening on port 8081 admin-0 2016-07-27 11:05:30.208 info requesting all objects admin-0 2016-07-27 11:05:30.203 info requesting all states admin-0 2016-07-27 11:05:30.093 info Request actual repository... admin-0 2016-07-27 11:05:30.070 info starting. Version 1.2.6 in /opt/iobroker/node_modules/iobroker.admin host-vm32test 2016-07-27 11:05:29.435 info instance system.adapter.admin.0 started with pid 6972 host-vm32test 2016-07-27 11:05:29.426 info starting 4 instances host-vm32test 2016-07-27 11:05:29.425 info 24 instances found host-vm32test 2016-07-27 11:05:29.422 info InMemoryDB connected inMem-objects 2016-07-27 11:05:29.419 info listening on port 9001 inMem-states 2016-07-27 11:05:29.403 info listening on port 9000 host-vm32test 2016-07-27 11:05:29.392 info ip addresses: 192.168.69.32 fe80::5054:ff:fe9b:9929 host-vm32test 2016-07-27 11:05:29.392 info hostname: vm32test host-vm32test 2016-07-27 11:05:29.391 info Copyright (c) 2014-2016 bluefox, hobbyquaker host-vm32test 2016-07-27 11:05:29.389 info iobroker.js-controller version 0.10.1 js-controller starting !
                                            9813
