    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. node-pre-gyp ERR! not ok
      Mr_REM_Esq last edited by
      Некоторое время назад при установке или обновлении драйверов в логе стали появляться вот таки ошибки:
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! not ok
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! node -v v8.15.0
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! System Linux 4.9.0-8-amd64
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
      iobroker 2019-02-15 11:55:34.010 info node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/b
      iobroker 2019-02-15 11:55:34.005 info node-pre-gyp ERR! build error
      iobroker 2019-02-15 11:55:34.000 info gyp ERR! not ok
      iobroker 2019-02-15 11:55:34.000 info gyp ERR! node-gyp -v v3.8.0
      iobroker 2019-02-15 11:55:34.000 info gyp ERR! node -v v8.15.0
      iobroker 2019-02-15 11:55:34.000 info gyp ERR! cwd /opt/iobroker/node_modules/usb
      iobroker 2019-02-15 11:55:34.000 info gyp ERR! System Linux 4.9.0-8-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_module
      iobroker 2019-02-15 11:55:33.995 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
      iobroker 2019-02-15 11:55:33.995 info gyp ERR! stack at ChildProcess.emit (events.js:214:7)
      iobroker 2019-02-15 11:55:33.995 info gyp ERR! stack at emitTwo (events.js:126:13)
      iobroker 2019-02-15 11:55:33.995 info gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      iobroker 2019-02-15 11:55:33.991 info ERR! build error
      С чем это связано и как с этим бороться?
      1.2k
      node-pre-gyp err
