    4. iogo-Adapter lässt sich nicht installieren
    UNSOLVED iogo-Adapter lässt sich nicht installieren
      Strizz last edited by
      die Installation des iogo-Adapters führt bei mir zu folgenden Fehlermeldungen im Log:
      2019-02-17 12:21:50.340 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/grpc_extension.js:57
      2019-02-17 12:21:50.340 - error: Caught by controller[0]: throw e;
      2019-02-17 12:21:50.341 - error: Caught by controller[0]: ^
      2019-02-17 12:21:50.341 - error: Caught by controller[0]: Error: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/node-v57-linux-arm-glibc/grpc_node.node)
      2019-02-17 12:21:50.341 - error: Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
      2019-02-17 12:21:50.341 - error: Caught by controller[0]: at Module.load (module.js:566:32)
      2019-02-17 12:21:50.341 - error: Caught by controller[0]: at tryModuleLoad (module.js:506:12)
      2019-02-17 12:21:50.341 - error: Caught by controller[0]: at Function.Module._load (module.js:498:3)
      2019-02-17 12:21:50.342 - error: Caught by controller[0]: at Module.require (module.js:597:17)
      2019-02-17 12:21:50.342 - error: Caught by controller[0]: at require (internal/module.js:11:18)
      2019-02-17 12:21:50.342 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/grpc_extension.js:32:13)
      2019-02-17 12:21:50.342 - error: Caught by controller[0]: at Module._compile (module.js:653:30)
      2019-02-17 12:21:50.342 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
      2019-02-17 12:21:50.342 - error: Caught by controller[0]: at Module.load (module.js:566:32)
      2019-02-17 12:21:50.343 - error: host.orangepiplus2e instance system.adapter.iogo.0 terminated with code 1 ()
      2019-02-17 12:21:50.343 - info: host.orangepiplus2e Restart adapter system.adapter.iogo.0 because enabledcode_text
      Ich habe versucht, libstdc++6 noch einmal zu installieren. Da bekomme ich dann allerdings folgende Meldung:
      root@orangepiplus2e:~# apt-get install libstdc++6
      Reading package lists... Done
      Building dependency tree
      libstdc++6 is already the newest version.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Bin jetzt etwas ratlos. Kann ich sonst noch was tun?
      npm: vers 6.4.1
      node: vers 8.15.0
      Hat jemand eine Idee?
      Strizz
        A Former User @Strizz last edited by
        @Strizz ich kenn zwar den Adapter gut... habe aber leider auch keine Idee 😕
          Strizz @Guest last edited by
          @nisio
          Dann sind wir schon mal zu zweit.😀 Danke für die Info. Werde meinen iobroker gelegentlich noch mal neu aufsetzen, und es dann noch einmal probieren.
          Strizz
            anubiss1337 last edited by anubiss1337
            hab so da so ein ähnliches wenn nicht sogar das gleiche Problem.
            2019-10-10 18:39:11.372 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/grpc_extension.js:57
            2019-10-10 18:39:11.372 - error: Caught by controller[0]: throw e;
            2019-10-10 18:39:11.372 - error: Caught by controller[0]: ^
            2019-10-10 18:39:11.372 - error: Caught by controller[0]: Error: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/node/extension_binary/node-v64-linux-arm-glibc/grpc_node.node)
            2019-10-10 18:39:11.372 - error: Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
            2019-10-10 18:39:11.372 - error: Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
            2019-10-10 18:39:11.372 - error: Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
            2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
            2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
            2019-10-10 18:39:11.373 - error: Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
            2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.iogo/node_modules/grpc/src/grpc_extension.js:32:13)
            2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
            2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
            2019-10-10 18:39:11.373 - error: Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
            2019-10-10 18:39:11.373 - error: host.axtpi instance system.adapter.iogo.0 terminated with code 1 ()
            nodej -v
            v6.14.3
            noe -v
            v10.16.3
            npm -v
            v6.11.3
            @Strizz
            hast Du das Problem gelöst?
              Strizz @anubiss1337 last edited by
              @anubiss1337 Leider nein! Habe aufgegeben!
              Strizz
                A Former User last edited by
                Welche Hardware und welches Betriebssystem nutzt ihr?
                  @nis
                  Hardware: Ornagepi Plus 2e
                  Betriebssystem: Linux
                  Strizz
                    Hardware: raspberry pi 3b
                    Software: linux
                    • E
                      e-s last edited by
                      Schaut mal bitte nochmal nach den Nodejs Versionen. Und updated diese auf v8 bzw v10. Oben bei der einen Angabe ist ist die node und Nodejs Version nicht gleich. Also bitte da nochmal nachschauen.
                        Hab jetzt, nach vielen Probleme, folgendes hinbekommen:
                        /opt/iobroker $ nodejs -v
                        v10.16.3
                        /opt/iobroker $ node -v
                        v10.16.3
                        /opt/iobroker $ npm -v
                        6.11.3
                        Um dahin zu kommen, hab ich, wenn ich das richtig verstanden habe, iobroker komplett neu aufgesetzt. Danach hab ich, mein zum Glück vorher ertelltes Backup eingespielt.
                        Vielleicht gehört das nicht hierrein aber bei der Instanz tr-064.0 hab ich seit längerem dieses Problem:
                        2019-10-13 11:09:13.457 - error: Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
                        2019-10-13 11:09:13.457 - error: Caught by controller[0]: fns.adapter = fns.adapter(options);
                        2019-10-13 11:09:13.457 - error: Caught by controller[0]: ^
                        2019-10-13 11:09:13.457 - error: Caught by controller[0]: TypeError: fns.adapter is not a function
                        2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
                        2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:15:20)
                        2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                        2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                        2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                        2019-10-13 11:09:13.458 - error: Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                        2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                        2019-10-13 11:09:13.458 - error: Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                        2019-10-13 11:09:13.459 - error: Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
                        2019-10-13 11:09:13.459 - error: Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
                        2019-10-13 11:09:13.459 - error: host.axtpi instance system.adapter.tr-064.0 terminated with code 1 ()
                        haben diese Fehler evtl. etwas gemeinsam?
                        • sigi234
                          sigi234 Forum Testing Most Active @anubiss1337 last edited by sigi234
                          @anubiss1337 sagte in iogo-Adapter lässt sich nicht installieren:
                          Suche mal nach soef oder nimm den neuen Adapter.
                          https://forum.iobroker.net/topic/22782/aufruf-test-community-version-vom-tr-064-adapter
                          iogo adapter
                          714
