    4. Windows Neustart Fehler
      Ritter last edited by
      Hallo!
      ioBroker ist auf einem NUC mit Windows 10 installiert. Immer wenn sich der NUC mal wegen eines updates neu startet stehen im log folgende Fehler:
      host-NUC 2016-02-21 23:08:46 error instance system.adapter.email.0 terminated with code 7 (Adapter already running)
      host-NUC 2016-02-21 23:08:45 info instance system.adapter.web.0 started with pid 4824
      host-NUC 2016-02-21 23:08:45 info instance system.adapter.hm-rpc.2 started with pid 5504
      host-NUC 2016-02-21 23:08:45 info instance system.adapter.node-red.0 started with pid 7528
      host-NUC 2016-02-21 23:08:45 info instance system.adapter.email.0 started with pid 5388
      host-NUC 2016-02-21 23:08:44 info Restart adapter system.adapter.history.0 because enabled
      host-NUC 2016-02-21 23:08:44 error instance system.adapter.history.0 terminated with code 7 (Adapter already running)
      host-NUC 2016-02-21 23:08:44 info Restart adapter system.adapter.hm-rpc.0 because enabled
      host-NUC 2016-02-21 23:08:44 error instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
      host-NUC 2016-02-21 23:08:44 info Restart adapter system.adapter.hm-rpc.1 because enabled
      host-NUC 2016-02-21 23:08:44 error instance system.adapter.hm-rpc.1 terminated with code 7 (Adapter already running)
      host-NUC 2016-02-21 23:08:43 info Restart adapter system.adapter.hm-rega.0 because enabled
      host-NUC 2016-02-21 23:08:43 error instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
      host-NUC 2016-02-21 23:08:42 info instance system.adapter.history.0 started with pid 2572
      host-NUC 2016-02-21 23:08:42 info instance system.adapter.hm-rpc.0 started with pid 2916
      host-NUC 2016-02-21 23:08:42 info instance system.adapter.hm-rpc.1 started with pid 7660
      host-NUC 2016-02-21 23:08:41 info instance system.adapter.hm-rega.0 started with pid 2668
      host-NUC 2016-02-21 23:08:26 info Restart adapter system.adapter.admin.0 because enabled
      host-NUC 2016-02-21 23:08:26 error instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      host-NUC 2016-02-21 23:08:23 info instance system.adapter.admin.0 started with pid 2552
      host-NUC 2016-02-21 23:08:20 info Restart adapter system.adapter.javascript.0 because enabled
      host-NUC 2016-02-21 23:08:20 error instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
      Wenn ich dann von Windows aus ioBroker neu starte passt wieder alles.
