    3. Tester
    4. ioBroker.upnp - please test
      Im Rahmen von der Freigabe für js-controller@1.5.7 wurde auch upnp Adapter upgedatet.
      Kann jemand die neue Version von upnp testen?
      cd /<dein Verzeichnis>/iobroker
      iobroker upnp stop
      npm i https://github.com/iobroker-community-adapters/ioBroker.upnp/tarball/refactoring --production
      iobroker u upnp
      iobroker upnp restart
      Downgrade back (falls irgendwelche Probleme und upnp nicht geht):
      iobroker upnp stop
      npm i iobroker.upnp --production
      iobroker u upnp
      H 2 Replies Last reply Reply Quote 3
      • sigi234
        Erledigt...........Adapter Grün
        upnp.0	2019-02-19 12:04:50.295	debug	response
        upnp.0	2019-02-19 12:04:50.094	debug	response
        upnp.0	2019-02-19 12:04:50.019	debug	Send Command
        upnp.0	2019-02-19 12:04:50.003	debug	Send Command
        upnp.0	2019-02-19 12:04:40.291	debug	response
        upnp.0	2019-02-19 12:04:40.083	debug	response
        upnp.0	2019-02-19 12:04:40.006	debug	Send Command
        upnp.0	2019-02-19 12:04:30.351	debug	response
        upnp.0	2019-02-19 12:04:30.130	debug	response
        upnp.0	2019-02-19 12:04:30.020	debug	Send Command
        upnp.0	2019-02-19 12:04:30.005	debug	Send Command
        upnp.0	2019-02-19 12:04:20.322	debug	response
        upnp.0	2019-02-19 12:04:20.101	debug	response
        upnp.0	2019-02-19 12:04:20.009	debug	Send Command
        upnp.0	2019-02-19 12:04:18.762	debug	system.adapter.admin.0: logging true
        upnp.0	2019-02-19 12:04:14.295	debug	Found 0 devices
        upnp.0	2019-02-19 12:04:10.308	debug	response
        upnp.0	2019-02-19 12:04:10.102	debug	response
        upnp.0	2019-02-19 12:04:10.006	debug	Send Command
        upnp.0	2019-02-19 12:04:10.004	debug	Send Command
        upnp.0	2019-02-19 12:04:09.287	info	Auto discover: false
        upnp.0	2019-02-19 12:04:09.271	info	starting. Version 0.3.9 in C:/ioBroker/node_modules/iobroker.upnp, node: v8.15.0
        upnp.0	2019-02-19 12:04:09.271	debug	statesDB connected
        upnp.0	2019-02-19 12:04:09.265	debug	objectDB connected
        Bluefox 1 Reply Last reply Reply Quote 1
          Bluefox @sigi234 last edited by Bluefox
          Участник @sigi234 написал в ioBroker.upnp - please test:
          Found 0 devices
          aber geht der Adapter? Waren vorher irgendwelche Geräte da?
          • sigi234
            sigi234 Forum Testing Most Active @Bluefox last edited by sigi234
            @Bluefox
            Ja Adapter geht, Geräte waren da.
            Habe die Automatische Erkennung ausgeschaltet.
            EDIT: War noch die alte Version
            • Neuschwansteini
              Neuschwansteini last edited by
              Bei mir auch ohne Probleme, keine Fehler im Log. Allerdings hat er ein Objekt ohne Namen angelegt, ist das normal?
              Bluefox 1 Reply Last reply Reply Quote 0
                Bluefox @Neuschwansteini last edited by
                @ilovegym Nein. Das ist nicht normal, kann es sein, dass ID is upnp.0..controllee.xxx ?
                Neuschwansteini 2 Replies Last reply Reply Quote 0
                • Neuschwansteini
                  Neuschwansteini @Bluefox last edited by
                  @Bluefox ja, so steht es in der RAW..
                  er legt mir auch zuwenig Objecte bei den devices an, gerade bei der Fritzbox sollte da doch einiges angelegt werden..hmm
                  ich stell mal auf debug ...
                  • Neuschwansteini
                    @Bluefox aha, der Adapter kann so einiges nicht parsen...
                    iobrokerlog-upnp.log
                    ...hmm kann pihole was damit zu tun haben? finde da aber nix im log..
                    Bluefox 2 Replies Last reply Reply Quote 0
                    • TheDuke
                      TheDuke last edited by
                      Ich kenne den Apdapter zwar nicht aber habe ihn mal getestet 🙂
                      Läuft soweit, findet aber auch meine Repeater ? Soll das so sein ?
                      Dann noch alle Amazon FireTV und Co und auch mein eines upnp Gerät.
                      Neuschwansteini 1 Reply Last reply Reply Quote 1
                        Участник @ilovegym написал в ioBroker.upnp - please test:
                        Kannst du mir den Inhalt von http://192.168.178.28:80/plugin/discovery/discovery.xml zeigen?
                        Neuschwansteini 1 Reply Last reply Reply Quote 0
                        • Neuschwansteini
                          Neuschwansteini @Bluefox last edited by Neuschwansteini
                          @Bluefox klar doch, das ist mein Octoprint-Pi, hab davon ein paar im Einsatz..
                          <root><specVersion><major>1</major><minor>0</minor></specVersion><device><deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType><friendlyName>OctoPrint instance "Octopi"</friendlyName><manufacturer>The OctoPrint Project</manufacturer><manufacturerURL>http://www.octoprint.org/</manufacturerURL><modelName>1.3.10</modelName><UDN>uuid:9a974f73-d481-44d5-8f93-088c35bd0dcd</UDN><serviceList>
                                  </serviceList><presentationURL>http://192.168.178.28/</presentationURL></device></root>
                          • Neuschwansteini
                            Neuschwansteini @TheDuke last edited by
                            @TheDuke bei dir findet er bei den AVM devices viel mehr Daten.. bei mir ist da irgendwo ein Problem.. 😞
                              Bei OctoPrint gibt es auch nichts zum parsen. Alles oK.
                              • Neuschwansteini
                                @Bluefox ok, aber bei der Fritzbox muss er doch mehr objekte anlegen.. ? Die alte Version hat da ganz viele Einträge erzeugt, diese Version nur diese.. auch bei anderen devices.. also irgendwie ist das meiner Meinung nach Merkwürdig..
                                Bei dem Screenshot von TheDuke im Beitrag oben sieht man ja, dass beim FritzRepeater jede Menge einträge da sind.
                                Bei mir siehts dagegen so aus, und ich weiß nicht, warum... 😞
                                  MyMeyer @Neuschwansteini last edited by
                                  @ilovegym Sieht bei mir auch so aus. Findet bei FritzBox nichts brauchbares.
                                  sigi234 1 Reply Last reply Reply Quote 1
                                  • sigi234
                                    sigi234 Forum Testing Most Active @MyMeyer last edited by
                                    @MyMeyer
                                    Bei mir findet er genug:
                                    • Neuschwansteini
                                      Neuschwansteini @sigi234 last edited by
                                      @sigi234 was ist bei dir anders ? Mit der Version 0.3.9 des upnp Adapter bekomme ich diese Einträge auch, mit der Version 1.0 nicht.
                                      Node 8.15, NPM 6.8, js-controller 1.5.7
                                        Ich habe einen Fehler gefunden. Bitte noch mal vom git probieren
                                        • Neuschwansteini
                                          @Bluefox Version 1.0.1 installiert, jetzt legt er viel mehr Einträge an, allerdings passiert jetzt auch das, was mit Version 0.3.9 passiert - die CPU Last geht hoch und iobroker restartet, alle Adapter auf Rot..
                                          hier das log, er meldet am Schluss uncaught exception: Maximum call stack size exceeded
                                          dabei hatte er nur 50 devices gefunden... sollten so um die 160 sein.. die gerade online sind..
                                          • sigi234
                                            sigi234 Forum Testing Most Active @Neuschwansteini last edited by
                                            @ilovegym sagte in ioBroker.upnp - please test:
                                            NPM 6.4.1
                                            sigi234 Neuschwansteini 2 Replies Last reply Reply Quote 0
                                            31.7k
                                            79.8k
                                            adapter test
                                            18
                                            196
                                            19451
