    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Ошибки mdns при обновдение драйверов
      Bosya last edited by
      При обновлении драйверов постоянно такие ошибки. Кажись обновляется, но как-то стремно это:
      $ ./iobroker upgrade javascript
      Update javascript from @4.1.0 to @4.1.2
      NPM version: 6.7.0
      npm install iobroker.javascript@4.1.2 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
      In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
       #include <dns_sd.h>
      compilation terminated.
      make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      gyp
       ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at emitTwo (events.js:126:13)
      gyp ERR!
       stack     at ChildProcess.emit (events.js:214:7)gyp
      ERR!
       stack
           at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp ERR! System Linux 4.19.20-sunxi
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/mdns
      gyp
      ERR!
      node -v v8.15.0gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      npm
       WARN
      optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 (node_modules/mdns):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.4.0 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.javascript"
      npm
      WARN
       deprecated
       coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      npm
       WARN
      deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm
       WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm
      WARN
       deprecated
       circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      Что с этим делать?
        После инсталяции всего что нарыл на форуме:
        sudo apt-get install libnss-mdns avahi-discover avahi-utils build-essential libavahi-compat-libdnssd-dev
        пошло веселее:
        Update javascript from @4.1.2 to @4.1.3
        NPM version: 6.7.0
        npm install iobroker.javascript@4.1.3 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
        ../src/dns_service_browse.cpp: In function ‘void node_mdns::OnServiceChanged(DNSServiceRef, DNSServiceFlags, uint32_t, DNSServiceErrorType, const char*, const char*, const char*, void*)’:
        ../src/dns_service_browse.cpp:39:50: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
             Nan::MakeCallback(this_, callback, argc, info);
        In file included from ../src/mdns.hpp:12:0,
                         from ../src/dns_service_browse.cpp:1:
        ../../nan/nan.h:958:46: note: declared here
           NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
        ../src/dns_service_enumerate_domains.cpp: In function ‘void node_mdns::OnEnumeration(DNSServiceRef, DNSServiceFlags, uint32_t, DNSServiceErrorType, const char*, void*)’:
        ../src/dns_service_enumerate_domains.cpp:29:50: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                         from ../src/dns_service_enumerate_domains.cpp:1:
        ../src/dns_service_register.cpp: In function ‘void node_mdns::OnServiceRegistered(DNSServiceRef, DNSServiceFlags, DNSServiceErrorType, const char*, const char*, const char*, void*)’:
        ../src/dns_service_register.cpp:48:54: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                         from ../src/dns_service_register.cpp:1:
        ../src/dns_service_resolve.cpp: In function ‘void node_mdns::OnResolve(DNSServiceRef, DNSServiceFlags, uint32_t, DNSServiceErrorType, const char*, const char*, uint16_t, uint16_t, const unsigned char*, void*)’:
        ../src/dns_service_resolve.cpp:51:50: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                         from ../src/dns_service_resolve.cpp:1:
        ../src/socket_watcher.cpp: In static member function ‘static void node_mdns::SocketWatcher::Callback(uv_poll_t*, int, int)’:
        ../src/socket_watcher.cpp:100:63: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                 Nan::MakeCallback(watcher->handle(), callback, 2, argv);
                         from ../src/socket_watcher.cpp:1:
        npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
        npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
        npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
        npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
        npm WARN lifecycle iobroker.javascript@4.1.3~postinstall: cannot run in wd iobroker.javascript@4.1.3 node ./install/installTypings.js (wd=/opt/iobroker/node_modules/iobroker.javascript)
        Update "system.adapter.javascript.0"
        got /opt/iobroker/node_modules/iobroker.javascript/admin
        upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/razor/razor.js vs/basic-languages/razor/razor.js application/javascript
        upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/msdax/msdax.js vs/basic-languages/msdax/msdax.js application/javascript
        upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/dockerfile/dockerfile.js vs/basic-languages/dockerfile/dockerfile.js application/javascript
        upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/copy-content.770c7d5d.svg static/media/copy-content.770c7d5d.svg image/svg+xml
        upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/precache-manifest.b4cb9f7f98e4d5115595edf28f571273.js precache-manifest.b4cb9f7f98e4d5115595edf28f571273.js application/javascript
        upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
        upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
        upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
        upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
        upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur application/octet-stream
        upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur application/octet-stream
        upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur application/octet-stream
        upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/x-wav
        upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
        upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
        upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/x-wav
        upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
        upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
        upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/x-wav
        upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
        upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
        upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
        upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
        upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
        upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
        upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
        upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/x-icon
        upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
        upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
        Adapter "javascript" updated
        Но что делать с тем что осталось? Как обновить?
        mdns error
